Viewing 15 posts - 601 through 615 (of 714 total)
  • #22952
    • Replies 8,739
    Very interesting and PC related. ‘wake on magic packet’ and ‘wake on pattern match’ is interesting, was this option also enabled for 2.4GHz or is it at adaptor level this value is set at ?
    Edit: ignore, just checked and this is an pc adapter level option
    #23014
    • Replies 148
    Just wondering what’s everyones thoughts on running Merlin on the DSL-AX82U?  I note there is an offshoot that supports the DSL version.  Worth it?
    #23015
    • Replies 8,739
    [quote quote=23014]Just wondering what’s everyones thoughts on running Merlin on the DSL-AX82U? I note there is an offshoot that supports the DSL version. Worth it?[/quote]
    @GNUton builds are good as they leverage all the additional features ASUSWRT-Merlin builds incorporates., I tend to think along these lines, if the Stock ASUSWRT firmware offers me what I need, and I cannot see any additional services / features / benefits offered by ASUSWRT-Merlin that I could make of use, then little point in using another build.
    But if you like to tinker, then @GNUton builds are perfect for that
    #23016
    They even implement bugfixes or better solutions of some features to AsusWRT.
    So I would recommend to use them even if you dont need additional features.
    #23658
    Emrah GöktaşEmrah Göktaş
    • Replies 11
    I am using asus dsl-ax82u vdsl2. my question
    Why can’t I change Annex B
    I WANT TO MAKE Annex A BUT IT WON’T LET ME CHOOSE
    And finally, I am sending you the photo of my line values, how much should I do?
    Firmware:388.1_0-gnuton1
    Black Bird
    • Replies 146
    Annex A and Annex B settings are applicable to hardware and ADSL. Annex modes are not valid for VDSL. Those who tell you to choose Annex A for VDSL seem to mislead you as they are not knowledgeable about the subject. For VDSL, upload and download channels are set as the operator wishes, and you cannot change this.
    The operator (Turk Telekom) can allocate more download bandwidth to subscribers who are given less upload speed, or the download and upload channels of a 16 Mbps package user and a 100 Mbps package user are not the same. DSL-AX82U or other brand modems automatically comply with this.
    #23661
    • Replies 8,739
    [quote quote=23660]Annex A and Annex B settings are applicable to hardware and ADSL. Annex modes are not valid for VDSL[/quote]
    #23662
    • Replies 11
    but the vdsl2 Annex B mode I took in the picture above appears
    Whatever there appears its not relevant at all for VDSL
    Annexes mean very different things for ADSL and VDSL, it is not anymore POTS vs. ISDN support like on old lines.
    So there are even other Annexes which could be taken like M or J, but it is handled by DSLAM and your modem and could change with each sync.
    #23666
    David DoranDavid Doran
    • Replies 55
    Does anybody have any experience with the DSL-AX82U and AiMesh? Mainly as the gateway/main node with something like a TUF-AX5400 as a satellite? Any recommended configs that work ok? I hear alot of horror stories with AiMesh so I am thinking of going Eero.
    #23667
    • Replies 8,739
    [quote quote=23662]but the vdsl2 Annex B mode I took in the picture above appears[/quote]
    Does seem that ASUS have dropped System Log – DSL Log from ‘Regional Mode’ to ‘ANNEX Mode’ for naming convention.
    Advanced Settings > System Log > DSL Log
    Annex Mode:
    POTS = Annex A
    ISDN = Annex B
    Advanced Settings > Administration > DSL Settings
    Annex Mode:
    ADSL Settings = Annex A, A/L, A/M and A/L/M
    VDSL Settings = ANNEX A/B
    #23668
    • Replies 8,739
    [quote quote=23666]Does anybody have any experience with the DSL-AX82U and AiMesh? Mainly as the gateway/main node with something like a TUF-AX5400 as a satellite? Any recommended configs that work ok? I hear alot of horror stories with AiMesh so I am thinking of going Eero.[/quote]
    AiMesh, especially around ASUS XT8 etc. did not work well for a long while with AiMesh, that was mainly due to ASUS introducing next generation of firmware, 388 builds, where as prior to that, the later 386 builds had worked well.
    The 388 builds have settled down from an Aimesh perspective, but there are still issues I think with ASUS ET12 etc.
    DSL-AX82U I had working with AiMesh for a couple of days (testing) all seemed stable.
    #23670
    Black Bird
    • Replies 146
    It appears that way, but that information is not accurate.
    #23671
    • Replies 55
    What nodes did you have with DSL-AX82U? @UK Sentinel
    #23672
    • Replies 8,739
    I had another DSL-AX82U so meshed up as a wireless node well it did.
    Also tried it with my RT-ac86u and this worked also as Aimesh node
