Viewing 15 posts - 616 through 630 (of 714 total)
  • #23674
    • Replies 8,739
    Forgot to say, this was using the @GNUton build for the DSL -AX82u not that this should make any difference from an AiMesh perspective ;)
    #23675
    Emrah GöktaşEmrah Göktaş
    • Replies 11
    i used asus dsl n16 before so i sold it because the snr didn’t work properly but asus dsl n16 ta vdsl2 let me choose anything like Annex A or Annex B. or airties 5650 also let me choose Annex A or Annex
    I just bought DSL-AX82U and installed the first fw merlin 388 mast directly, I am really satisfied.
    I’m not having a problem right now, but is the Annex A or Annex B selection event complete?
    #23677
    • Replies 8,739
    [quote quote=23676]I’m not having a problem right now, but is the Annex A or Annex B selection event complete?[/quote]
    Not sure what you mean ?
    The DSL-N16  uses MediaTek for its CPU, which is very good for options on ADSL.
    DSL-AX82U uses Broadcom for its CPU, so less options (Annex A or B) but still good, stable especially with VDSL
    #23859
    • Replies 148
    I’ve been having some strange issues with this router since the last update and I can’t help but think it’s the new dsl driver in the latest version.
    My speed has been slowly decreasing over time, currently synced at 54mbps.  I had openreach over to check the line and they confirmed when they plug their tester into the dsl cable they get 64mbps, so something to do with the  router.
    I plugged in an old ISP router I had buried away, and that synced at almost 63.
    I guess I will try and go back to the old firmware and see what happens.  In the current release notes it says it uses the new driver ‘by default’, is it possible to select to use the old driver whilst keeping the new firmware then?  I’d like to not lose the other enhancements in the current version.
    #23864
    • Replies 8,739
    I seem to remember somebody else mentioning about the latest driver for the DSL-AX82U causing them sync rate issues with this latest firmware release.
    Also, check to make sure you are not experiencing high CRC’s or FEC’s etc ?
    #23871
    David DoranDavid Doran
    • Replies 55
    Just to be clear you do mean 3.0.0.4.388_22048? (2022/12/29)
    It was fine in holding sync for me although I was on a slower FTTC tier with BT.
    Some screenshots I saved:
    View post on imgur.com
    One after 16 hours then another after 2 days had passed.
    As Sentinel says, how are CRC and FEC looking?
    #23881
    • Replies 148
    Over the past 14 hours
    FEC: 1447
    HEC: 0
    CRC: 6
    ES: 4
    SES: 0
    I think these stats are pretty good? Just seems really odd that their tester reads a lot higher (and that wasn’t even directly into the socket, they tested via the dsl cable by plugging the end that is in the ASUS into their tester) and the old isp router also synced higher, just this ASUS one seems to be struggling a bit
    #23885
    • Replies 8,739
    [quote quote=23881]I think these stats are pretty good?[/quote]
    Stats a very good considering, definitely worth trying a downgrade on firmware, to test older driver and see if that makes any difference
    #23887
    Newer chips doesn’t support old lines as well as older ones build for those slower standards.
    #23934
    Black Bird
    • Replies 146
    [quote quote=23887]Newer chips doesn’t support old lines as well as older ones build for those slower standards.[/quote]
    There is no backward compatibility issue with DSL, but there are compatibility issues with some devices on WIFI. For example, my old phone cannot connect at 80 MHz 2×2, so I am using 433 Mbps instead of 866 Mbps.
    #25701
    AvatarVikArmo
    • Replies 6
    Can anyone please help with the log message below? It is absolutely flooded with this and only this.
    Jul 7 11:54:02 miniupnpd[2519]: accept(http): Too many open files
    and on and on…
    #25702
    • Replies 8,739
    Haven’t seen those for a while, usually they are related to a device interacting with the UPNP server maybe media on you DSL-AX82U.
    Alas only way to tell is understand when the logs started showing these massages and if this correlates with a device on you network being turned on (NAS) etc.
    Alternatively, if logs are being created all the time, you will have to turn off individual devices on your LAN and see if logs are still being created etc.
    #26395
    • Replies 8,739
    New ASUS DSL-AX82U Firmware version 3.0.0.4.388_23756
    Version 3.0.0.4.388_23756
    2023/08/11
    Security:
    Fixed Client DOM Stored XSS.
    Fixed CVE-2022-46871.
    Fixed httpd command injection vulnerabilities.
    Fixed httpd DoS vulnerabilities.
    Fixed httpd integer overflow vulnerability.
    Fixed httpd Null Pointer Dereference vulnerabilities.
    Fixed lighttpd command injection vulnerability.
    Fixed not secure cookies when using https.
    Fixed cfg server security issues.
    Fixed Stored Cross Site Scripting.
    Updated OpenSSL to version 1.1.1t for CVE vulnerabilities.
    Fixed XSS attack via USB EXT3 foldername.
    Fixed Stored Cross Site Scripting. Thanks to Howard McGreehan.
    Fixed XSS attack via malformed hostname in DHCP request
    Fixed MiniDLNA CVE-2020-28926.
    Fixed OpenVPN CWE 134 issue.
    Fixed ffmpeg CVE-2022-3964 / CVE-2022-48434 / CVE-2022-3109.
    Fixed command injection issues.
    Fixed cURL CVE-2023-28322, CVE-2023-28319.
    Updated libxml2 to version 2.10.4.
    Fixed Brute Force Protection for SSH and telnet server.
    Fixed AiCloud ZDI-CAN-16078.
    Fixed the vulnerability in the logmessage function.
    Feature:
    Add Surfshark in VPN Fusion allows you to surf the internet anonymously and securely from anywhere by encrypting connections. Please refer to https://asus.click/SurfsharkVPN.
    Fixed AiMesh related bugs.
    Fixed minor GUI bugs.
    Fixed AiCloud ftpclient login issue.
    Fixed ipv6 network service filter issue.
    Enhanced Dual-WAN fail-over/fail-back. Fixed switching Operation Mode.
    Fixed resource leak issues.
    Updated OpenVPN server for the compatibility with OpenVPN 2.6 client.
    Fixed bandwidth limiter rule not to restart in mesh node.
    Fixed possible system crash issue with setting WireGuard VPN Fusion.
    https://www.asus.com/uk/networking-iot-servers/modem-routers/all-series/dsl-ax82u/helpdesk_bios/?model2Name=DSL-AX82U
    #26447
    RDash123RDash123
    • Replies 10
    2023/08/11
    Security:
    Feature:
    Flashed it on day of release and so far its excellent.
    There is just one problem and that is LED bug.
    When router renews IP address Online LED is still off but all is fine and fully works.
    Current fix is to login via App or WebGUI and toggle LED On/Off
    I reported this issue to Asus via WebGUI maybe they will find a permanent fix.
    #26451
    • Replies 8,739
    Great news @RDash123 good to hear the new firmware release is working well, I will drop ASUS an email and remind them also about LED bug
