- This topic has 711 replies, 37 voices, and was last updated 1 month, 1 week ago by
El3rt1cal.
April 18, 2021 at 11:09 am #12888
Thanks, wow June, I was hoping to get one this month or next.
I think I’ll keep an eye out as I suspect some places may have it available sooner to purchase. If not, i’ll pre-order it.
April 18, 2021 at 5:23 pm #12889[quote quote=12886]Which firmware version of 7530 do you use? Did you try to use old (previous) DSL-driver? That often helps. Not all drivers work well with all lines and remote systems or their firmwares.[/quote]
I used 7.24 and 7.25, FritzBox is a good modem but it has one negative “feature”, if it sees the noise in dsl line it gives a command to reboot, even the slightest noise can trigger to reboot.
April 18, 2021 at 5:45 pm #12890Did you try with previous DSL-driver?
Many solved their problems with it, can be changed in tab with DSL-stability settings.
At least give it a try till the other modem arrives.
April 18, 2021 at 6:24 pm #12891Sorry but FritzBox 7530 is gone from my life for good
, I have been having DSL-AX82U for over a month and I’m very happy with it
April 19, 2021 at 5:57 pm #12903[quote quote=12885]Amazon are taking pre-orders for the DSL-AX82U for £199.99 – Stock available in June. https://www.amazon.co.uk/s?k=asus+dsl-ax82u&ref=nb_sb_noss_1[/quote]
The date keeps changing on that, first time I looked at the product page it said it was in stock on the 9th June then yesterday it changed to the 2nd June and now today its saying the 31st May so it could be out even sooner 🙂
April 19, 2021 at 7:44 pm #12904April 19, 2021 at 11:18 pm #12907[quote quote=12878]sure thanks, hopefully someone can advise if connection has been stable :) Thanks Kev[/quote]
From a couple of days use the connection seems as reliable on VDSL 80/20 as the Billion 8800 axl I was replacing (which was rock solid). Little or no difference in any of the key stats. I am on a decent line, but it is also possible to adjust to provide greater stability. Wifi also seems issue free, (I have an AX 86U which I got a while back meshed to it).
April 20, 2021 at 12:33 am #12908[quote quote=12866]How has the unit been so far @El3rt1cal? Are you running it as it came from ASUS or loaded Merlin on it? I’m tempted to by one but a little weary due to the usual teething problems until its been out a while :) Kev[/quote]
Seems fine, stable and the Wifi reach is very good. I am using stock, firmware for at least the next couple of weeks. It was worth buying it and I expect prices will drop a bit, so it may be a good idea to wait.
April 20, 2021 at 5:11 pm #12910Thanks @El3rt1cal, my existing BT router appears to be dropped connection approx. every 1.5 – 2 hours. It automatically re-connects so hence I don’t always notice it if i’m not using it at the time it drops but super annoying…
Just looking for a shop to buy it from that has in stock and is one I’m familiar with ideally.
April 20, 2021 at 5:13 pm #12911that link on amazon shows 5th June for me atm…. going to wait and see if other suppliers get it :)
April 22, 2021 at 1:08 am #12913[quote quote=12911]that link on amazon shows 5th June for me atm…. going to wait and see if other suppliers get it :) Kev[/quote]
Shows April 27th for me now. It clearly doesn’t know when it wants to be released 😄
April 22, 2021 at 6:01 am #12915Just checked again this morning, still showing In stock on April 27th,
April 22, 2021 at 2:37 pm #12919ASUS have on there downloads servers the first firmware for the DSL-AX82U
Version 3.0.0.4.386_42438
https://www.asus.com/Networking-IoT-Servers/Modem-Routers/All-series/DSL-AX82U/HelpDesk_Download/
April 22, 2021 at 8:46 pm #12921Hi UK Sentinel, do you have the very first Firmware Version:3.0.0.4.386_41776 ? Before I update to next firmware I need at least first stable.. and why Asus don’t offer Firmware Restoration Utility or something from their website ???
Thank you.
April 22, 2021 at 9:27 pm #12922[quote quote=12921]3.0.0.4.386_42438[/quote]
The restoration util is there, It is on the support tab, same place as the more recent firmware, just get it to show all downloads.
I did upgrade the firmware and the performance is at least the same as that it came with. Not sure why Asus shipped it with the version they did, given they are not listing 3.0.0.4.386_41776 as the initial release.
