- This topic has 713 replies, 37 voices, and was last updated 3 weeks ago by
April 23, 2021 at 6:41 am #12924
[quote quote=12921]Hi UK Sentinel, do you have the very first Firmware Version:3.0.0.4.386_41776 ? Before I update to next firmware I need at least first stable.. and why Asus don’t offer Firmware Restoration Utility or something from their website ??? Thank you.[/quote]
As @El3rt1cal mentioned. expand the whole list and the restoration tool is there at the bottom (Version 2.1.0.2) under Software and Utility
original firmware [download id="12925"]
April 23, 2021 at 11:21 am #12929April 24, 2021 at 11:32 am #12932The user manual has been published
Asus FW
3.0.0.4.386_42438 (2021/04/20)
3.0.0.4.386_40058 (2020/10/13)Asuswrt-Merlin FW (Stable)
386.02_1-gnuton1 (2021/04/17)
386.01_2-gnuton1 (2021/03/08)ASUS Device Discovery
1.4.8.2 (2019/01/18)ASUS Firmware Restoration
2.1.0.2 (2018/07/23)ASUS DSL-AX82U user’s manual in English
E18230 (2021/04/21)ASUS DSL-AX82U Quick Start Guide for European
U16649 (2020/11/02)You need to login in order to vote
April 24, 2021 at 11:42 am #12935April 24, 2021 at 7:37 pm #12938Hi all,
New member here! :)
Got my DSL-AX82U couple of days ago and have finally set it up yesterday night. It’s still very early, but I’ve noticed a big difference in the wireless coverage area (for better) and also VDSL2 line speed increase. I have AiMesh with a RT-AX92U which gives perfect coverage in all my property including garden.
My old one the DSL-AC68U was about 7 years old and I think it was asking for a replacement – I started notice more connection drops so many that my line speed dropped and switched from FastPath to Interleave. Also started noticing bottlenecks on the wireless coverage.
I’ll post more details as time goes by.
Cheers.
April 24, 2021 at 7:49 pm #12940April 24, 2021 at 10:29 pm #12941April 24, 2021 at 11:28 pm #12947I’ve noticed some small memory leak about 9-10MB per every 6 hours, has everyone with DSL-AX82U experienced this too ?
April 25, 2021 at 6:38 am #12953[quote quote=12947]I’ve noticed some small memory leak about 9-10MB per every 6 hours, has everyone with DSL-AX82U experienced this too ?[/quote]
Some memory usage increase over time is normal, but it should stop eventually – how many days has the DSL-AX82U been running and what is memory used upto ?
FWIW – I did notice on the changelog I had on the last firmware I released is mentions a fix to a memory leak ?
Are you on the latest firmware – DSL-AX82U_3.0.0.4_386_42438 ?
Old Changelog:
Security Fixed and Improvement:
– Fixed XSS issue.
– Fixed httpd stack overflow issues.
– Fixed some AiCloud security issues.
– Enhanced httpd for DoS.
– Fixed httpd buffer overflow issue.New:
– New style QIS.
– New schedular design for Parental Control.
– Instant Guard.Bug Fixed and Improvement:
– Fixed AiMesh issues.
– Enhanced Speedtest.
– Disabled EEE by default.
– Updated USB Modem APN data.
– Updated miniupnpd to 2.2.0.
– Enhanced bufferbloat issue for Traditional QoS and Bandwidth Limiter.
– Updated DSL PHY to A2pv6L046w.027l.
– Fixed TrendMicro module stack issue
– Updated Tuxera module.
– Enhanced jffs filesystem occupied by icon file with some Netgear AP in LAN.
– Fixed sometimes cannot identify the “Seagate Expansion” disk.
– Added usb modem D-Link DWM-222 and ZTE MF821 support.
– Added FEC, ES, SES and fixed CRC of DSL Line Stats.
– Fixed Let’s Encrypt issue.
– Fixed DSL WAN settings can not be restored.
– Enhanced speed while click “Edit” WAN PVC.– Fixed aaews memory leak issue.
April 25, 2021 at 6:52 am #12954What is your ‘disable nat tunnel’ set to ? as aaews is associated with the ASUS NAT TUNNEL I believe ?
April 25, 2021 at 7:08 am #12955Yes I’m on the latest firmware, after switching on it has about 280MB and after 6-7 hours it reaches 291 , but sorry I switch it off for the night and when I go to work, I don’t like leaving it on for all day, maybe memory leak stops on 290-300 that’s why I’m not too bothered to much, just wanted to point out.
April 25, 2021 at 7:14 am #12956April 25, 2021 at 7:39 am #12957[quote quote=12941]Good to hear, where did you get the DSL-AX82U from @trainzer? I see amazon UK have now changed to 1 – 2 months delivery…. earliest dates are now in May it seems. Thanks Kev[/quote]
Amazon UK. I ordered it at the beginning of April when it was saying temporarily out of stock. It was a nice surprise to get it this week.You need to login in order to vote
April 25, 2021 at 7:58 am #12959[quote quote=12947]I’ve noticed some small memory leak about 9-10MB per every 6 hours, has everyone with DSL-AX82U experienced this too ?[/quote]
Did notice memory increase after some hours, but nothing else since.On mine it’s currently 77%-78% memory utilisation and its been like that at least in the past 12 hours.
April 25, 2021 at 9:56 am #12967 -
