Viewing 15 posts - 91 through 105 (of 714 total)
  • #12866
    How has the unit been so far @El3rt1cal? Are you running it as it came from ASUS or loaded Merlin on it?
    I’m tempted to by one but a little weary due to the usual teething problems until its been out a while :)
    • Replies 8,739
    [quote quote=12865]Tekshop247.com I used Pricespy when @wizard1’s post suggested they might be released here soon. There were about 5 sellers at the time. Yes, the DSL-AC88U had promise with the move to a Broadcom chipset, pity it did not work out. I hope (and expect) this will be different. It is particularly good to see GNUton making Merlin available on this one.[/quote]
    #12870
    • Replies 8,739
    [quote quote=12864]Would be interested to know when brought from :) Does the DSL-AX82U also work with a external modem i.e. can turn off inbuilt one? If so, this maybe the best option for me at present, use inbuilt modem and then if I ever go FTTP, turn inbuilt modem off and plug cable from FTTP modem into the wan port? Need to look at some more reviews but I’m thinking this maybe be simplest option at present and by the time FTTP becomes affordable, might be time for a new router anyway :) Thanks Kev[/quote]
    The DSl-AX82U has a dedicated WAN port, so can be used with an external modem
    Video of myself unboxing the DSL-AX82U
    #12871
    Thanks, think i might go for this one.  Anyone had any issues with the DSL-AX82U when running on the default firmware?  Is it good to buy now or are there some bugs that need fixing so should wait?
    • Replies 8,739
    [quote quote=12871]Thanks, think i might go for this one. Anyone had any issues with the DSL-AX82U when running on the default firmware? Is it good to buy now or are there some bugs that need fixing so should wait? Kev[/quote]
    No official firmware actually exists for the DSL-AX82U, only beta’s :- https://www.asus.com/Networking-IoT-Servers/Modem-Routers/All-series/DSL-AX82U/HelpDesk_Download/
    So early days yet for firmware, but the more feedback forms ASUS receive the earlier they can fix the bugs, think of it as an investment and if you do purchase from outside the UK, make sure it has a suitable UK power plug
    #12873
    Reason for potentially going with the AX82U is the RT-AX86U seems unavailable at most places with reasonable prices and the DSL-AX82U would still be usable if went FTTP due to WAN port.  Also means I don’t have to worry about getting an adapter so I can plug in 2 devices as only have 1 socket available where router is.  Also works out cheaper than getting the AX86U + Vigor 130.
    • Replies 8,739
    It would, Enjoy your new DSL-AX82U
    #12875
    Will buy from the UK for reasons of ensuring getting the UK plug and also in case of returns and not having to deal with any customs stuff :)
    Has your DSL-AX82U been ok so far on default router out of the box or are there some issues I should be aware of?  Top priority is getting a decent connection and not one that drops out a few times each day randomly like it does at present.
    • Replies 8,739
    Alas, the information I pass to ASUS during testing I cannot divulge publicly, hopefully others can advise
    #12878
    sure thanks, hopefully someone can advise if connection has been stable :)
    Avatarvitt13
    • Replies 46
    Hi, I have the noisiest dsl line in my neighborhood and with my previous dsl modem FritzBox 7530 I was having reboot after reboot sometimes 10 times or more every evening, but with DSL-AX82U NOT A SINGLE DROP in connection, its Broadcom chip makes it very stable the same with my mum’s DSL-AC68VG just working 24/7, I recommend this modem.
    #12880
    • Replies 8,739
    [quote quote=12879]Hi, I have the noisiest dsl line in my neighborhood and with my previous dsl modem FritzBox 7530 I was having reboot after reboot sometimes 10 times or more every evening, but with DSL-AX82U NOT A SINGLE DROP in connection, its Broadcom chip makes it very stable the same with my mum’s DSL-AC68VG just working 24/7, I recommend this modem.[/quote]
    The original Fritz!box 7530 uses the Qualcomm (Dakota) chipset for its modem, good to know the DSL-AX82U with its Broadcom DSL chipset is working well ans stable
    #12884
    Thanks, I just been looking at current BT router event log, it seems connection dropped at around 1am, 8am, 9am, 10:45am so far today so seem it dropped out every hour or two mostly, ignoring the 1am as this maybe when BT dropped the connection.  Fortunately it comes back on its own but takes a short while but rather annoying to say the least.
    Going to see if more reviews of the DSL-AX82U from users having one and then might place a order for one, i never heard of those online stores before though, usually buy from ebuyer etc.
    • Replies 8,739
    Amazon are taking pre-orders for the DSL-AX82U for £199.99 – Stock available in June.
    https://www.amazon.co.uk/s?k=asus+dsl-ax82u&ref=nb_sb_noss_1
    #12886
    Which firmware version of 7530 do you use? Did you try to use old (previous) DSL-driver? That often helps.
    Not all drivers work well with all lines and remote systems or their firmwares.
