robgbc.
June 15, 2022 at 7:34 pm #19225
Lost connection but after nearly 4 days, so better than official. Whatever the issue, it is also present in 386.07.
I will turn off ‘Web and App Filters’ and try again in the next official FW.
Not currently using the extra features.
I only use it to give access to USB-HDD, nothing much.
June 15, 2022 at 8:31 pm #19233Does sound simular – thanks for feedback and good to see @GNUtons work is still worth a consideration for ASUSWRT-Merlin value add
August 4, 2022 at 9:15 am #20447ASUS ZenWiFi AX (XT8) Firmware version 3.0.0.4.386.49873
1. Fixed CVE-2018-1160 Thanks to Steven Sroba
2. Fixed anomalous 802.11 frame issues.
Thanks to Kari Hulkko and Tuomo Untinen from The Synopsys Cybersecurity Research Center (CyRC). Issue was found by using Defensics Fuzz Testing Tool.
3. Improved system stability.
4. Supported Safe Browsing in the router app to filter explicit content from search results. You can set it in the router app –> Devices or Family.Please unzip the firmware file first then check the MD5 code.
MD5: 30eead8d89b9bb990604e568b53dced4https://dlcdnets.asus.com/pub/ASUS/wireless/ZenWiFi_XT8/FW_ZENWIFI_XT8_300438649873.zip
August 4, 2022 at 9:46 am #20448[quote quote=20447]ASUS ZenWiFi AX (XT8) Firmware version 3.0.0.4.386.49873[/quote]
Any volunteers
August 4, 2022 at 10:02 am #20450I’ve updated and will see how it goes, or more likely my wife will!
August 4, 2022 at 10:23 am #20451[quote quote=20450]I’ve updated and will see how it goes, or more likely my wife will![/quote]
Will be great to see how you get on with the latest FW.
I have been using Gnuton’s Merlin builds for the past month or so. Currently on build 386.07_2.
https://github.com/gnuton/asuswrt-merlin.ng/releases
August 4, 2022 at 2:30 pm #20452[quote quote=20450]I’ve updated and will see how it goes, or more likely my wife will![/quote]
August 5, 2022 at 12:50 pm #20469upgraded to ASUS ZenWiFi AX (XT8) Firmware version 3.0.0.4.386.49873.
no issues until now : everything working with teams, rdp-sessions, remote working with vpn, video streaming.
August 5, 2022 at 12:56 pm #20470[quote quote=20469]upgraded to ASUS ZenWiFi AX (XT8) Firmware version 3.0.0.4.386.49873. no issues until now : everything working with teams, rdp-sessions, remote working with vpn, video streaming.[/quote]
Great news, thanks for sharing
August 5, 2022 at 7:52 pm #20472I downloaded the latest update yesterday and so far everything has been working fine from teams video and calls VPN no issues let’s hope it stays that way.
August 5, 2022 at 8:03 pm #20474[quote quote=20472]I downloaded the latest update yesterday and so far everything has been working fine from teams video and calls VPN no issues let’s hope it stays that way.[/quote]
Indeed, 2 out of 2 positive feedbacks, sounds like ASUS are still working there magic with there latest firmware offering for the ASUS ZenWiFi AX (XT8)
August 5, 2022 at 10:34 pm #20475[quote quote=20474]Indeed, 2 out of 2 positive feedbacks, sounds like ASUS are still working there magic with there latest firmware offering for the ASUS ZenWiFi AX (XT8)
[/quote]Asus seem to have upped their game with the new FW releases on the XT8. Refreshing to see after all the previous issues. Well done to you all that sent their logs with their Teams issues.
August 6, 2022 at 12:41 am #20478[quote quote=20475]
<noscript>
</noscript>Asus seem to have upped their game with the new FW releases on the XT8. Refreshing to see after all the previous issues. Well done to you all that sent their logs with their Teams issues.[/quote]
Can’t say I’ve noticed any issues with the latest update, and it seems that for a while now things have settled down. That isn’t to say I don’t still get the odd occasion where the mesh node drops to 2.4GHz Wi-Fi and sticks there. No amount of optimising or even rebooting fixes – but usually a physical flick of the power switch solves it.
That’s, thankfully, rare. I have no idea why it does it – or if Asus could ever fix it, but I’ll live with it.
What does seem to be more of a problem is that when I’ve forced 160MHz, it can sometimes not connect at all. I’ve tried 160MHz only, which can cause it not to work. So I then do 20/40/80/160 which also seems to make it use just 80MHz.
Currently it’s on 80MHz but with the 160MHz box ticked, and I am not even sure that’s a valid setting – and in any case, it’s connected at 80MHz.
Basically, I’ve pretty much accepted that despite a near perfect signal, it doesn’t like using 160MHz on the backhaul. It’s not even showing as an issue with radar (I’m not a million miles away from an airport) and just decides to sync at 80MHz. I guess it will remain like the 2.4GHz problem – something that will always be there.
Perhaps doing another reset and restoring settings will fix it, but I can’t be bothered anymore as I think I just want stability. As I’m mostly near the main router, I still get the full speed and my wife/son who use the node (when she’s working from home, or my son is on his Xbox) aren’t so worried about max speed. My son’s Xbox rarely downloads any games at anywhere near my maximum Internet speed anyway – which seems a limitation of their servers.
The important thing is that my wife hasn’t had any issues relating to her work, my son can still play online games, and everything else ‘just works’. There are no ongoing monthly fees like other routers, so I’m sure when the time comes to upgrade (no obvious need anytime soon) I’d almost certainly buy another Asus product, most likely Wi-Fi 6E or more likely wait for Wi-Fi 7.
August 6, 2022 at 2:09 am #20480I will also wait till Wi-Fi 7 ZenWifi is released as my current units work really well now. Asus FW on the XT8 have worked amazingly for me since Jan/Feb 22 releases.
Not sure why your mesh does not connect to 160MHz. I just set channel bandwidth to 160MHz and it it finds and connects to channel 100. Haven’t noticed it change at all for a long time. Might be worth you trying a factory reset over the weekend?
August 6, 2022 at 6:35 am #20481[quote quote=20480]I will also wait till Wi-Fi 7 ZenWifi is released as my current units work really well now. Asus FW on the XT8 have worked amazingly for me since Jan/Feb 22 releases. Not sure why your mesh does not connect to 160MHz. I just set channel bandwidth to 160MHz and it it finds and connects to channel 100. Haven’t noticed it change at all for a long time. Might be worth you trying a factory reset over the weekend?[/quote]
I don’t know why it doesn’t work. Maybe it is down to radar detection, and perhaps I can try again and see if I have any more luck – but even when I’ve managed to see it on 160MHz for a while and thought ‘success!’ it has dropped back later on by itself.
I am loathe to force it to 160MHz as that will probably also cause it to drop to 2.4GHz or lose connection entirely.
The one thing I wish it would do is attempt to ‘retrain’ at regular intervals. Previously I just set the system to reboot every morning, but that causes my USB connected flash drive to disconnect.
Nevertheless, I am happy enough with the overall performance and stability.
