Viewing 15 posts - 961 through 975 (of 1,411 total)
  • #23056
    • Replies 8,458
    Oh ok, so instead of selecting 20,40,80mhz. I just choose 80mhz only? Also unclick auto channel dfs?
    Yes, Firmware 22525 is good, but still a little buggy with AiMesh Wifi backhaul stability
    #23057
    • Replies 617
    So sorry for the mix up. Yes, itโ€™s Asus zenwifi AX XT8. Oh ok, so instead of selecting 20,40,80mhz. I just choose 80mhz only? Also unclick auto channel dfs? thanks a lot! Will try these! More power to you! Great help!
    It really also depends on your location and RADAR detection in your area.ย  For me, on 22525 I just set it to 160MHz and it hasn’t had any major issues in 32-33 days uptime.ย  In previous 388.xxxxx FW the wireless backhaul lost connection after 5-7 days for me.
    Jaime Salud CastilloJaime Salud Castillo
    • Replies 36
    Nice. I have an option to use 160mhz solo too? Great! If this current 80mhz setup fails, iโ€™ll try your suggestion. Thanks a lot!
    robgbcrobgbc
    • Replies 38
    Experiencing the same loss of connectivity as before with 3.0.0.4.388_22525
    Very strange, I can access the router via IP address but not http://www.asusrouter.com
    I can ping IP addresses from the router network tools, but cannot connect to any web pages from wired or wireless devices.
    I can still surf normally through my connected VPN, but if I disconnect the VPN, it will not reconnect and if I disconnect from wired or wireless connection, devices will not reconnect.
    Nothing unusual leading up to the loss of connectivity event.
    It seems like DNS and DHCP are crashing, but nothing at all in the logs.
    Power cycle resolves.
    • Replies 8,458
    That is most odd, can you send a feedback form and mention in comments box ‘UK Sentinel’ I can then touch base with ASUS and ask them to have a look
    #23289
    AvatarNicky
    • Replies 57
    This is a first for me.
    I saw this in the system logs, can anyone tell me what’s going on here please?
    Mar 22 02:20:34 kernel: CPU: 2 PID: 1765 Comm: asd Tainted: P O 4.1.52 #2
    Mar 22 02:20:34 kernel: Hardware name: Generic DT based system
    Mar 22 02:20:34 kernel: task: d91b8400 ti: d19b0000 task.ti: d19b0000
    Mar 22 02:20:34 kernel: PC is at 0xb6902ec0
    Mar 22 02:20:34 kernel: LR is at 0xb6903bb0
    Mar 22 02:20:34 kernel: pc : [<b6902ec0>] lr : [<b6903bb0>] psr: 80000010
    Mar 22 02:20:34 kernel: sp : beeb1340 ip : b6917150 fp : b69061f8
    Mar 22 02:20:34 kernel: r10: 00024164 r9 : b69060c0 r8 : 00000000
    Mar 22 02:20:34 kernel: r7 : 0171cb40 r6 : 0171c9c0 r5 : beeb1360 r4 : 017202c0
    Mar 22 02:20:34 kernel: r3 : b65016c8 r2 : 00000000 r1 : 00000080 r0 : 00000000
    Mar 22 02:20:34 kernel: Flags: Nzcv IRQs on FIQs on Mode USER_32 ISA ARM Segment user
    Mar 22 02:20:34 kernel: Control: 10c5387d Table: 118ac04a DAC: 00000015
    Mar 22 02:20:34 kernel: [<c00270a0>] (unwind_backtrace) from [<c0022cf8>] (show_stack+0x10/0x14)
    Mar 22 02:20:34 kernel: [<c0022cf8>] (show_stack) from [<c04c76bc>] (dump_stack+0x8c/0xa0)
    Mar 22 02:20:34 kernel: [<c04c76bc>] (dump_stack) from [<c003ad2c>] (get_signal+0x490/0x558)
    Mar 22 02:20:34 kernel: [<c003ad2c>] (get_signal) from [<c0022290>] (do_signal+0xc8/0x3ac)
    Mar 22 02:20:34 kernel: [<c0022290>] (do_signal) from [<c0022718>] (do_work_pending+0x94/0xa4)
    Mar 22 02:20:34 kernel: [<c0022718>] (do_work_pending) from [<c001f58c>] (work_pending+0xc/0x20)
    Mar 22 02:25:59 rc_service: service 20703:notify_rc restart_firewall
    • Replies 8,458
    Lots going on in that log, are any of the cores or RAM ย maxing out ?
    Alas I am in London for a couple of days but ย  Will have a proper look when I get back
    #23291
    AvatarNicky
    • Replies 57
    Thank you.
    I’m not aware of anything maxing out. I’ve attached a screenshot of the current status.
    • Replies 617
    Your free ram seems very low compared to mine.ย  Mine has never gone below 150MB free
    • Replies 617
    You are around my neck of the woods UK Sentinel.ย  Welcome to London…….
    AvatarNicky
    • Replies 57
    Mine is normally around 118MB, It maybe because I have around 72 devices connected, most of which are just IoT devices?
    • Replies 8,458
    You are around my neck of the woods UK Sentinel. Welcome to Londonโ€ฆโ€ฆ.
    Theatre with my good wife for Moulin Rouge ;)
    #23298
    • Replies 617
    Is that at the Piccadilly Theatre?ย  I work nearby in Victoria Street.
    Hope you enjoyed the theatre.ย  There are some lovely eateries in Denman Street.ย  Very expensive though.
    • Replies 617
    That is probably why your free RAM is lower than mine from the start.ย  Hopefully UK Sentinel can help explain the logs when he is back.
    • Replies 8,458
    Is that at the Piccadilly Theatre? I work nearby in Victoria Street. Hope you enjoyed the theatre. There are some lovely eateries in Denman Street. Very expensive though.
    Small world, Yes Piccadilly Theatre, great show and ofto Marriot to check in. Luckily London is like a second home to me, so lots of eateries etc, ;)
Close โœ–
Search forums
Advanced forum search
Back to basic search
