› UKTH forums › ๐ Wireless Routers & Modems › ASUS & Wireless › ASUS ZenWiFi AX Whole Home Tri-Band Mesh WiFi 6 System Not sure if this is the right place to ask…. I am thinking of upgrading my Google Mesh wifi to the above.ย Has anyone used this and does it...
- This topic has 1,410 replies, 25 voices, and was last updated 2 months, 4 weeks ago by
- February 26, 2025 at 6:46 pm #35735March 18, 2025 at 11:03 pm #36039
It looks like a new firmware upgrade is rolling out.
Firmware version 3.0.0.4.388_24709
– Release Note –New Add:
– WPA Encryption Settings Update. Added new configuration options for WPA encryption, including the option to select AES for improved client compatibility.
This setting can be found under “Network > Main Network”.Bug Fixes and Enhancements:
– Addressed potential irregularities in AiProtection.
– Corrected the issue where the wireless network settings page disappears in AP mode on the WebGUI.
– Enhanced AiCloud password protection mechanisms, safeguarding against unauthorized access attempts.
– Enhanced input parameter handling techniques to improve data processing stability and system security.
– Enhance system access control mechanisms.
– Enhanced security of system command processing to guard against potential malicious operations.
– Fixed compatibility issues with older models, preventing WiFi malfunctions after SDN settings.
– Fixed connectivity issue with Apple wireless devices.
– Fixed an issue that could lead to system failures following a reboot.
– Fixed the malfunction of the “Prefer AP” feature.
– Fixed the issue where devices do not appear in the client list after connecting to the ASUS router.
– Fixed UI issues during VPN file export.
– Improved AiMesh backhaul stability.
– Improved web rendering engine, enhancing browsing experience and security.
– Optimized memory management mechanisms, improving system efficiency and stability.
– Optimized stability and efficiency of the AiMesh system.
– Perfected JavaScript-related security mechanisms, offering a more secure web interaction environment.
– Resolved LAN device disconnections after SDN configuration.
– Strengthened input validation and data processing workflows, further protecting your information security.You need to login in order to vote
March 19, 2025 at 7:02 am #36040Great news and thank you for sharing
FWIW: some of the newer firmware releases across a range of ASUS routers are causing issues with IOT devices not reconnecting after upgrade, seems newer firmwares are changing Authentication Method to โWPA2/WPA3-Personalโ for all Wi-Fi bands rather than what they where set to previously.
March 19, 2025 at 9:49 pm #36076March 19, 2025 at 10:07 pm #36079Do you have Adaptive QOS is enabled as I believe it is associated ?
March 19, 2025 at 10:16 pm #36080March 20, 2025 at 7:35 am #36081Shoots that easy theory out the window
The log message is telling us that the “lighttpd” command has crashed.
Lighttpd is a lightweight and efficient web server that is configured on ASUS routers running AiCloud I believe.
It does seem to be happening a lot looking at your logs and is a fairly common problem, have you noticed any changes, are you using AiCloud ?
March 20, 2025 at 8:50 am #36082I tried logging in via AiCloud and it wouldn’t let me in with my credentials, so I deregistered and re-registered successfully with a new DDNS name. The top box under Network Map is showing “Internet Status Connected” with the newly registered DDNS name and the Let’s Encrypt Server Certificate showing as Active (with the same DDNS name), but when I try to login via the web browser I get the “Hmmmโฆ can’t reach this page” ?
March 20, 2025 at 8:54 am #36083I’ve just power cycled the router and I now have web access via the DDNS, but it’s not accepting my login credentials.
March 20, 2025 at 10:12 am #36084Try a second Power Cycle, was you using AiCloud before the firmware upgrade ?-
This reply was modified 1 year ago by
UK Sentinel. Reason: added strikethrough
March 20, 2025 at 3:42 pm #36090I have just rebooted my Virgin Media MoDem and it looks as if that’s fixed the connection issue, but I’m still getting the ย lighttpd Tainted reported in the system log.
March 20, 2025 at 3:46 pm #36091Great news, was you using AiCloud / DDNS before the firmware upgrade ?
Being cheeky, is it possible to disable DDNS and/or AiCloud to see if lighttpd Tainted error messages remains ?
In reality, as long as these services are working and you are not experiencing any issues, it is an issue only ASUS can fix and I can then let them know.
March 20, 2025 at 10:34 pm #36147Sorry I should have given you a straight answer before. No I hadn’t used AiCloud / DDNS before the firmware upgrade, but I had noticed the lighttpd Tainted error messages in previous versions, but didn’t really take much notice because they were very few and far between. However, since this upgrade, my system log has been full of them, there are over 100 occurrences in the log since 09:00 this morning.
I’ll disable the DDNS and AiCloud, clear the system log and get back to you with the results.
March 21, 2025 at 8:10 am #36148Good news so far. I disabled my AiCloud but left the DDNS enabled and I’ve not had one lighttpd Tainted error message yet.
March 21, 2025 at 6:50 pm #36150 -
