Viewing 15 posts - 1,381 through 1,395 (of 1,411 total)
  • #39010
    AvatarNicky
    • Replies 57
    I’ll be biting the bullet this weekend. I’ll let you know how it goes๐Ÿคž
    AvatarNicky
    • Replies 57
    . UK Sentinel Said:
    You might need something a little stronger
    I think @Grisu mentioned something similar above, might be worth you taking a backup copy of your current config, then upgrade to new firmware and then take a backup of the new config.
    Then factory reset and apply latest backup config, reboot and see how that goes ?
    might save some time and let us know if this work ?
    As an interesting thought, if you had โ€œauto updateโ€ enabled on your XT8โ€™s, I assume this would have updated your XT8โ€™s automatically and by passed the factory reset advise given in the changelog
    Well the deed has been done. Just one bottle of beer and noting in the swear box. All the iMesh nodes are there, all the devices have connected with their correct IP addresses and the routes are intact. Let’s see how things go.
    I just need to register the AUSU cert for the https://ย  login, but that can wait.
    • Replies 8,458
    Congrats, did you dirty flash or rebuild from scratch ?
    #39025
    AvatarNicky
    • Replies 57
    I did a dirty upgrade using the method both you and @Grisuย  mentioned.
    One thing I have noticed though, before I upgraded I got the “The router cannot connect to ASUS server to check for the firmware update. Please download the latest firmware from ASUS Product Support Site and do manually upgrade.ย Check onย FAQ for more instructions.” message, so I downloaded it using the link in one of the previous posts and I am still getting it with this version. I’m also getting “Signature update failed.”?
    • This reply was modified 7 months, 3 weeks ago by AvatarNicky.
    #39027
    • Replies 8,458
    The โ€œSignature update failedโ€ error on the Asus router relates I think it relates to the Trend Micro security components (like AiProtection or parental controls).
    Could be a few reasons, is the Routers time set correctly for your region and Trend Micro Signatures issues is fairly common.
    Edit: Forget to say, Go to Advanced Settings > Administration > Firmware Upgrade and scroll down to Firmware Version and see if there is an update for Trend.
    #39028
    AvatarNicky
    • Replies 57
    The Time and date are correct and I’m not seeing any updates for Trend. I did disable “AiProtection” and reenabled it, now I’m not getting the โ€œThe router cannot connect to ASUS server …” error and it’s telling me that the firmware is up to date on my Mesh devises.
    But I’m still getting the โ€œSignature update failed.โ€ message. It will be interesting to see if anyone else is having issues with the Signature update?
    I also had four devices not reconnect to the network via WiFi (2G & 5G), so I rebooted them and all OK now.
    AvatarNicky
    • Replies 57
    Well it’s been 33 hours and no further issues other than someone trying to log in to the router, so I’ve disabled Web access from WAN, which must have been turned on when I upgraded.
    • Replies 8,458
    Great news, has you Wifi and LAN speeds remanded good as I have seen online that some did have issues with speeds decreased until they did a factory reset.
    Web access from WAN enabled on upgrade, that’s not good especially if your not using the App.
    #39033
    AvatarNicky
    • Replies 57
    Web access from WAN enabled on upgrade, thatโ€™s not good especially if your not using the App.
    I don’t know if Web access gets turned on by default by the upgrade, but it was strange it was on after?
    I’ve done the speed checks on both the WAN & LAN and I’m not seeing any speed drops.
    Also, the Signature updated this morning
    #39035
    • Replies 8,458
    Time to buy a lottery ticket with the good fortune you are having
    #39134
    Avatarmaggiemay
    • Replies 6
    Hello, where do I check ifย  “Web access from WAN” is enabled?ย  Thanks!
    • Replies 8,458
    On your ASUS XT8, login via your browser and …
    • Go to Administration
      • From the left-hand menu, select Administration.
    • Find System tab
      • Inside Administration, click the System tab.
    • Check โ€œEnable Web Access from WANโ€
      • Look for the option โ€œEnable Web Access from WANโ€ (sometimes just โ€œEnable Web Access from WAN (HTTP/HTTPS)โ€).
      • If itโ€™s Enabled, that means your routerโ€™s web interface is accessible externally (not recommended unless you use strong security).
    #39140
    Avatarmaggiemay
    • Replies 6
    I don’t have a “Remote Acess Config” box under Administration–>System.ย  Is this because my XT8 operates in AP mode?ย  Thanks again.
    • This reply was modified 7 months, 2 weeks ago by Avatarmaggiemay.
    #39142
    • Replies 8,458
    Exactly, In AP mode I believe youโ€™ll only see settings related to LAN, Wi-Fi, and system administration etc.
    #39348
    AvatarNicky
    • Replies 57
    Well today was not a good day. 2Ghz devises started to randomly disappear and reappear from my network. I rebooted the whole system, No change. I reinstalled the latest firmware, done a factory reset, reinstalled the CFG file and within minutes it started to happen all over again. So I’ve had to regress back to FW_ZENWIFI_XT8_300438824710 and I’ve had no issues for the past 12 hours.
    I know I should have pulled the logs, but I forgot too, I was so focused on getting the system back up and running. I’ll try again when I get a moment.
Close โœ–
Search forums
Advanced forum search
Back to basic search
