Viewing 15 posts - 136 through 150 (of 1,130 total)
  • #5223
    • Replies 8,718
    [quote quote=5220]I am using n16 with 5.5.2.11 too much crc errors and bad stability. 5.9.2.23 much better. It would be great if you could report it to Asus[/quote]
    DSL-N16 uses the MediaTek MT7510 DSL chipset so different from Zyxel DSL chipset, but will advise you are having issues with 5.5.2.11 ;-)
    Maybe also send ASUS a feedback form as they may help you with CRC errors
    #5224
    Avatarkamiboy
    • Replies 32
    Do not use ASUS as modem only use it as router . bridge your zyxel to dsl-n16
    #5226
    • Replies 8,718
    [quote quote=5224]
    Do not use ASUS as modem only use it as router . bridge your zyxel to dsl-n16 [/quote]
    Good idea
    #5228
    Avatarjonathan
    • Replies 11
    zyxel’s software is insufficient. Asus is better on this but mediatek chipset have a chronic problem with Broadcom dslam. I hope they solve the problem with new xdsl drivers.
    #5230
    • Replies 8,718
    [quote quote=5228]zyxel’s software is insufficient. Asus is better on this but mediatek chipset have a chronic problem with Broadcom dslam. I hope they solve the problem with new xdsl drivers.[/quote]
    ASUS do not often update xDSL drivers for the MediaTeK range, have you tried an older ASUS DSL-N16 firmware, are CRC errors still the same?
    #5231
    Avatarjonathan
    • Replies 11
    there are many old firmwares. I don’t know (remember) which might be the best. Do you have advice?
    #5232
    • Replies 8,718
    [quote quote=5231]there are many old firmwares. I don’t know (remember) which might be the best. Do you have advice?[/quote]
    Try Version 1.1.2.3_552  as they updated DSL Driver about three times after, so a good midway firmware point just to see if CRC errors are still showing
    #5233
    Avatarlostcause
    • Replies 53
    People with many CRC errors, are you on;
    • ADSL or VDSL ?
    • Uncapped line or not ?
    • Interleaved or Fast Path ?
    • G.INP available ?
    • G.vector enabled (VDSL) ?
    All these things matter a lot in line noise reduction. Not the dslam brand, infineon/ broadcom.
    Post your System Log – DSL Log Line stats here if you think it will help.
    #5235
    • Replies 8,718
    With the MediaTeK DSL chipsets, usually they struggle on long lines (VDSL) with  an attenuation over 35 dB and can be noisy also.
    #5241
    Avatarjonathan
    • Replies 11
    1.1.2.3_552 I tried all day did not change. snr margin fixed, only downstream crc increasing. 17a profile no g.inp and vector.
    #5242
    • Replies 8,718
    [quote quote=5241]1.1.2.3_552 I tried all day did not change. snr margin fixed, only downstream crc increasing. 17a profile no g.inp and vector.[/quote]
    Shame, What is your attenuation value ?
    #5249
    Avatarjonathan
    • Replies 11
    14.1 dB CRC seems to have stopped increasing. Let’s see how long it takes. I think there is another factor that makes interference.
    #5250
    • Replies 8,718
    [quote quote=5249]14.1 dB now seems to have improved. I think there is another factor that makes interference.[/quote]
    14dB is very good, so interesting you have high CRC’s
    #5252
    Avatarjonathan
    • Replies 11
    my snr margin is usually 5.9
    #5261
    Avatarlostcause
    • Replies 53
    If your ISP did not implement modern techniques like G.INP and.or vectoring you should be on an interleaved profile.
    System Log – DSL Log –> Path Mode
    If you’re not on interleaved but on Fast Path () you need to reduce your line speed by increasing SNR Margin or call the ISP to check your line for interference or ask to be put on interleaved which causes additional latency unfortunately.
    Goto  Administration – DSL Setting – VDSL settings –> Stability Adjustment
    Start with 7 dB and work up to get your line more stable.
    for ADSL
    Goto  Administration – DSL Setting – common settings –> disable Dynamic Line Adjustment (DLA)
    ADSL settings –> Stability Adjustment
