Viewing 15 posts - 166 through 180 (of 1,130 total)
  • #5600
    • Replies 8,718
    [quote quote=5598]
    Well spotted, hopefully will be suitable for @jonathan changelog = alas no DSL driver update Version 1.1.2.3_805 2019/12/279.36 MBytesASUS DSL-N16 Firmware version v1.1.2.3_805 (This product supports both Annex A and Annex B) Bug fixes and enhancements: – Now supports Feedback > 12 hours Diagnostic xDSL debug log capture feature for non-USB supported models. – Feedback > WiFi Diagnostic feature change log file name to “WiFi.log” instead of “TCC.log”. xDSL Diagnostic log remains to be “TCC.log”. – Fixed VPN settings > username/password, if special character “.” used leads to connectivity issue problem. – Fine tuned Feedback feature. – Fixed various Web UI related issues. – Fine tuned OpenVPN Web UI. Security: – Enhanced Security for specific Malware/Malicious Script protection.
    just a minor update, main issues still persists. high CRC errors and l2tp vpn problem.[/quote]
    #5772
    Avatarboyelroy
    • Replies 10
    dsl-ac51
    vpn connection error: “write UDP: Invalid argument (code=22)”
    ??? why…
    #5775
    • Replies 8,718
    [quote quote=5772]dsl-ac51 Firmware version v1.1.2.3_805 vpn connection error: “write UDP: Invalid argument (code=22)” ??? why…[/quote]
    Did this problem happen with Firmware – Version 1.1.2.3_790 , if No then maybe try factory reset and see if issue remains
    Firmware version v1.1.2.3_805 is a very ne release, hopefully not buggy
    #5779
    Avatarboyelroy
    • Replies 10
    Problem solved.
    v1.1.2.3_805 – after facory reset problem still present, flashing v1.1.2.3_743 and add vpn profile, problem is gone, and finally update to v1.1.2.3_805 and everything is ok.
    #5780
    • Replies 8,718
    [quote quote=5779]Problem solved. v1.1.2.3_805 – after facory reset problem still present, flashing v1.1.2.3_743 and add vpn profile, problem is gone, and finally update to v1.1.2.3_805 and everything is ok.[/quote]
    Good news and thanks for letting us know
    #5781
    Mike
    • Replies 3
    So came to this after trying to get my old dsl-n66u back up and running, with the original firmware I get HR faults introduced on the line, so thought the beta firmware might resolve it?
    I’m currenty on the v9.1.2.3_743, but for the 783/790/805 seems the DSL-n66u has been dropped?
    I did see the direct link for 783 on post https://uktechhub.com/forums/topic/latest-dsl-asuswrt-firmware-v9-1-2-3_502-g2bdb05b-now-available/page/7/#post-4641
    But that appears to have been removed?
    Is 743 the last firmware available for the dsl-n66u??
    #5782
    • Replies 8,718
    Basically, the DSL-N66U has reached is end of life, ASUS kindly provided unofficial updates beyond EOL but as they received a complaint about EOL Firmware, with no support, they (ASUS) have withdrawn all previously released DSL-N66U Firmware’s beyond DSL-N66U_v9.1.2.3_707-g524aadd – DSL-N66U_v9.1.2.3_743-gf5b4545
    https://www.asuswebstorage.com/navigate/a/#/s/BDE1E747AA8341BFB1BA6EF4FC290597Y
    https://www.asuswebstorage.com/navigate/a/#/s/9A11A78AD414465B853617379C50D180Y
    So the version you are currently running is the latest and no newer firmwares are available for download via ASUS
    ASUS did release DSL-N66U firmware’s 783/790 so hopefully somebody else downloaded before they where removed, if so hopefully they can share or drop me an email and I can share via Forum Direct link etc
    #5784
    Mike
    • Replies 3
    • Replies 8,718
    My apologies, I missed that one, the version 743 is newer, so should be more stable
    (I will amend above notes to capture this later firmware)
    #5800
    Avatarlostcause
    • Replies 53
    Firmware version 1.1.2.3_805 now also online for the AC51 and AC52U.
    https://www.asus.com/Networking/DSL-AC52U/HelpDesk_BIOS/
    https://www.asus.com/Networking/DSL-AC51/HelpDesk_BIOS/
    I’m still on beta_rev708fa due to the 5G Off boot issue….
    #5804
    • Replies 8,718
    • Replies 8,718
    Forum Member @Jani has kindly shared with myself two Recent firmwares for the DSL-N66U (many thanks)
    DSL-N66U_9.1.2.3_783-g4cb10eb.trx
    DSL-N66U_v9.1.2.3_790-g61d41b5.trx
    “These files have been virus checked via myself, but UKTechHub.com has not liability for these firmware’s and there usage”
    DSL-N66U_9.1.2.3_783-g4cb10eb.trx – [download id="5810"]
    DSL-N66U_v9.1.2.3_790-g61d41b5.trx – [download id="5818"]
    #5833
    Mike
    • Replies 3
    @Jani thank you kindly.
    #5843
    AvatarBAXdinos
    • Replies 1
    When I try to update my ac51 to 1.1.2.3_805 it says that the firmware is invalid. And I try to update it straight from ASUSwrt
    #5844
    Avatarlostcause
    • Replies 53
    [quote quote=5843]When I try to update my ac51 to 1.1.2.3_805 it says that the firmware is invalid. And I try to update it straight from ASUSwrt[/quote]
    Went on fine on my AC51. Downloaded the file from the link a few posts back.
    DSL-AC51_1.1.2.3_805-gadd8a2b.trx MD5 hash: D99341ACA5898FC50CE3C91054819399
