- This topic has 717 replies, 4 voices, and was last updated 6 years, 1 month ago by
Bully.
April 25, 2020 at 6:36 pm #6713
Downstream rate = 39709 Kbps =
“your downstream SNR reduced from 8 to 6” which is good
April 25, 2020 at 6:42 pm #6714April 25, 2020 at 8:48 pm #6718That strange, it looks like DLM did resync during the day which is not common. However it’s looking good as your line is nod banded so far, so things moving right direction 👍
April 26, 2020 at 6:54 am #6719After I look closer I see that your card (in DLM) is on different fw than mime, that’s explain sync during the daytime. To see better differences I put zyxel on my line, and the thing which I realised straight away is bitswap, on yours is in thousands on downstream where mine looks like that
Bitswap 18/18 1/1
Don’t want to predict evil but I think there maybe some issues on your line, could be noise on some tones, that’s why bitswap working so hard, because some tones are unusable bits are swapped that is probably why you had so high amount of errors with draytek, hg612 seems to use different tones or either manage to bitswap better.
Could you please post pictures of snr graph and hlog from dsl stats program. (when you got time of course)
April 26, 2020 at 7:32 am #6720April 26, 2020 at 9:34 am #6721April 26, 2020 at 9:47 am #6723April 26, 2020 at 10:00 am #6724I put mine back in the name of science
, so far no issues with it, slightly slower on sync speed but I knew the price. I think my cabinet going to blow up anyway, as attainable speed keep dropping pretty much every week, what didn’t happened in the past. No issues with vigor as you know so I may put him back next weekend
( I must be bored too ).Below my recent stats, snr on downstream 5.8db was 6.2db when I connected but obviously attainable speed drop so snr follow. Also bitswap bit higher since connected but not much.
adsl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason: 0
Max: Upstream rate = 22087 Kbps, Downstream rate = 72276 Kbps
Bearer: 0, Upstream rate = 20000 Kbps, Downstream rate = 72470 KbpsLink Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 5.8 6.4
Attn(dB): 13.3 0.0
Pwr(dBm): 1.1 1.1VDSL2 framing
Bearer 0
MSGc: 18 150
B: 239 236
M: 1 1
T: 22 5
R: 0 16
S: 0.1054 0.3771
L: 18216 5410
D: 1 1
I: 240 255
N: 240 255Counters
Bearer 0
OHF: 8503806 2424350
OHFErr: 68 20
RS: 0 2886047
RSCorr: 0 142
RSUnCorr: 0 0Bearer 0
HEC: 168 0
OCD: 2 0
LCD: 2 0
Total Cells: 2069172117 0
Data Cells: 44895294 0
Drop Cells: 0
Bit Errors: 0 0ES: 24 20
SES: 0 0
UAS: 27 27
AS: 14851Bearer 0
INP: 0.00 0.00
INPRein: 0.00 0.00
delay: 0 0
PER: 1.74 6.15
OR: 109.97 202.87
AgR: 72580.48 20203.27Bitswap: 29/29 3/3
Total time = 4 hours 7 min 58 sec
FEC: 0 142
CRC: 68 20
ES: 24 20
SES: 0 0
UAS: 27 27
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 15 minutes time = 7 min 58 sec
FEC: 0 10
CRC: 2 1
ES: 2 1
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 0 14
CRC: 3 1
ES: 3 1
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 4 hours 7 min 58 sec
FEC: 0 142
CRC: 68 20
ES: 24 20
SES: 0 0
UAS: 27 27
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 1 day time = 0 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 4 hours 7 min 29 sec
FEC: 0 142
CRC: 68 20
ES: 24 20
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
NTR: mipsCntAtNtr=0 ncoCntAtNtr=0You need to login in order to vote
April 26, 2020 at 10:12 am #6726April 26, 2020 at 10:15 am #6728April 26, 2020 at 12:34 pm #6730Right, I have to rebooted zyxel modem as I have bunch of CRC error, looks like it can cope properly with snr below 6db (on 6db profile). Will keep an eye on it till rest of the day, draytek may be back on duty sooner
April 26, 2020 at 3:25 pm #6744Right, I have to rebooted zyxel modem as I have bunch of CRC error, looks like it can cope properly with snr below 6db (on 6db profile). Will keep an eye on it till rest of the day, draytek may be back on duty sooner
So your science experiment has finished ;-)
April 26, 2020 at 3:37 pm #6745Well still running and keep an eye on it from time to time. In the mean time I was browsing internet about g.inp on eci, and found something interesting… This wonderful future enable FEC on downstream for broadcom modem on eci cabinet 😂😂 what convenience me even more to go back to draytek. Therefore not sure how it’s working on Huawei cabinet @Uk Sentinel?
April 26, 2020 at 4:20 pm #6747Today’s stats –
xdslcmd info –stats
Status: Showtime
Retrain Reason: 6
Max: Upstream rate = 12136 Kbps, Downstream rate = 50748 Kbps
Bearer: 0, Upstream rate = 12097 Kbps, Downstream rate = 39709 KbpsLink Power State: L0
Mode: VDSL2 Annex B
Trellis: U:ON /D:ON
Down Up
SNR (dB): 6.1 6.1
Attn(dB): 19.6 0.0
Pwr(dBm): 13.3 6.7
VDSL2 framing
Bearer 0
MSGc: 15 20
B: 25 238
M: 1 1
T: 64 31
R: 10 16
S: 0.0208 0.6287
L: 13824 3245
D: 2803 1
I: 36 255
N: 36 255
Counters
Bearer 0
OHF: 33974281 1280630
OHFErr: 100 0
RS: 2335387872 3808628
RSCorr: 515474 3
RSUnCorr: 7270 0Bearer 0
HEC: 759 0
OCD: 28 0
LCD: 28 0
Total Cells: 1777370627 0
Data Cells: 255491876 0
Drop Cells: 0
Bit Errors: 0 0ES: 31 5296
SES: 17 62
UAS: 68 167676
AS: 79585Bearer 0
INP: 8.00 0.00
INPRein: 0.00 0.00
delay: 14 0
PER: 2.34 9.78
OR: 71.71 21.26
AgR: 39780.60 12118.23Bitswap: 55892/56281 32/33
Total time = 1 days 50 min 56 sec
FEC: 581671 3
CRC: 7223 0
ES: 31 5296
SES: 17 62
UAS: 68 167676
LOS: 1 2
LOF: 13 2
LOM: 7 0
Latest 15 minutes time = 5 min 56 sec
FEC: 889 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 6137 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 50 min 56 sec
FEC: 14164 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 567507 3
CRC: 7223 0
ES: 31 5296
SES: 17 62
UAS: 68 167676
LOS: 1 2
LOF: 13 2
LOM: 7 0
Since Link time = 22 hours 6 min 25 sec
FEC: 515474 3
CRC: 100 0
ES: 13 2648
SES: 0 31
UAS: 0 83832
LOS: 0 1
LOF: 0 1
LOM: 0 0DSLAM type / SW version: IFTN:0xd086 (208.134) / v0xd086
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime: 22 hours 18 min 19 sec
Resyncs: 0 (since 26 Apr 2020 17:13:36)Downstream Upstream
Line attenuation (dB): 19.6 0.0
Signal attenuation (dB): Not monitored
Connection speed (kbps): 39709 12097
SNR margin (dB): 6.1 6.1
Power (dBm): 13.3 6.7
Interleave depth: 2803 1
INP: 8.00 0
Vectoring status: 5 (VECT_UNCONFIGURED)RSCorr/RS (%): 0.0209 0.0001
RSUnCorr/RS (%): 0.0003 0.0000
April 26, 2020 at 4:26 pm #6749 -
