Viewing 15 posts - 166 through 180 (of 718 total)
  • #6688
    AvatarMrk26
    • Replies 465
    Just make sure that in dhcp start pooling address is from (example) 192.168.1.6 so your ip (example) 192.168.1.2 for hg612 is not taken by any other device in your network. Also in wan settings you need to change to get IP automatically, hg612  working different than vigor so therefore setup is slightly different. Then of course one cable to wan in asus and one in to lan, if you setup like that you should have access to telnet and via dsl stats program.
    #6690
    Bully
    • Replies 386
    Todays Stats –
    xdslcmd info –stats
    Status: Showtime
    Retrain Reason: 0
    Max: Upstream rate = 12109 Kbps, Downstream rate = 50704 Kbps
    Bearer: 0, Upstream rate = 12045 Kbps, Downstream rate = 34999 Kbps
    Link Power State: L0
    Mode: VDSL2 Annex B
    VDSL2 Profile: Profile 17a
    TPS-TC: PTM Mode(0x0)
    Trellis: U:ON /D:ON
    Line Status: No Defect
    Training Status: Showtime
    Down Up
    SNR (dB): 8.6 6.1
    Attn(dB): 19.6 0.0
    Pwr(dBm): 13.3 6.7
    VDSL2 framing
    Bearer 0
    MSGc: 18 20
    B: 47 238
    M: 1 1
    T: 61 31
    R: 16 16
    S: 0.0436 0.6314
    L: 11736 3231
    D: 1485 1
    I: 64 255
    N: 64 255
    Counters
    Bearer 0
    OHF: 33248874 504941
    OHFErr: 1 0
    RS: 3817668293 78424
    RSCorr: 111989 9
    RSUnCorr: 1 0
    Bearer 0
    HEC: 0 0
    OCD: 0 0
    LCD: 0 0
    Total Cells: 1678343065 0
    Data Cells: 356409855 0
    Drop Cells: 0
    Bit Errors: 0 0
    ES: 1 2648
    SES: 0 31
    UAS: 26 83749
    AS: 88827
    Bearer 0
    INP: 8.00 0.00
    INPRein: 0.00 0.00
    delay: 16 0
    PER: 2.67 9.82
    OR: 71.86 21.17
    AgR: 35071.00 12065.94
    Bitswap: 62891/63321 13/13
    Total time = 1 days 40 min 53 sec
    FEC: 111989 9
    CRC: 1 0
    ES: 1 2648
    SES: 0 31
    UAS: 26 83749
    LOS: 0 1
    LOF: 0 1
    LOM: 0 0
    Latest 15 minutes time = 10 min 53 sec
    FEC: 271 0
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    FEC: 270 0
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    Latest 1 day time = 40 min 53 sec
    FEC: 1480 0
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    FEC: 110509 9
    CRC: 1 0
    ES: 1 2648
    SES: 0 31
    UAS: 26 83749
    LOS: 0 1
    LOF: 0 1
    LOM: 0 0
    Since Link time = 1 days 40 min 27 sec
    FEC: 111989 9
    CRC: 1 0
    ES: 1 2648
    SES: 0 31
    UAS: 0 83723
    LOS: 0 1
    LOF: 0 1
    LOM: 0 0
    #6691
    Bully
    • Replies 386
    Stats recorded 24 Apr 2020 18:20:43
    DSL mode: VDSL2 Profile 17a
    Status: Showtime
    Uptime: 1 day 0 hour 43 min 57 sec
    Resyncs: 0 (since 24 Apr 2020 18:17:11)
    Downstream Upstream
    Line attenuation (dB): 19.6 0.0
    Signal attenuation (dB): Not monitored
    Connection speed (kbps): 34999 12045
    SNR margin (dB): 8.6 6.1
    Power (dBm): 13.3 6.7
    Interleave depth: 1485 1
    INP: 8.00 0
    Vectoring status: 5 (VECT_UNCONFIGURED)
    RSCorr/RS (%): 0.0029 0.0006
    ES/hour: 0 0
    This looks interesting –
    https://forum.kitz.co.uk/index.php?topic=17671.0
    #6692
    AvatarMrk26
    • Replies 465
    Well 111k FEC errors now compare to milions before, I personally see light in this tunnel. Let’s see if DLM will like this change, minimum 3 days, maximum 6 for any positive action. If nothing happen then we will think about how to help DLM to make right decision 😉
    #6693
    • Replies 8,724
    As per link – changing 192.168.1.1 (i normally use 192.168.1.2) for routers IP sounds a good option to stop the hourly disconnects (a volunteer need)
    Hacking modem Iptables sounds a little risky
    FEC’s count are getting better
    #6694
    AvatarMrk26
    • Replies 465
    [quote quote=6691]This looks interesting – https://forum.kitz.co.uk/index.php?topic=17671.0[/quote]
    With iptables it’s always lottery, may work, may not. I think I tried in the past with Rt-ac68u and I wasn’t successful. For one cable solution best method working on asus router is the one @Uk Sentinel wrote in vigor section on this forum. If per these instructions HG612 will work on one cable then you can configure same way as vigor.
    @Uk Sentinel
    Could you please have look on this guide and see if HG612 configured as per instruction from link will work on one cable with asus router configured “your” way.
    #6695
    Bully
    • Replies 386
    @Mrk26 – I had configured the HG612 the same as my Draytek modem and left Asus router as it was configured for Draytek modem, but i can only access web gui via lan2 on HG612, dslstats works only via lan 2 on HG612 and telnet via windows does not work.
    #6696
    AvatarMrk26
    • Replies 465
    Did you configure HG612 as per instruction from your link? The biggest issue here is HG612 which is not configured properly, once that is sorted all should work. Thing is that if you will play with HG612 now it may reboot as configuration will be changed what is not good move now when modem settling.
    Edit
    Every reboot now delay positive action from DLM side, so it’s your call. If you reboot modem you start counting again from scratch. I personally will wait these couple of days.
    Edit 2,
    You sure you setup telnet from windows correctly? If dsl stats working telnet must working as well as dsl stats take all data from telnet.
    #6699
    Bully
    • Replies 386
    Not done anything from the link.
    How i currently have it configured –
    On Asus router RT-AC86U
    Get the WAN IP automatically No
    IP Address – 192.168.2.2
    Subnet Mask – 255.255.255.0
    Default Gateway – 192.168.2.1
    On Hg612
    Lan ip 192.168.2.1
    EDIT 1 – When i try to access via windows telnet i get this – Microsoft Telnet> 192.168.2.1
    Invalid Command. type ?/help for help
    Microsoft Telnet>
    EDIT 2 – I know why, i did not enter telnet then ip (how embarrassing)
    #6704
    AvatarMrk26
    • Replies 465
    O.K first of all, the HG612 will not work on single cable until you finish procedure from post you linked, and actually I read through and Iptable commands are executed on HG612 modem so that may be a bit tricky. The other more safe option is configure HG612 as I described earlier with two cables connected and I guarantee that all will work as should.
    For better telnet experience I recommend PuTTY
    #6707
    • Replies 8,724
    [quote quote=6694]
    @Uk Sentinel Could you please have look on this guide and see if HG612 configured as per instruction from link will work on one cable with asus router configured “your” way.
    [/quote]
    The iptables etc. look good but I would not approve this usage (my moto is)  ‘KIS’ keep-it-simple -this could leave the modem open to exploitation,
    #6708
    Bully
    • Replies 386
    I am going to leave it a few days and see how its goes before i fiddle about any more.
    #6709
    • Replies 8,724
    [quote quote=6708]I am going to leave it a few days and see how its goes before i fiddle about any more.[/quote]
    #6711
    Bully
    • Replies 386
    HI,
    Todats stats –
    xdslcmd info –stats
    Status: Showtime
    Retrain Reason: 0
    Max: Upstream rate = 12121 Kbps, Downstream rate = 50840 Kbps
    Bearer: 0, Upstream rate = 12019 Kbps, Downstream rate = 39709 Kbps
    Mode: VDSL2 Annex B
    Trellis: U:ON /D:ON
    Down Up
    SNR (dB): 6.2 6.1
    Attn(dB): 19.6 0.0
    Pwr(dBm): 13.3 6.6
    VDSL2 framing
    Bearer 0
    MSGc: 15 20
    B: 25 238
    M: 1 1
    T: 64 31
    R: 10 16
    S: 0.0208 0.6328
    L: 13824 3224
    D: 2803 1
    I: 36 255
    N: 36 255
    Counters
    Bearer 0
    OHF: 4080767 974955
    OHFErr: 6 0
    RS: 1827995376 293718
    RSCorr: 64065 0
    RSUnCorr: 42 0
    Bearer 0
    HEC: 7 0
    OCD: 1 0
    LCD: 1 0
    Total Cells: 729378890 0
    Data Cells: 47222311 0
    Drop Cells: 0
    Bit Errors: 0 0
    ES: 1 2648
    SES: 0 31
    UAS: 26 83819
    AS: 9560
    Bearer 0
    INP: 8.00 0.00
    INPRein: 0.00 0.00
    delay: 14 0
    PER: 2.34 9.84
    OR: 71.71 21.12
    AgR: 39780.60 12039.80
    Bitswap: 6812/6841 3/3
    Total time = 2 hours 39 min 46 sec
    FEC: 64065 0
    CRC: 6 0
    ES: 1 2648
    SES: 0 31
    UAS: 26 83819
    LOS: 0 1
    LOF: 0 1
    LOM: 0 0
    Latest 15 minutes time = 9 min 46 sec
    FEC: 7763 0
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    FEC: 3394 0
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    Latest 1 day time = 2 hours 39 min 46 sec
    FEC: 64065 0
    CRC: 6 0
    ES: 1 2648
    SES: 0 31
    UAS: 26 83819
    LOS: 0 1
    LOF: 0 1
    LOM: 0 0
    Previous 1 day time = 0 sec
    FEC: 0 0
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    Since Link time = 2 hours 39 min 19 sec
    FEC: 64065 0
    CRC: 6 0
    ES: 1 2648
    SES: 0 31
    UAS: 0 83793
    LOS: 0 1
    LOF: 0 1
    LOM: 0 0
    #6712
    AvatarMrk26
    • Replies 465
    Modem sync nearly 40Mb/s on downstream now, did you rebooted recently? 🤔
