UKTH forums 🛜 Wireless Routers & Modems ASUS & Wireless RT-AC86U 384.16 Hi,   I updated to the latest Merlin firmware this morning (about 9 am) and since doing so my NE CRC count has gone up to 326598 over 5 hours. ...
  • This topic has 717 replies, 4 voices, and was last updated 6 years ago by Bully.
Viewing 15 posts - 241 through 255 (of 718 total)
  • #6833
    Bully
    • Replies 386
    @Bully performed original quiet line test via Master Socket (faceplate socket) I believe. Yes, I believe also faceplates can fail if line (outside) is hit with lightening etc.
    I did the quiet line test at the test socket, the faceplate and from the extension in the living room.
    #6834
    AvatarMrk26
    • Replies 465
    Was any difference between them?
    #6835
    Bully
    • Replies 386
    Yeah, the living room extension using a wireless phone was worse.  The Faceplate and test socket using a cabled phone were identical and not as bad, heard slight hiss.
    #6837
    AvatarMrk26
    • Replies 465
    Did you tried to disconnect phone and see if stats don’t get any better, also another opposite option make a call from landline and see how stats looks like during a call.
    #6838
    Bully
    • Replies 386
    @Mrk26 – No i did not try this.
    Today’s stats –
    xdslcmd info –stats
    Status: Showtime
    Retrain Reason: 0
    Max: Upstream rate = 12263 Kbps, Downstream rate = 50652 Kbps
    Bearer: 0, Upstream rate = 12216 Kbps, Downstream rate = 39994 Kbps
    Link Power State: L0
    Mode: VDSL2 Annex B
    VDSL2 Profile: Profile 17a
    TPS-TC: PTM Mode(0x0)
    Trellis: U:ON /D:ON
    Line Status: No Defect
    Training Status: Showtime
    Down Up
    SNR (dB): 6.8 6.1
    Attn(dB): 19.5 0.0
    Pwr(dBm): 13.4 6.7
    VDSL2 framing
    Bearer 0
    MSGc: 18 20
    B: 31 238
    M: 1 1
    T: 64 63
    R: 10 16
    S: 0.0255 0.6225
    L: 13200 3277
    D: 1283 1
    I: 42 255
    N: 42 255
    Counters
    Bearer 0
    OHF: 38508352 1079384
    OHFErr: 109 1
    RS: 1902150454 1373610
    RSCorr: 305328 14
    RSUnCorr: 3882 0
    Bearer 0
    HEC: 638 0
    OCD: 27 0
    LCD: 27 0
    Total Cells: 2965003192 0
    Data Cells: 725946512 0
    Drop Cells: 0
    Bit Errors: 0 0
    ES: 23 2654
    SES: 0 31
    UAS: 25 84199
    AS: 94471
    Bearer 0
    INP: 3.50 0.00
    INPRein: 0.00 0.00
    delay: 8 0
    PER: 2.45 9.84
    OR: 78.26 21.13
    AgR: 40072.04 12237.73
    Bitswap: 65016/65363 9/9
    Total time = 1 days 2 hours 14 min 56 sec
    FEC: 305328 14
    CRC: 109 1
    ES: 23 2654
    SES: 0 31
    UAS: 25 84199
    LOS: 0 1
    LOF: 0 1
    LOM: 0 0
    Latest 15 minutes time = 14 min 56 sec
    FEC: 3350 0
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    FEC: 715 1
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    Latest 1 day time = 2 hours 14 min 56 sec
    FEC: 75207 3
    CRC: 72 0
    ES: 11 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    FEC: 230121 11
    CRC: 37 1
    ES: 12 2654
    SES: 0 31
    UAS: 25 84199
    LOS: 0 1
    LOF: 0 1
    LOM: 0 0
    Since Link time = 1 days 2 hours 14 min 29 sec
    FEC: 305328 14
    CRC: 109 1
    ES: 23 2654
    SES: 0 31
    UAS: 0 84174
    LOS: 0 1
    LOF: 0 1
    LOM: 0 0
    Stats recorded 30 Apr 2020 18:08:11
    DSL mode: VDSL2 Profile 17a
    Status: Showtime
    Uptime: 1 day 2 hours 14 min 31 sec
    Resyncs: 0 (since 30 Apr 2020 18:08:06)
    Downstream Upstream
    Connection speed (kbps): 39994 12216
    SNR margin (dB): 6.8 6.1
    Power (dBm): 13.4 6.7
    Interleave depth: 1283 1
    INP: 3.50 0
    Vectoring status: 5 (VECT_UNCONFIGURED)
    RSCorr/RS (%): 0.0161 0.0010
    RSUnCorr/RS (%): 0.0002 0.0000
    ES/hour: 0 0
    #6839
    AvatarMrk26
    • Replies 465
    Do you keep your pc running to monitor your line? Last day you have 230k FEC errors, last 2h 75k that is a big burst in last two hours!! I guess you were in home at this time. Was something specific turned on?
    #6841
    Bully
    • Replies 386
    3 people are at home using the internet thorough out the day every day during the Covid lock down, using mobile phones, laptops, firesticks and xbox.
    No, i do not keep my laptop running to monitor my line.
    #6842
    AvatarMrk26
    • Replies 465
    No worries, normal usage is out of control and obviously not much we can do about in these days. It’s just that burst of errors last 2h from the time you posted stats it’s a bit suspicious. That’s why I asked did you noticed if something specific was turned on in home, could be also time of the day where congestion on broadband network increases causing bunch of errors. This amount of errors which appear on your line now are much better than before (with vigor on the line), but I’m not sure if is good enough.
    #6844
    AvatarMrk26
    • Replies 465
    @Bully
    I forgot to ask, on what package is your broadband, Is it 40/10?
    #6845
    Bully
    • Replies 386
    @Bully I forgot to ask, on what package is your broadband, Is it 40/10?
    Yes its either 40/10 or 45/10.
    #6848
    AvatarMrk26
    • Replies 465
    Just to make @Bully fill better, I’m on 5th day today constantly connected since lost fastpath and still no change. I will give time for my modem till Sunday, if nothing change I will apply light cap on downstream to let DLM know that I need fastpath right now 😜
    #6852
    Bully
    • Replies 386
    Great.
    Today’s stats –
    xdslcmd info –stats
    Status: Showtime
    Retrain Reason: 0
    Max: Upstream rate = 12381 Kbps, Downstream rate = 51768 Kbps
    Mode: VDSL2 Annex B
    Trellis: U:ON /D:ON
    Down Up
    SNR (dB): 7.1 6.2
    Attn(dB): 19.5 0.0
    Pwr(dBm): 13.4 6.7
    VDSL2 framing
    Bearer 0
    MSGc: 18 20
    B: 31 238
    M: 1 1
    T: 64 63
    R: 10 16
    S: 0.0255 0.6225
    L: 13200 3277
    D: 1283 1
    I: 42 255
    N: 42 255
    Counters
    Bearer 0
    OHF: 73451543 1266829
    OHFErr: 167 1
    RS: 2435433802 2393983
    RSCorr: 552930 17
    RSUnCorr: 6942 0
    Bearer 0
    HEC: 1178 0
    OCD: 49 0
    LCD: 49 0
    Total Cells: 963394437 0
    Data Cells: 2215487903 0
    Drop Cells: 0
    Bit Errors: 0 0
    ES: 39 2654
    SES: 0 31
    UAS: 25 84199
    AS: 180194
    Bearer 0
    INP: 3.50 0.00
    INPRein: 0.00 0.00
    delay: 8 0
    PER: 2.45 9.84
    OR: 78.26 21.13
    Bitswap: 124100/124841 17/17
    Total time = 1 days 2 hours 3 min 39 sec
    FEC: 552930 17
    CRC: 167 1
    ES: 39 2654
    SES: 0 31
    UAS: 25 84199
    LOS: 0 1
    LOF: 0 1
    LOM: 0 0
    Latest 15 minutes time = 3 min 39 sec
    FEC: 40307 0
    CRC: 10 0
    ES: 1 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    FEC: 4619 0
    CRC: 8 0
    ES: 2 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    Latest 1 day time = 2 hours 3 min 39 sec
    FEC: 93852 0
    CRC: 30 0
    ES: 9 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    FEC: 228957 6
    CRC: 100 0
    ES: 18 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    Since Link time = 2 days 2 hours 3 min 13 sec
    FEC: 552930 17
    CRC: 167 1
    ES: 39 2654
    SES: 0 31
    UAS: 0 84174
    LOS: 0 1
    LOF: 0 1
    LOM: 0 0
    Stats recorded 01 May 2020 17:57:51
    Status: Showtime
    Uptime: 2 days 2 hours 4 min 14 sec
    Resyncs: 0 (since 01 May 2020 17:56:18)
    Downstream Upstream
    INP: 3.50 0
    RSCorr/RS (%): 0.0226 0.0006
    RSUnCorr/RS (%): 0.0003 0.0000
    ES/hour: 0 0
    #6853
    • Replies 8,641
    I forgot to say yesterday, you are probable on BT’s 50/10 service as this ties in with your synch speed, what you get at modem is what we are working On
    https://www.bt.com/
    #6856
    Bully
    • Replies 386
    If I ever got 50 mb download again I would be happy
    #6857
    • Replies 8,641
    We all would be happy
