Bully.
- May 2, 2020 at 8:53 am #6869
Upgraded router merlin fw to 384.17 this morning, did a factory reset, and connected HG612 lan2 to router. I can access modem through router now.
Seen this in router stats, getting this log every 3 seconds or so – May 2 09:52:09 kernel: br0: received packet on eth1 with own address as source address ?
Today’s stats –
xdslcmd info –stats
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 12381 Kbps, Downstream rate = 51076 Kbps
Bearer: 0, Upstream rate = 12280 Kbps, Downstream rate = 39994 KbpsLink Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.9 6.1
Attn(dB): 19.5 0.0
Pwr(dBm): 13.4 6.8
VDSL2 framing
Bearer 0
MSGc: 18 21
B: 31 238
M: 1 1
T: 64 22
R: 10 16
S: 0.0255 0.6193
L: 13200 3294
D: 1283 1
I: 42 255
N: 42 255
Counters
Bearer 0
OHF: 244576 58653
OHFErr: 0 0
RS: 93762310 3869246
RSCorr: 517 0
RSUnCorr: 0 0Bearer 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 46091927 0
Data Cells: 17595135 0
Drop Cells: 0
Bit Errors: 0 0ES: 0 2655
SES: 0 31
UAS: 25 84362
AS: 601Bearer 0
INP: 3.50 0.00
INPRein: 0.00 0.00
delay: 8 0
PER: 2.45 10.25
OR: 78.26 21.05
AgR: 40072.04 12301.21Bitswap: 393/396 0/0
Total time = 10 min 26 sec
FEC: 517 0
CRC: 0 0
ES: 0 2655
SES: 0 31
UAS: 25 84362
LOS: 0 1
LOF: 0 1
LOM: 0 0
Latest 15 minutes time = 10 min 26 sec
FEC: 517 0
CRC: 0 0
ES: 0 2655
SES: 0 31
UAS: 25 84362
LOS: 0 1
LOF: 0 1
LOM: 0 0
Previous 15 minutes time = 0 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 10 min 26 sec
FEC: 517 0
CRC: 0 0
ES: 0 2655
SES: 0 31
UAS: 25 84362
LOS: 0 1
LOF: 0 1
LOM: 0 0
Previous 1 day time = 0 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 9 min 59 sec
FEC: 517 0
CRC: 0 0
ES: 0 2655
SES: 0 31
UAS: 0 84337
LOS: 0 1
LOF: 0 1
LOM: 0 0Stats recorded 02 May 2020 09:52:20
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime: 0 hour 12 min 31 sec
Resyncs: 0 (since 02 May 2020 09:49:47)Downstream Upstream
Connection speed (kbps): 39994 12280
SNR margin (dB): 6.9 6.1
Power (dBm): 13.4 6.8
Interleave depth: 1283 1
INP: 3.50 0
Vectoring status: 5 (VECT_UNCONFIGURED)RSCorr/RS (%): 0.0005 0.0000
May 2, 2020 at 9:23 am #6870Check if modem hold connection, these stats are only from 10 mins, unless you reboot modem as well with router.
May 2, 2020 at 10:56 am #6871ARGGHHHHH – Cant access my router now, via its lan ip. Can access it via router.asus. com.
May 2, 2020 at 11:03 am #6872How did you configure router? 🤔
With two cable option you should have automatic wan IP, you can change dns if you want. To give modem ip like on vigor don’t give you any benefits, but can cause issues with two cables option.
May 2, 2020 at 11:19 am #6873[quote quote=6872]How did you configure router? 🤔 With two cable option you should have automatic wan IP, you can change dns if you want. To give modem ip like on vigor don’t give you any benefits, but can cause issues with two cables option.[/quote]
Automatic wan ip on router?
May 2, 2020 at 11:22 am #6874Yes, and make sure HG612 have different IP on lan than asus but they must be in same IP group eg. 192.168.1.xx.
May 2, 2020 at 11:26 am #6875I have configured the modem on 192.168.1.XX, the router is on 192.168.0.XX, i have configured router wan to modem lan.
May 2, 2020 at 11:45 am #6876May 2, 2020 at 11:46 am #6877May 2, 2020 at 11:54 am #6878May 2, 2020 at 11:58 am #6883When I used eci modem with two cables all was configured like that:
Modem – lan 192.168.1.2
Subnet mask 255.255.255.0
Router – 192.168.1.1
Wan IP automatically, as you access modem through lan port.
May 2, 2020 at 12:07 pm #6884Also as mentioned earlier setup in lan in router start address from eg 192.168.1.6 so router will not assign IP dedicated for modem lan to other device. Then you should see modem ip eg. 192.168.1.2 on your connected devices list.
May 2, 2020 at 12:09 pm #6885Set wan IP on router to auto, i have internet but now cannot access modem.
***EDIT*** – CHANGED BACK TO MANUAL AND I CAN NOW ACCESS MODEM.
May 2, 2020 at 12:15 pm #6886May 2, 2020 at 12:18 pm #6889 - AuthorPosts
