RT-AC86U 384.16
Viewing 15 posts - 631 through 645 (of 718 total)
  • #7928
    AvatarMrk26
    • Replies 465
    If you can, post stats in the morning.
    #7929
    Bully
    • Replies 386
    sorry only just seen your request.
    Todays stats –
    DS Actual Rate          : 35000000 bps   US Actual Rate       : 10636000 bps
    DS Attainable Rate      : 44922288 bps   US Attainable Rate   : 10920032 bps
    DS Interleave Depth     :      581       US Interleave Depth  :        1
    NE Current Attenuation  :       20 dB    Cur SNR Margin       :        7  dB
    DS actual PSD           :     6. 5 dB    US actual PSD        :    13. 1  dB
    NE CRC Count            :      213       FE CRC Count         :     4112
    NE ES Count             :       34       FE  ES Count         :     2681
    Xdsl Reset Times        :        0       Xdsl Link  Times     :        3
    VDSL Firmware Version   : 05-07-09-0F-01-07   [with Vectoring support]
    > vdsl status more
    LOS          :      4               0
    FECS         :   7598586            55033 (seconds)
    ES           :     34            2681 (seconds)
    UAS          :     34            89685 (seconds)
    CRC          :    213            4112
    INP          :      0              15 (symbols)
    InterleaveDelay :      0             800 (1/100 ms)
    NFEC         :    255              76
    LSYMB        :   2854            11189
    INTLVBLOCK   :    255              76
    > vdsl status counts
    [ Counters: Showtime ]
    ElapsedTime  :   1013722            1013722 (seconds)
    CRC          :    213            4112
    FEC          :   7598584            55033
    HEC          :      0               0
    CRC_P        :    178               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :     33            2681
    SES          :      0              31
    LOSS         :      0               1
    UAS          :      0               0
    LOFS         :      0               0
    [ Counters: 15Min ]
    ElapsedTime  :    864             864 (seconds)
    CRC          :      0               0
    FEC          :    145               0
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0               0
    SES          :      0               0
    LOSS         :      0               0
    UAS          :      0               0
    LOFS         :      0               0
    [ Counters: 1DAY ]
    ElapsedTime  :   38664            38664 (seconds)
    CRC          :      0               0
    FEC          :   791955               0
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0               0
    SES          :      0               0
    LOSS         :      0               0
    UAS          :      0               0
    LOFS         :      0               0
    #7930
    AvatarMrk26
    • Replies 465
    No problem, if there’s nothing change tonight try to put cap again on your line.
    #7934
    • Replies 8,708
    Or give it a couple more days, jus incase
    ‘and unplug the telephone if pos’.
    #7935
    AvatarMrk26
    • Replies 465
    From my experience if nothing happen within 7 days it will not at all. @Bully stats getting worse and worse now, and as we observed DLM accepted average of 120k FEC errors per day on his line to action positive. Agree that telephone maybe issue here. If @Bully could run without telephone connected for couple of days that should clarify.
    #7936
    • Replies 8,708
    The Telephone removal should help us understand why the sudden increase in FEC, alas capping synch speeds is last resort as his connection is  so low already .
    BTW – my new Plusnet connection is still sorting itself out after 8 days, so 7 days as a rough guide is ok, but sometimes a pinch of salt is needed  .
    #7937
    AvatarMrk26
    • Replies 465
    Yes, but you are on Huawei cabinet that’s completely different story, some people waiting for weeks for g.inp to be activated and with cap they achieved within a week. On eci cabinet is bit different. I personally was waiting over 20 days in past with perfect stats and nothing happened, once capped DLM “woke up” and started do his job. Of course @Bully don’t have to cap now, if he disconnect phone we should see difference (hopefully).
    #7938
    • Replies 8,708
    We shall see .
    #7992
    AvatarMrk26
    • Replies 465
    Hi @Bully.
    How stats looking, any changes?
    #7993
    Bully
    • Replies 386
    Not disconnected phone yet.
    DS Attainable Rate      : 44874480 bps   US Attainable Rate   : 10916824 bps
    DS actual PSD           :     6. 5 dB    US actual PSD        :    13. 2  dB
    NE CRC Count            :      219       FE CRC Count         :     4112
    NE ES Count             :       37       FE  ES Count         :     2681
    > vdsl status more
    LOS          :      4               0
    FECS         :   11721662            55045 (seconds)
    ES           :     37            2681 (seconds)
    CRC          :    219            4112
    NFEC         :    255              76
    LSYMB        :   2854            11189
    INTLVBLOCK   :    255              76
    > vdsl status counts
    ElapsedTime  :   1239538            1239538 (seconds)
    CRC          :    219            4112
    FEC          :   11721660            55045
    HEC          :      0               0
    CRC_P        :    190               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :     36            2681
    SES          :      0              31
    LOSS         :      0               1
    UAS          :      0               0
    LOFS         :      0               0
    [ Counters: 15Min ]
    ElapsedTime  :    479             479 (seconds)
    CRC          :      0               0
    FEC          :    186               0
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0               0
    SES          :      0               0
    LOSS         :      0               0
    UAS          :      0               0
    LOFS         :      0               0
    [ Counters: 1DAY ]
    ElapsedTime  :   38279            38279 (seconds)
    CRC          :      0               0
    FEC          :   118359               0
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0               0
    SES          :      0               0
    LOSS         :      0               0
    UAS          :      0               0
    LOFS         :      0               0
    #7994
    AvatarMrk26
    • Replies 465
    These looks better than last one, looking forward to see stats with phone disconnected when it will be possible.
    #8073
    • Replies 8,708
    @Bully, has your new phone arrived yet
    #8080
    Bully
    • Replies 386
    No not yet
    #8155
    • Replies 8,708
    @bully – how’s your stats looking ?
    #8156
    Bully
    • Replies 386
    DS Attainable Rate      : 43695216 bps   US Attainable Rate   : 10435624 bps
    DS actual PSD           :     6. 5 dB    US actual PSD        :    13. 6  dB
    NE CRC Count            :     1633       FE CRC Count         :     4134
    NE ES Count             :      162       FE  ES Count         :     2697
    > vdsl status more
    LOS          :      4               0
    FECS         :   30800903            59318 (seconds)
    ES           :    162            2697 (seconds)
    SES          :      1              31 (seconds)
    CRC          :   1633            4134
    NFEC         :    255              76
    LSYMB        :   2854            11189
    INTLVBLOCK   :    255              76
    > vdsl status counts
    ElapsedTime  :   2221311            2221311 (seconds)
    CRC          :   1633            4134
    FEC          :   30800901            59318
    HEC          :      0               0
    CRC_P        :   1013               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :    161            2697
    SES          :      1              31
    LOSS         :      0               1
    UAS          :      0               0
    LOFS         :      0               0
    [ Counters: 15Min ]
    ElapsedTime  :    701             701 (seconds)
    CRC          :      0               0
    FEC          :   5018               0
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0               0
    SES          :      0               0
    LOSS         :      0               0
    UAS          :      0               0
    LOFS         :      0               0
    [ Counters: 1DAY ]
    ElapsedTime  :   40301            40301 (seconds)
    CRC          :      0               0
    FEC          :   42232              51
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0               0
    SES          :      0               0
    LOSS         :      0               0
    UAS          :      0               0
    LOFS         :      0               0
  • The topic ‘RT-AC86U 384.16’ is closed to new replies.
