February 11, 2022 at 6:59 am in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #17724
An update: After doing the factory reset, I’ve noticed that my connection stability is much worse. Around one day, CRC errors go mad, and the internet slows down (90 mbit/s to 8 mbit/s). I’m trying different DSL connection settings now. On the other hand, I’ve contacted with ASUS, they forwarded me to local ASUS service. After getting some log files from me, they’ve decided that they need to see the modem. The downside is, I’m working from home and If I send the modem, I won’t have a replacement, which means 20 business days of no internet.
can you attach dsl config?
Half-Life 1 Server IP: hl.oyunsen.com:27015
We will re-write code of world…
February 4, 2022 at 6:09 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #17547you must close all settings (not bitswap) from DSL Config area.. or you must do hard reset to modem.
January 31, 2022 at 5:36 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #17497I assume it is due to ASUS not selling many of these models anymore and they are not expensive, so not a good profit margin in 2022 ?
they are still expensive in Turkiye :)) price is 673 TL :D
January 28, 2022 at 1:29 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #17459Hi guys, I am using DSL AC-750 with 790 firmware. I dont have any problems but Asus has to release a new official firmware. Latest official firmware is very buggy so many customers have problems.
you can use 959beta. This is perfect
January 28, 2022 at 12:22 am in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #17441AC51_9.1.2.3_ipv6_05.trx is not official version. tr: o version resmĂ® sĂĽrĂĽm deÄźil yĂĽkleme biĹźi deÄźiĹźmiyor. Ben 959 ile ıpv6 sorunsuz kullanıyorum.
tr: gerekli ayarları yaptım fakat testlerden başarısız oluyor. papara ve twitter’a erişim sorunu yaşıyorum. ip6 alıyor, bilgisayar da alıyor. anlamadım kapattım bende ayarlardan.
so i dont use ipv6. Some applications dont work when active ipv6. Ex; Matriks. Nowly, go ahead use to ipv4
tr: ben de o yüzden kullanmıyorum ipv6yı. Bazı uygulamalar çalışmıyor ıpv6 aktif olunca(turknet kullanıyorum). En çok ihtiyacım olan matriks uygulaması veri akışını kesiyor. Şimdilik ıpv4 devam.
January 27, 2022 at 11:34 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #17439I use 960 firmware and this firmware force SNR at 15dB. But it slowed down my connection speed. Then I set it to 9 dB. 48 hours passed and 159 crc occurred. I didn’t have much of a problem with crc anyway. My problem is ipv6 tests fail. Maybe because of the iss maybe because of the firmware. I do not know. So far, the normal and beta firmware versions have all failed. My ISS recommends the firmware on this page for ipv6. This is an official page but you said before that AC51_9.1.2.3_ipv6_05.trx” firmware is not approved. That’s why I never installed it. Should i try?
tr: o version resmî sürüm değil yükleme bişi değişmiyor. Ben 959 ile ıpv6 sorunsuz kullanıyorum.
January 27, 2022 at 10:00 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #17436no no, i dont have got any disconnecting problems with 3db snr at 959. I added screenshot.
I will let ASUS know .959 is good
<noscript><noscript>
</noscript>thanks. asus can do this official version
January 27, 2022 at 8:44 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #17427When I set the snr to 15db, I do not get Crc errors in any version. I will write like this; For 960 version, same settings same 3db higher Crc error. Same settings same 3db I get less Crc error in 959 version.
Perfect,
<noscript>
</noscript>Edit: Do you have many DSL line disconnects with 3dB SNR with .959 ?no no, i dont have got any disconnecting problems with 3db snr at 959. I added screenshot.
January 27, 2022 at 3:01 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #17422Do you have many CRC with 8 or 3dB ? Have you tried SNR to 15dB to see if CRC reduce ?
January 27, 2022 at 10:34 am in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #17420Understood, if any body else is using this firmware and was experiencing DSL stability issues, did leaving the SNR at 15dB make the DSL connection more stable, less DSL disconnections ?
my iss default snr is 8. I use 102mbps vdsl2. So i dont know how is 15db. Now i pulled my snr to 3db, and no problem
January 27, 2022 at 9:31 am in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #17417Did 960 firmware force SNR at 15dB ? Any feedback I can pass to ASUS to help them make the next firmware better ?
no 960 fw didnt force 15db, i could adjust snr margin..
Everything is ok nowly for 959v.. I wont pass any version to fix late connection problem. I happy with 959.
January 26, 2022 at 10:29 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #17412yes. i hate from late connection problem at 960. And i solved crc problems at 959.
Apart from delayed connection issue with 960 and 2x CRC, was stability better ?
I couldn’t find any help at 960.
January 26, 2022 at 9:35 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #17408i returned 959 and no problem nowly.
Are you using 959 now ?
January 26, 2022 at 8:02 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #17404In this version, after connecting to vpn l2tp and pptp, the modem will restart when disconnected. Please report to Asus
I will inform ASUS of VPN disconnects
<noscript>
</noscript>i returned 959 and no problem nowly.
January 25, 2022 at 2:52 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #17361So ASUS have come back and they have spoken with the Chipset Venodor, they have agreed that SNR has changed to 15 dB A new firmware below with the adjustments to try for the DSL-AC51 only – if feedback is positive, the change will be made to other MediaTek based modem/routers also in future firmware’s for other models (factory reset advisable) I have made the firmware only available for members to download, as this is a test firmware version. DSL-AC51_9.1.2.3_960-g795fbf6.trx.zip (18 downloads)
9.1.2.3_960-g795fbf6 i installed and started to test. The first problem that caught my attention is the late connection problem. While I didn’t get a CRC error in the first 10 minutes in old versions, I got 2 CRC errors in the first 15 minutes. I’ll write again in 24 hours, but this lag issue is annoying. It was connected to the internet in exactly 4 minutes and 2 seconds..
