Viewing 15 posts - 661 through 675 (of 1,439 total)
  • #2493
    Avatarjetspeed
    • Replies 50
    Are ASUS aware of the issues with 591? Or should we still be reporting them?
    Just yesterday, I had the same issue where router was pingable, but no internet, and was not able to get into the admin UI.
    #2495
    • Replies 8,724
    [quote quote=2493]Are ASUS aware of the issues with 591? Or should we still be reporting them? Just yesterday, I had the same issue where router was pingable, but no internet, and was not able to get into the admin UI.[/quote]
    ASUS are aware of issues raised on this forum, but it never does any harm to send a feedback form to remind them of their failings ;-)
    #2496
    Avatarpavlf
    • Replies 70
    As I’ve said before you don’t quite know what router you are going to get when you reboot it. I’m at nearly 37 days and still on 47% usage. No issues at all. I bet that the next time it reboots it doesn’t come back in the state it’s in now.  The only difference between this time and the last more buggy time it booted up is that vpn is off. Other than that I’ve got between five and seven devices connected, two hdds, one running quite a lot of torrents and the other is used to stream high res audio (previous routers would have a bottleneck with high res audio, torrents, and browsing happening all at once, but not this one).
    #2588
    AvatarKatana1074
    • Replies 16
    Im close to returning this router,had 2 random reboots with the last 2 days,even tried reverting to firmware v1.10.06 build585,but made no difference,I think Asus need to take there heads out of there asses and sort this out…..
    #2589
    • Replies 8,724
    Is the router rebooting or is it just loss of access to internet, usually the DSL-AC88U is fairly stable for DSL connections? maybe a line fault?
    #2590
    AvatarKatana1074
    • Replies 16
    Hi Uk Sentinel…
    I get complete reboots,my partner said she heard the click behind her (where the router is situated),
    Just check the logs it rebooted completely at 19:59 tonight….
    #2591
    • Replies 8,724
    If you can , keep an eye on the RAM/Memory usage during the day, and see if this increase to 80 / 90% as this is usually the cause, if not then you may have a faulty unit? then time to buy a Fritz!Box ;-)
    #2592
    AvatarKatana1074
    • Replies 16
    Will do im at 176mb used at moment…
    #2593
    [quote quote=2590]Hi Uk Sentinel… I get complete reboots,my partner said she heard the click behind her (where the router is situated), Just check the logs it rebooted completely at 19:59 tonight….[/quote]
    Hasn’t been this problem with clicking (probably relais on DSL-output) 1-2 years ago too?
    We discussed these issues in asus-forum and whirlpool but maybe related to DSL-AC68U.
    As far as I can remember it was a firmware issue, DSL driver switches between different DSL-types/protocols or something like that or trying to reset line by completely disconnecting some time, only seen on some (for asus logic problematic) lines, not all users had this problem.
    Sold all asus and now a Fritz-fan without all those buggy firmware problems anymore.
    Hardware has been good for me all the time but they missed to employ some good programmers or at least one in Taiwan!
    #2595
    • Replies 8,724
    [quote quote=2592]Will do im at 176mb used at moment…[/quote]
    176Mb is good and norm if you have AiProtection disabled, will be interesting to see if it creeps up over the next couple of days.
    #2598
    • Replies 8,724
    [quote quote=2593]Hasn’t been this problem with clicking (probably relais on DSL-output) 1-2 years ago too? We discussed these issues in asus-forum and whirlpool but maybe related to DSL-AC68U. As far as I can remember it was a firmware issue, DSL driver switches between different DSL-types/protocols or something like that or trying to reset line by completely disconnecting some time, only seen on some (for asus logic problematic) lines, not all users had this problem.[/quote]
    The clicking, @Katana1074 said his better half heard the click, the DSL-AC88U used to have the issue when the router would click multiple times and this was resolved as they (ASUS) removed the G.fast option from Auto-Synch settings. If I remember correctly ?
    “when you have eliminated the impossible, whatever remains, however improbable, must be the truth”
    #2599
    miss a like button in this – and a dislike button in all – forums :-)
    #2600
    • Replies 8,724
    [quote quote=2599]miss a like button in this – and a dislike button in all – forums 🙂[/quote]
    Defo in my plans for the future, just trying to keep it simple for now ;-)
    #2601
    AvatarKatana1074
    • Replies 16
    Hi All…
    Hopefully ive resolved this,I had installed a BT Master Socket NTE5C + VDSL MK4.
    The faceplate has a habit of coming loose so ive superglued this on and hopefully will have no further disconnections….
    #2602
    • Replies 8,724
    Interesting and thanks for update, I would be surprised if a bad/poor master socket would cause the router to reboot, but this will be an interesting exercise.
    Let us know how it goes?
