- This topic has 1,438 replies, 106 voices, and was last updated 5 months, 4 weeks ago by
alt.james.
- April 6, 2019 at 2:27 pm #2603April 7, 2019 at 5:10 pm #2613
Hi All..
Dsl-AC88u has rebooted twice in the last 24 hours,this is getting rather annoying now…..
April 7, 2019 at 5:19 pm #2614Hi All.. Dsl-AC88u has rebooted twice in the last 24 hours,this is getting rather annoying now…..
So new BT face plate (master socket) did not help?
Did you manage to see RAM usage?
April 7, 2019 at 5:22 pm #2615Nope did not help,wonder if its because im using a cat 6a cable to connect to faceplate and not the original asus one……
April 7, 2019 at 5:39 pm #2616Nope did not help,wonder if its because im using a cat 6a cable to connect to faceplate and not the original asus one……
Cat 6a, does the BT master socket support this (RJ45) ? I assumed it should support RJ11 connectors, not RJ45, but I am a little rusty in this area?
Defo try other cable from ASUS, I was thinking that maybe Router is getting hot, is it in a ventilated area?
April 7, 2019 at 5:46 pm #2617yeah bt face plate takes either RJ11 or RJ45 cables,Ive actually moved the router so its now wall mounted,temps at the moment are : 2.4 GHz: 55°C – 5 GHz: 68°C – CPU: 49.623°C
regards
Katana1074
April 7, 2019 at 5:50 pm #2618yeah bt face plate takes either RJ11 or RJ45 cables,Ive actually moved the router so its now wall mounted,temps at the moment are : 2.4 GHz: 55°C – 5 GHz: 68°C – CPU: 49.623°C regards Katana1074
Temps are good, looks like trying the cable is next option as well as monitoring temp?
April 7, 2019 at 5:56 pm #2619Yeah i`ll keep an eye on it,one thing that was strange I was on Interleaved depth of 8 with the cat6a cable,now im on interleaved depth of 4 with the asus cable,mind you my sync speed is down from 6600o to 62000 so probably dslam is kicking me for the disconnects…
April 7, 2019 at 6:03 pm #2620Yeah i`ll keep an eye on it,one thing that was strange I was on Interleaved depth of 8 with the cat6a cable,now im on interleaved depth of 4 with the asus cable,mind you my sync speed is down from 6600o to 62000 so probably dslam is kicking me for the disconnects…
I also think the Dslam is making you suffer for all those reboots, whats the CRC like?
April 7, 2019 at 7:38 pm #2621Heres the current stats :
TCM(Trellis Coded Modulation)
ON
ON
SNR 3.3 dB 6.1 dB
Line Attenuation 18.1 dB N/A
Path Mode Fast Fast
Interleave Depth 4 8
Data Rate 62070 kbps 20000 kbps
MAX Rate 63669 kbps 21030 kbps
POWER 13.6 dbm 7.6 dbm
CRC 0 0
HEC 0 0
ES 0 1
SES 0 1
FEC 1549 358
INP 59.00 symbols 48.00 symboYou need to login in order to vote
April 7, 2019 at 8:20 pm #2622did you change power adapter?
often the problem for reboots due to bad DC-supply power to the unit.
Temps very good below 70°C for CPU and my Wifi-chips had same as yours, 51/56.
April 7, 2019 at 8:24 pm #2624No i Havent changed the power adapter,router is only 4 months old lol
April 7, 2019 at 9:02 pm #2625Heres the current stats : TCM(Trellis Coded Modulation) ON ON SNR 3.3 dB 6.1 dB Line Attenuation 18.1 dB N/A Path Mode Fast Fast Interleave Depth 4 8 Data Rate 62070 kbps 20000 kbps MAX Rate 63669 kbps 21030 kbps POWER 13.6 dbm 7.6 dbm CRC 0 0 HEC 0 0 ES 0 1 SES 0 1 FEC 1549 358 INP 59.00 symbols 48.00 symbo
Stats look good, hopefully DSL cable change and watching CPU temps will give us a clue ;-)
BTW – is DSL-AC88U power plug plugged into wall socket, or extension lead?
April 8, 2019 at 11:37 am #2634So should be ok, but should doesnt mean ‘is’!
To iron things out it is one part of the procedure.
Even new things can be wrong, though you are right they fail usually after >5 years.
Same with wall sockets, if all ok it is absolutely irrelevant where its connected to.
But we know constellations where it had influce.
April 8, 2019 at 11:46 am #2635Hi All…
Unfortunately ive had 2 more reboots this morning so i have bit the bullet and returned the DSL-AC88U and ordered a RT-AC86U,just means i`ll have to use my hg612 in conjunction with this…
Regards
Katana1074
