Viewing 15 posts - 61 through 75 (of 1,442 total)
  • #884
    gigios
    • Replies 27
    Thanks. I will start asap a new test ;)
    #886
    gigios
    • Replies 27
    – Revert to build 540
    – WiFi 2.4GHz, 5GHz, Guest (no MAC Filter)
    – DDNS
    – DHCP da 192.168.1.50 a 192.168.1.199
    – Port Forwarding (10 rules)
    – AI Protection off (default)
    – Firewall ON (after a switch to off and after a restore to on, otherwise I was not able to navigate on some sites, for example the Italian forum related the router).
    Date       Time   Used   %   Free
    2018-09-28 22:30 168MB (37%) 289MB
    2018-09-29 07:20 170MB (37%) 288MB
    2018-09-29 12:05 171MB (37%) 287MB
    2018-09-29 15:30 171MB (37%) 287MB
    2018-09-29 18:00 171MB (37%) 287MB
    2018-09-29 20:30 171MB (37%) 287MB
    2018-09-29 22:40 171MB (37%) 287MB
    2018-09-30 09:00 171MB (37%) 286MB
    2018-09-30 12:00 172MB (38%) 285MB
    2018-09-30 14:00 173MB (38%) 284MB
    2018-09-30 18:30 173MB (38%) 284MB
    2018-09-30 21:30 173MB (38%) 284MB
    #890
    [quote quote=886]– Revert to build 540 – WiFi 2.4GHz, 5GHz, Guest (no MAC Filter) – DDNS – DHCP da 192.168.1.50 a 192.168.1.199 – Port Forwarding (10 rules) – AI Protection off (not changed the default) – Firewall OFF (otherwise I’m not able to navigate on some sites, for example the Italian forum related the router). This is the same problem seen on the build 527
    [/quote]
    Same Memory Start usage as firmware 546 at least they are they same at the start.
    #897
    gigios
    • Replies 27
    Not completely true. In the 540, at the start, I have seen more memory allocation, but after 20 seconds (+/-) the memory came back to the ‘normal’ initial value.
    PS: The Firewall is ON, after the Switch OFF and came back, now seems works correctly (I’m able to navigate also in the Italian forum), except that the ports are closed instead stealth (but I think this is a know problem of this version).
    #902
    [quote quote=897]Not completely true. In the 540, at the start, I have seen more memory allocation, but after 20 seconds (+/-) the memory came back to the ‘normal’ initial value. PS: The Firewall is ON, after the Switch OFF and came back, now seems works correctly (I’m able to navigate also in the Italian forum), except that the ports are closed instead stealth (but I think this is a know problem of this version).[/quote]
    Yes, I also believe the release 540 had FW issues, memory usage so far from you above chart/table has only used 2Mb extra after 9 hours, your 546 chart, showed 20Mb extra used after 9 ish hours ???
    Interesting ;)
    #905
    gigios
    • Replies 27
    Yes, I confirm that the 540 has a better memory management. After 14 hours there is only 3MB more than the starting value. The configuration is exactly the same of the test done with the build 546. Probably this is the better starting point for a new firmware without the memory leak.
    #907
    [quote quote=905]Yes, I confirm that the 540 has a better memory management. After 14 hours there is only 3MB more than the starting value. The configuration is exactly the same of the test done with the build 546. Probably this is the better starting point for a new firmware without the memory leak.[/quote]
    Good news so far ;)
    #909
    gigios
    • Replies 27
    Today the memory seems very stable, without variations. Good news…
    #910
    [quote quote=909]Today the memory seems very stable, without variations. Good news…[/quote]
    Good news for ASUS ;) if this same memory usage tomorrow, I will let ASUS know on Monday, hopefully this helps them with a good starting point for new firmware’s, if they do not know already regarding beta540
    #938
    [quote quote=886]– Revert to build 540 – WiFi 2.4GHz, 5GHz, Guest (no MAC Filter) – DDNS – DHCP da 192.168.1.50 a 192.168.1.199 – Port Forwarding (10 rules) – AI Protection off (default) – Firewall ON (after a switch to off and after a restore to on, otherwise I was not able to navigate on some sites, for example the Italian forum related the router).
    [/quote]
    Hi @gigios, this is still showing no increase in memory usage by the DSL-AC88U running Beta 540 firmware. I think you have proved very well beta540 is a good point to allow ASUS to start new firmware development. I am happy for you to stop and will tell ASUS of your good work and results.
    Thnk you for your kind help ;)
    #939
    gigios
    • Replies 27
    Ok! Thank you also for the build 540 ;)
    #952
    gigios
    • Replies 27
    On Italian Forum we have received this answer from ASUS:
    “Thanks for confirmation. We also confirm that Build540 no such memory leak issue, so only several commits left to check, any update will inform you.”
    Now I’m crossing my fingers for a solution.
    #959
    @gigios – thanks for update and good news ASUS have also confirmed build540 is stable
    #961
    Avatarpavlf
    • Replies 70
    Fingers crossed some improvements are coming soon.
    #976
    ASUS have given me a copy of there latest DSL-AC88U firmware with memory leak fix, see below and please be aware, this is a beta, so read ASUS DSL Beta Firmware Policy, top of ASUS Forum and I am happy to pass back comments to ASUS if this helps?
    We have found root cause of memory leak issue, but not sure whether this is the only issue at the moment. This version is based on Build578 codebase, with Broadcom Patch5/ all WiFi patches adopted and with this memory leak issue fixed, should be optimal version currently. Feel free to share on your forums.
    DSL-AC88U_v9.10.06_build585.zip
    https://www.asuswebstorage.com/navigate/s/23991F8488394DAF92CBE25B97A5AB88Y
    Alternate link is as follows.
    https://www.asuswebstorage.com/navigate/s/8E6759046D13459BA0A9FCE3508A8DEC4
    Edit: DSL-AC3100_v9.10.06_build585.zip
    https://www.asuswebstorage.com/navigate/s/9443A5F69A7A405AAFEF7993A892051BY
    Factory reset Advised after flashing firmware
