Viewing 15 posts - 76 through 90 (of 1,442 total)
  • #978
    gigios
    • Replies 27
    I have received the same build from ASUS.
    I have started now the new test but without reset the settings because I’m not at home to reinitialize all the parameters with the correct values. But I hope that this is not a problem.
    Date       Time  Used    %   Free
    2018-10-02 11:45 179MB (39%) 279MB
    2018-10-02 13:05 181MB (40%) 276MB
    2018-10-02 15:00 180MB (39%) 277MB
    2018-10-02 16:00 182MB (40%) 276MB
    2018-10-02 18:00 181MB (40%) 276MB
    2018-10-02 20:00 182MB (40%) 275MB
    2018-10-02 22:00 182MB (40%) 276MB
    2018-10-02 23:00 182MB (40%) 276MB
    2018-10-03 06:30 182MB (40%) 275MB
    2018-10-03 06:35 Enabled AiProtection & WEB History + Backup on USB every hour
    2018-10-03 07:30 258MB (56%) 200MB
    2018-10-03 09:30 258MB (56%) 199MB
    2018-10-03 12:00 258MB (56%) 199MB
    2018-10-03 16:00 262MB (57%) 196MB
    2018-10-03 20:30 262MB (57%) 196MB
    2018-10-03 22:50 264MB (58%) 194MB
    2018-10-04 06:30 263MB (57%) 195MB
    2018-10-04 14:00 264MB (58%) 194MB
    #979
    [quote quote=978]I have received the same build from ASUS. I have started now the new test but without reset the settings because I’m not at home to reinitialize all the parameters with the correct values. But I hope that this is not a problem.
    [/quote]
    Good job ;)
    #983
    Avatardarkblak
    • Replies 12
    [quote quote=976]ASUS have given me a copy of there latest DSL-AC88U firmware with memory leak fix, see below and please be aware, this is a beta, so read ASUS DSL Beta Firmware Policy, top of ASUS Forum and I am happy to pass back comments to ASUS if this helps?
    <hr />
    [/quote]
    Looks like we all have it. Fingers crossed.
    #993
    [/quote]
    Memory usage is looking good/stable so far, after a day or so. maybe worth turning on AiProtection etc. to see if this makes a difference  ;)
    #995
    gigios
    • Replies 27
    For this night I stay with the current configuration, to have more ‘statistics’.
    Tomorrow after I will try to switch on the AiProtection (for me it’s the first time I switched on the AiProtection, in the past I used only the Parental Control for a Time Schedule and the Web History backup on USB key).
    For the moment seems a good firmware for the memory management.
    #1000
    gigios
    • Replies 27
    After more than 18 hours the memory seems very stable!
    Now I have started the test with AiProtection ON, Web History ON with the backup on USB key every hour.
    The memory allocation is a 16% greater than the previous value (56%).
    My feeling is that the big memory problem should be fixed! And this is a good news.
    #1001
    [quote quote=1000]After more than 18 hours the memory seems very stable! Now I have started the test with AiProtection ON, Web History ON with the backup on USB key every hour. The memory allocation is a 16% greater than the previous value (56%). My feeling is that the big memory problem should be fixed! And this is a good news.[/quote]
    thanks for update, yes others are also reporting a initial positive result regarding memory usage, will be interesting to see if AiProtection/USB usage is also managed well by the routers memory ?
    #1004
    gigios
    • Replies 27
    After +/- 6 hours the memory seems very stable also with AiProtection, Web History and backup on USB. Also others people confirms these data. This is, finally, a good and stable version!
    #1012
    [/quote]
    Memory usage is still looking consistent, even with AiProtection enabled ;)
    #1014
    gigios
    • Replies 27
    Yes! I confirm the stability of the memory.
    This is the last, with this build, memory report :)
    #1018
    Iggy82
    • Replies 8
    How’s the WiFi stability and performance?  That was my last problem before I sold it.
    I’ve just had this router returned to me since I sold it on eBay because the buyer was not happy with the WiFi range – ridiculous!  He thought the extra antenna’s would give a better range and decided to return it when it didn’t perform as he expected.
    I think I’m going to be stuck with this router forever!
    #1020
    The latest beta585 has removed memory leak issue and so far, wifi has improved from a stability perspective, one user has mentioned it has improved, but likewise, thE DSL-AC88U still does not support MU-MIMO etc, so limited improvements but it at last going in the correct direction.
    The fact that a purchaser from ebay has returned the router is ironic,  looks like the router and yourself are destined to be together forever ;)
    #1024
    AvatarOvercast_UK
    • Replies 1
    [quote quote=1018]I’ve just had this router returned to me since I sold it on eBay because the buyer was not happy with the WiFi range – ridiculous! He thought the extra antenna’s would give a better range and decided to return it when it didn’t perform as he expected. I think I’m going to be stuck with this router forever![/quote]That’s why I’ve not bothered to off-load the 2 I’ve got sat collecting dust here, I hate dealing with non-tech buyers on ebay at the best of times but knowing there’s potential for hassle with the firmware issues alone has stopped me selling on.
    I still monitor these threads in the hope one day they’ll create a working firmware.
    #1035
    Avatarjetspeed
    • Replies 50
    Good work guys. Thanks for posting your updates.
    Any idea when an official release is due? Surely can’t be too long now given the positive feedback…
    #1036
    [quote quote=1035]Good work guys. Thanks for posting your updates. Any idea when an official release is due? Surely can’t be too long now given the positive feedback…[/quote]
    I will ask them as to when a formal release maybe available?
