- This topic has 713 replies, 37 voices, and was last updated 3 weeks ago by
April 25, 2021 at 10:16 am #12968
[quote quote=12967]wow 77-78% hmmm bit high no? wondering if should get the AX86U now and modem instead….. doesn’t seem much room left in ram… Kev[/quote]
ASUS do run high in regards to Memory usage and it does have the Modem also. I would be worried at 90% for an ASUS, especailly if using a VPN ? but 80% is Ok,
As we have said before, early days in term of Firmware maturity ?
April 25, 2021 at 10:28 am #12970Once I enabled Traffic Analyzer and QoS the RAM usage went up. It was the same with my old DSL-AC68U.
April 25, 2021 at 12:46 pm #12971[quote quote=12967]wow 77-78% hmmm bit high no? wondering if should get the AX86U now and modem instead….. doesn’t seem much room left in ram… Kev[/quote]
Mine has 55% with 5 devices connected 4 WiFi + Lan PC, today after 6 hours only 4 MB increase, just make sure to deactivate unnecessary servers like FTP or SAMBA if you don’t really need it, by the way I deactivated AiProtection as well because I rely only on Kaspersky Internet security, so “kev2021” don’t worry about RAM
April 26, 2021 at 8:09 pm #12986April 27, 2021 at 5:13 am #12989from Sweden: https://www.dustinhome.se/product/5011209508/dsl-ax82u-ax5400-dual-band-wifi-6-xdsl-modem-router?ssel=false
April 27, 2021 at 6:31 am #12994Good to see there are different locations to buy a DSL-AX82U in Europe, as i said at the start, the DSL-AX82U is more aimed at the European markets, and availability only in Europe is proving this
April 28, 2021 at 11:01 pm #13001My modem arrived today and I started using it, but I don’t like the high RAM usage. 512 MB of RAM is not enough :(
April 29, 2021 at 5:03 am #13003[quote quote=13001]My modem arrived today and I started using it, but I don’t like the high RAM usage. 512 MB of RAM is not enough :([/quote]
I agree,, that is using to much RAM
what version firmware are you using ? are you using AiProtection, AiMesh or a VPN ?You need to login in order to vote
April 29, 2021 at 5:49 am #13004only AiProtection is active
Firmware Version:3.0.0.4.386_42438 (3.0.0.4.386_42438-g045583a)
April 29, 2021 at 6:04 am #13006[quote quote=13004]only AiProtection is active Firmware Version:3.0.0.4.386_42438 (3.0.0.4.386_42438-g045583a)[/quote]
When you have time, could you disable AiProtection and re-boot rooter, just to see if AiProtection is causing problem, After re-boot, leave router with AiProtection Off for 1 hour, then if memory usage is lower 70-80% then we know AiProtection is problem and I can inform ASUS
After test, re-enable AiProtection if you wish and did the RAM usage increase over time ?
April 29, 2021 at 11:10 am #13008Received this item last week and generally very very happy with it .Unit is on latest FW (20/4/2021) but i am now having to reset router AGAIN.This will be 5th time i will have to reset the unit
Issue i am having is – I am creating a unique username and password as the norm – Ai protection showing up as Green
But if i do not log back into the unit for say 2 or 3 days – it totally forgets the sign in details….
Also the captcha doesnt seem to be working either ??
Also in Ai Protection – even though i turn off UpNp it only shows up as orange / yellow (Not Green)
Or is there another menu i have to go to – to change aswell ??
April 29, 2021 at 11:52 am #13009Please ignore the above post from me – Seems to be issues with my dsl line
But the Ai Pro is still showing Orange/Yeloow when surely it should be Green when certain items are showing that they are off
April 29, 2021 at 12:19 pm #13010[quote quote=13009]Please ignore the above post from me – Seems to be issues with my dsl line But the Ai Pro is still showing Orange/Yeloow when surely it should be Green when certain items are showing that they are off[/quote]
No problem, I will ask ASUS regarding the UPnP and AiProtction showing Yellow and get them to add it to there debug list.
BTW – what is you DSL-AX82U RAM /Memory usage with AiProtection enabled ?
April 29, 2021 at 4:28 pm #13012April 29, 2021 at 4:40 pm #13013[quote quote=13012]My Ram usage with Ai Pro turned on is 363mb 71% total ram used[/quote]
@black-bird is noticing they have 94% RAM usage with AiProtection ?You need to login in order to vote
