Viewing 15 posts - 361 through 375 (of 712 total)
  • #15694
    • Replies 8,720
    [quote quote=15692]Thanks you so much UK Sentinel![/quote]
    #15700
    • Replies 1,039
    But Merlin featured by Gnuton is much more powerfull in my opinion and therefore prefered to take AX89.
    #15705
    Daron FutéDaron Futé
    • Replies 6
    If the XR500/1000 didn’t have upgrade issues, it would be number 1
    So, wouldn’t the netduma r2 which has a better update tracking be the best choice?
    I don’t need wifi so it doesn’t matter if it’s not wifi 6
    #15706
    • Replies 8,720
    My view is the Netduma R2 is good value for money but uses Mediatek Chipsets (not Broadcom or Qualcomm)
    • CPU1: MediaTek MT7621AT (880 MHz, 2 cores)
    • RAM1: 256 MiB (Nanya NT5CB128M16FP-DI)
    The ASUS ASUS RT-AC57U uses the same CPU, and in my view the Netduma R2 is an Entry level / cost friendly gaming router.
    #15707
    • Replies 6
    To manage 3 consoles and 1 pc it seem to be enought right?
    #15708
    • Replies 8,720
    [quote quote=15707]To manage 3 consoles and 1 pc it seem to be enought right?[/quote]
    Glad you are doing your research.
    Higher CPU Clock Speeds means more stuff is processed more quickly, and this in-turn reduces delay.
    Same applies for RAM, less need for CPU usage if you have more RAM
    I am sure the R2 will be OK, but not the Best !
    Note: DumaOS has lots of great features for gamers and is British
    #16230
    AvatarChelsea maniac
    • Replies 44
    Is there anyway to turn off those bleeding Aura RGB lights at a certain time, it is annoying in the bedroom at night so keep them off all the time. Just wondering if there is a setting you could turn them off about 12 midnight to 8 in the morning instead of turning them off by app. At the moment I just keep them off
    #16231
    • Replies 8,720
    Alas no, the Aura RGB lights are either On or Off
    #16232
    • Replies 44
    Cheers I think that is stupid, but hey ho
    #16233
    • Replies 8,720
    It does seem a missed opportunity. If you send A feedback form by the Routers UI, this with others that may have also complained might encourage ASUS to change this ;)
    #16236
    • Replies 1,039
    Take an edding and paint them black, so they will shine only weak.
    #16263
    • Replies 44
    Sent feedback, I will Just keep them turned off saves buying the tin of paint Grisu
    #16264
    • Replies 8,720
    [quote quote=16263]Sent feedback, I will Just keep them turned off saves buying the tin of paint Grisu[/quote]
    Not sure if you are aware, the button on Top at the front of the router allows you to tap thru the various light displays, when I had my DSL-AX82U plugged in last, I settled on a constant (not flashing) Red/Green (I forget which) which made a great night light for downstairs in the hallway
    #16274
    • Replies 44
    You sir are a star that is what I was looking for it turned off all those annoying bleeding lights and I do not have to tape the lights over now.
    Slight problem when I reboot the router it seems to drop about 10mb from when I first set it up any clues
    #16275
    • Replies 8,720
    Glad the routers lights are now sorted ;)
    usually when a dsl modem/router is rebooted it can take a day or so to get back to its previous synchs rate (speed) if there is not a problem etc.
    Give it a day or 3 and check again
