- This topic has 711 replies, 37 voices, and was last updated 1 month, 1 week ago by
El3rt1cal.
September 21, 2022 at 8:46 pm #20964
[quote quote=20959]it’s so weird, it fixed when I tried a different browser[/quote]
Makes sense, I will inform ASUS regarding EDGE browser compatibility
September 22, 2022 at 6:15 am #20965If anybody has the chance to see how well the new DSL-AX82U feature – WireGuard VPN works, that would be interesting.
September 22, 2022 at 10:12 pm #20967[quote quote=20964]
[/quote]I couldn’t be sure of that because I had looked at the mobile app before trying a different browser.
September 23, 2022 at 6:07 am #20968[quote quote=20967]I couldn’t be sure of that because I had looked at the mobile app before trying a different browser[/quote]
Understood, let me know if you still find problems with UI ?
September 25, 2022 at 2:33 pm #21002[quote quote=20846]I would assume the days of DSL Modem/Router combos and new units is coming to an end as FTTP/H is the new way forward.
But I will ask ASUS regarding DSL and DECT
[/quote]Im on Croatian ISP Hrvatski Telekom with this Asus DSL-AX82U Modem Router.
Today i had issue with it, refreshed PPPoE connection and IP normally at 5:30 AM as usual.
But for some unknow reason it lost PPPoE session(Internet Connection) at 7 AM but DSL Sync was still up.
For hours it wouldnt even try to get PPPoE up until i woke up at 10:30AM and went into WebGUI under WAN for Internet and hit Apply then it suddenly got new IP and Internet got up.
I checked on other people around me that have older Asus Modem Routers and are on same ISP as me(DSL-AC55U and DSL-AC51) and they where just fine.Can you check up with your Asus is this some bug with this model as on last nonBeta firmware they stated in Release Note that they fixed “Fixed Internet connection issue for specific ISPs” probably they didnt fixed it for my case.
On Hrvatski Telekom aka T-Com SNR Margin 6.1 dB on both on Download and Upload side is recommended from my ISP and they state that you shouldnt go under SNR 6 dB but from time to time my Upload SNR side from unknow reason drops to SNR 3.7 dB and stays there.
I can give you my ISP settings for xDSL if its needed for fixing my Internet PPPoE issue.
Thank you.
September 25, 2022 at 2:55 pm #21003Can you send a feedback form using the DSL-AX82U UI, if you put in subject box that you spoke with ‘UK Sentinel’ and explain problem, I can then speak with ASUS and see if they can find any issues / clues with your logs etc.
Let me know when you have sent feedback form and if you use the Same email address as the one you have used for this forum, I can ask ASUS to search via Email address etc. For feedback form .
September 27, 2022 at 6:46 pm #21019[quote quote=20968]
Understood, let me know if you still find problems with UI ?[/quote]
I’ve been using it for a few days now and I haven’t had a UI problem.
Other than that, some said they don’t work in “VDSL Stability Adjustment”.You need to login in order to vote
September 27, 2022 at 7:35 pm #21020[quote quote=21019]Other than that, some said they don’t work in “VDSL Stability Adjustment”.[/quote]
Is that with dsl-ax82u_9.0.0.4_388_20987-g900d10b_cferom_puresqubi.w ?
September 27, 2022 at 9:27 pm #21021[quote quote=21020]
Is that with dsl-ax82u_9.0.0.4_388_20987-g900d10b_cferom_puresqubi.w ?[/quote]
Yes, it doesn’t work in this beta version
September 27, 2022 at 9:44 pm #21022[quote quote=21021]Yes, it doesn’t work in this beta version[/quote]
September 28, 2022 at 12:57 pm #21025[quote quote=21022]
[/quote] I spoke with ASUS regarding DSL-AX82U and “VDSL Stability Adjustment” – ASUS confirmed they are in discussions with chipset manufacturer to get this looked into.You need to login in order to vote
September 28, 2022 at 9:06 pm #21026[quote quote=21025]
I spoke with ASUS regarding DSL-AX82U and “VDSL Stability Adjustment” – ASUS confirmed they are in discussions with chipset manufacturer to get this looked into.[/quote]
Thanks, this feature is very important for some and provides significant speed gain.
September 29, 2022 at 10:29 pm #21030Good to hear they are may get it fixed. I rely on stability adjustment to keep me at the maximum my package could allow and I have been using 3.0.0.4.386_45660-g37ee6d6 as it was the last one before they pulled VPN Fusion (which it seems this Beta finally reinstates)
September 30, 2022 at 8:45 am #21033When I spoke with ASUS, stability adjustment was a priority and something they do not won’t to remove.
This latest beta firmware for the DSL-AX82U had an updated DSL driver, hence the stability adjustment problem, I am just glad it was spotted by this Forum (@black bird)
September 30, 2022 at 4:15 pm #21047[quote quote=21002]Im on Croatian ISP Hrvatski Telekom with this Asus DSL-AX82U Modem Router[/quote]
Did you manage to send a feedback form to ASUS ?
