› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ASUS ZenWiFi AX Whole Home Tri-Band Mesh WiFi 6 System Not sure if this is the right place to ask…. I am thinking of upgrading my Google Mesh wifi to the above. Has anyone used this and does it...
- This topic has 1,420 replies, 25 voices, and was last updated 3 weeks, 6 days ago by
robgbc.
June 22, 2021 at 7:12 pm #14039
[quote quote=13971]Let us know if Teams has improved with 43181 this week
[/quote]Same problem exists with 43181. I have now turned off ipv6 and will continue testing this week. Really annoying and weird, no problems with streamlining or anything else just online meetings.
June 22, 2021 at 7:14 pm #14041Online meeting use VoIP usually ? any problems using other VoIP services ?
June 23, 2021 at 9:54 am #14046Also, without going to deep into your whole set-up, have you set-up or disabled SIP ALG (SIP Pass-through)
Just a thought ?
June 23, 2021 at 1:16 pm #14047[quote quote=14046]Also, without going to deep into your whole set-up, have you set-up or disabled SIP ALG (SIP Pass-through) Just a thought ?[/quote]
No idea what that is
. My set up for working from home is a workplace supplied Microsoft Surface Pro connected via USB-C to my home monitor’s HDMI.The Surface Pro has Windows 10 and Office 365, it uses Microsoft Teams to make calls and also online meetings.
June 23, 2021 at 1:36 pm #14048Whats your Router ?
Edit: From your ZenWifi go to Advanced Settings > WAN > NAT Passthrough (hopefully you have the NAT Passthrough Tab), then check to see what SIP Passthrough is set as ?
If ON then disable SIP Passthrough and see if that helps with Teams calls etc. ?
June 23, 2021 at 7:53 pm #14050[quote quote=14048]Whats your Router ? Edit: From your ZenWifi go to Advanced Settings > WAN > NAT Passthrough (hopefully you have the NAT Passthrough Tab), then check to see what SIP Passthrough is set as ? If ON then disable SIP Passthrough and see if that helps with Teams calls etc. ?[/quote]
The Surface Pro is connected via wireless to one of the ZenWifi nodes. Turning off ipv6 did not help much. I will try with SIP Passthrough disabled (it was enabled by default).
I had the same setup previously, but instead of the ZenWifi the Surface Pro was connected wireless to TP_Link powerline adapters (TL-WPA8630KIT V2).
June 23, 2021 at 8:07 pm #14052Interesting that SIP Passthrough was enabled (interesting for myself at least)
I forget, whats the ZenWifi nodes connecting too ?
June 23, 2021 at 8:30 pm #14054[quote quote=14052]Interesting that SIP Passthrough was enabled (interesting for myself at least)
<noscript>
</noscript>I forget, whats the ZenWifi nodes connecting too ?[/quote]The nodes are connected to a Nokia router provided by Hyperoptic
June 24, 2021 at 1:29 pm #14059These are the NAT Passthrough settings. Only thing I changed was SIP Passthrough to disabled
June 24, 2021 at 1:45 pm #14061June 25, 2021 at 3:55 pm #14067After more problems with Microsoft Teams yesterday, I decided to roll back to 42095 last night.
With 5GHz-2 set to following:
Wireless mode: Auto
Channel bandwidth: 160MHz
Control channel: Auto
The backhaul was only 80 MHz
I then changed it to:
Wireless mode: AX Only
Control channel: 124
Straight away backhaul changed to 160MHz
Microsoft Teams has been working fine today
Free RAM on 43181 (including 43169 & 43170) was around 200MB, on 42095 it is 240 MB
Sort this mess out Asus!!!!!!!
June 25, 2021 at 4:02 pm #14071Interesting, so on 42095 all works, but with same settings on 43181 etc, issue with teams ?
I bet you wish you purchased the Netgear Orbi
June 25, 2021 at 4:19 pm #14074[quote quote=14071]Interesting, so on 42095 all works, but with same settings on 43181 etc, issue with teams ? I bet you wish you purchased the Netgear Orbi
[/quote]The only difference in setting on 42095 compared to 43181:
I would have got the Orbi if it had the Parental Control. Orbi was much too expensive and no included Parental Control was the killer.
June 25, 2021 at 7:28 pm #14077I will test with the following settings on 43181 next week:
June 25, 2021 at 7:43 pm #14078[quote quote=14077]I will test with the following settings on 43181 next week: Wireless mode: AX Only Channel bandwidth: 160MHz Control channel: 124[/quote]
That would be an interesting exercise
