› UKTH forums › ๐ Wireless Routers & Modems › ASUS & Wireless › ASUS ZenWiFi AX Whole Home Tri-Band Mesh WiFi 6 System Not sure if this is the right place to ask…. I am thinking of upgrading my Google Mesh wifi to the above.ย Has anyone used this and does it...
- This topic has 1,410 replies, 25 voices, and was last updated 2 months, 4 weeks ago by
January 26, 2024 at 7:31 pm #30276
Good to know and very useful
January 27, 2024 at 1:27 pm #30284Good to see ASUS ZenWIFI XT8 Firmware version 3.0.0.4.388_24609 is on the UK Download Servers
January 27, 2024 at 1:59 pm #30286January 27, 2024 at 3:11 pm #30287Still none here for Asian Asus site.
If nothing by tomorrow, let us know and I will speak with ASUS
January 29, 2024 at 8:52 am #30327Still none here for Asian Asus site.
got my update just today.ย i had to upload manually after downloading from asus asian support site.ย i was trying to update via in-app and kept getting i was on the latest update…so did it manually.
will observe this new one now.
thanks again!
January 29, 2024 at 9:06 am #30328updated this morning to : ASUS ZenWIFI XT8 Firmware version 3.0.0.4.388_24609. (dowloaded manually from support site)
for now, all is working : vpn, remote desktop, ms teams calls, …
will inform if something unusual occurs.
This reply was modified 2 years, 2 months ago by
Jacky Decoster.
January 29, 2024 at 9:28 am #30330updated this morning to : ASUS ZenWIFI XT8 Firmware version 3.0.0.4.388_24609. (dowloaded manually from support site)
for now, all is working : vpn, remote desktop, ms teams calls, โฆ
January 29, 2024 at 9:46 am #30333got my update just today.ย i had to upload manually after downloading from asus asian support site.ย i was trying to update via in-app and kept getting i was on the latest updateโฆso did it manually.
thanks again!
January 31, 2024 at 6:17 pm #30348Hi,
I’m On 3.0.0.4.388_23285-g5068da5 which is stable without any issues, Wired backhaul all green.
I’m wondering if i should do the upgrade? i haven’t seen any feed back which support upgrade or ones voting against itWhat do you recon?
January 31, 2024 at 8:34 pm #30349Welcome, as this update includes several security improvements, I would suggest an upgrade is advisable.
I have not seen any negative feedback regarding this new firmware release for the ASUS XT8.
remember to take a backup of your current configuration before you upgrade, just incase this new XT8 firmware release proves to be unstable and you have to revert back
February 1, 2024 at 3:48 am #30350Hi,
Iโm On 3.0.0.4.388_23285-g5068da5 which is stable without any issues, Wired backhaul all green.
Iโm wondering if i should do the upgrade? i havenโt seen any feed back which support upgrade or ones voting against itWhat do you recon?
You should try updating. You can always go downgrade back to the firmware that worked best for you.
Jaime Salud Castillo.
February 2, 2024 at 8:23 am #30355I have updated to the latest firmware but have noticed since then in the system logs this happened loads. No idea what it means but have just submitted feedback/question via the interface. it is set manually to channel 1 as auto knocks the connection to the ring doorbell off otherwise.
Has anyone else noticed this?
Feb 1 23:06:36 acsd: eth4: COEX: downgraded chanspec 0x1803 to 0x1001: ctrl channel 1 SB not aligned with existing 40BSS
Feb 1 23:21:41 acsd: eth4: COEX: downgraded chanspec 0x1803 to 0x1001: ctrl channel 1 SB not aligned with existing 40BSS
Feb 1 23:51:46 acsd: eth4: COEX: downgraded chanspec 0x1803 to 0x1001: ctrl channel 1 SB not aligned with existing 40BSS
Feb 2 00:06:51 acsd: eth4: COEX: downgraded chanspec 0x1803 to 0x1001: ctrl channel 1 SB not aligned with existing 40BSS
Feb 2 00:21:56 acsd: eth4: COEX: downgraded chanspec 0x1803 to 0x1001: ctrl channel 1 SB not aligned with existing 40BSS
Feb 2 00:52:00 acsd: eth4: COEX: downgraded chanspec 0x1803 to 0x1001: ctrl channel 1 SB not aligned with existing 40BSS
Feb 2 01:07:03 acsd: eth4: COEX: downgraded chanspec 0x1803 to 0x1001: ctrl channel 1 SB not aligned with existing 40BSS
Feb 2 01:22:08 acsd: eth4: COEX: downgraded chanspec 0x1803 to 0x1001: ctrl channel 1 SB not aligned with existing 40BSS
Feb 2 01:37:13 acsd: eth4: COEX: downgraded chanspec 0x1803 to 0x1001: ctrl channel 1 SB not aligned with existing 40BSS
Feb 2 01:52:18 acsd: eth4: COEX: downgraded chanspec 0x1803 to 0x1001: ctrl channel 1 SB not aligned with existing 40BSS
Feb 2 02:07:21 acsd: eth4: COEX: downgraded chanspec 0x1803 to 0x1001: ctrl channel 1 SB not aligned with existing 40BSS
Feb 2 02:22:26 acsd: eth4: COEX: downgraded chanspec 0x1803 to 0x1001: ctrl channel 1 SB not aligned with existing 40BSS
Feb 2 02:37:31 acsd: eth4: COEX: downgraded chanspec 0x1803 to 0x1001: ctrl channel 1 SB not aligned with existing 40BSS
Feb 2 02:52:34 acsd: eth4: COEX: downgraded chanspec 0x1803 to 0x1001: ctrl channel 1 SB not aligned with existing 40BSS
Feb 2 03:07:39 acsd: eth4: COEX: downgraded chanspec 0x1803 to 0x1001: ctrl channel 1 SB not aligned with existing 40BSS
Feb 2 03:22:44 acsd: eth4: COEX: downgraded chanspec 0x1803 to 0x1001: ctrl channel 1 SB not aligned with existing 40BSS
Feb 2 03:37:48 acsd: eth4: COEX: downgraded chanspec 0x1803 to 0x1001: ctrl channel 1 SB not aligned with existing 40BSS
Feb 2 03:52:51 acsd: eth4: COEX: downgraded chanspec 0x1803 to 0x1001: ctrl channel 1 SB not aligned with existing 40BSSYou need to login in order to vote
February 2, 2024 at 9:23 am #30356Maybe they reduce bandwith to 20MHz, for 40MHz you need central channel 3.
February 2, 2024 at 9:27 am #30357I believe this is referencing channel ย 1 at 40MHz then switching to channel 1 at 20MHz
try changing bandwidth from Auto to Manual 20MHz if the message annoys you.
There is a cmd to tell you what Eth4 relates to but am out and about at the moment and will find it later.
February 2, 2024 at 9:32 am #30358Ok, An Update:
i have taken the plunge and upgraded my two XT 8 to 3.0.0.4.388_24609.
At the moment all seems to work fine, Noticed my WIFI throughput is a bit lower then expected (5G-2), Enabled the 160MHZ.
Will continue to monitor
Thanks for your support!
