Viewing 15 posts - 1,306 through 1,320 (of 1,421 total)
  • #34752
    AvatarLarryR
    • Replies 33
    Do the changes in the newly released BIOS appear to have any impact on actual Mesh or connectivity or is it all related to security for connecting TO the router? I know that’s important as well, but wondering if there are any “under the hood” changes that would impact stability or wifi usage etc.
    #34757
    • Replies 8,744
    The ASUS GT-BE98 Pro, RT-AX86U_Pro and a few others ASUS models have had this new release available to them an so far no real issues around AiMesh stability has been reported.
    I appreciate early days and changelog reads more around Security improvements (certs, buffer handling and data processing workflows) etc.
    FWIW, I did hear that malware was effecting certain ASUS routers, hence these quick Firmware releases.
    Always nice to have a volunteer to try first
    #34763
    AvatarNicky
    • Replies 58
    Well I updated to 3.0.0.4.388_24684 (v1 flavour) about 8 hours ago. The only issue I had was with some of my 2.4G devices not reconnecting, so I just turned off the 2.4G radio for a few seconds, turned it back on and everything came back up. I can’t report on any node issues because mine are all hard wired.
    Now let’s see if it holds up.
    #34764
    • Replies 8,744
    Congrats on being the first Forum member to try this new firmware release 3.0.0.4.388_24684 (v1).
    #34766
    • Replies 634
    . dodgydrains Said:
    ASUS ZenWiFi XT8 Firmware version 3.0.0.4.388_24684
    V1 – https://dlcdnets.asus.com/pub/ASUS/wireless/ZenWiFi_XT8/FW_ZENWIFI_XT8_300438824684.zip?model=ASUS%20ZenWiFi%20AX%20(XT8)
    V2 – https://dlcdnets.asus.com/pub/ASUS/wireless/ZenWiFi_XT8/FW_XT8_V2_300438824684.zip?model=ASUS%20ZenWiFi%20AX%20(XT8)
    I have been testing this for nearly 24 hours.  Seems stable for my use case on 160MHz wireless backhaul.
    #34800
    AvatarNicky
    • Replies 58
    It’s been over 2 days and nothing untoward. It looks like a stable update for me.
    #34801
    • Replies 8,744
    Great news so far
    #34915
    AvatarLarryR
    • Replies 33
    I run GNUton firmware on my primary router, and Asus latest on my aimesh node.
    I have a scheduled reboot set for 6am Sunday mornings, just to clear thing out and avoid memory leak issues etc… About 45 minutes after reboot I and seeing this in the log. Anything to worry about?
    Nov 17 06:45:24 kernel: CPU: 1 PID: 1719 Comm: asd Tainted: P O 4.1.52 #1
    Nov 17 06:45:24 kernel: Hardware name: Generic DT based system
    Nov 17 06:45:24 kernel: task: d22b7c00 ti: d3672000 task.ti: d3672000
    Nov 17 06:45:24 kernel: PC is at 0xb6906fbc
    Nov 17 06:45:24 kernel: LR is at 0xb6907e14
    Nov 17 06:45:24 kernel: pc : [<b6906fbc>] lr : [<b6907e14>] psr: 20010010
    Nov 17 06:45:24 kernel: sp : be885340 ip : b691b150 fp : 00000000
    Nov 17 06:45:24 kernel: r10: b690a458 r9 : b690a2d4 r8 : 00000000
    Nov 17 06:45:24 kernel: r7 : 01763b50 r6 : be885360 r5 : 017639d0 r4 : 01769f48
    Nov 17 06:45:24 kernel: r3 : 0000676f r2 : b6500928 r1 : 00000400 r0 : 00000000
    Nov 17 06:45:24 kernel: Flags: nzCv IRQs on FIQs on Mode USER_32 ISA ARM Segment user
    Nov 17 06:45:24 kernel: Control: 10c5387d Table: 1370804a DAC: 00000015
    Nov 17 06:45:24 kernel: [<c0026f20>] (unwind_backtrace) from [<c0022cf8>] (show_stack+0x10/0x14)
    Nov 17 06:45:24 kernel: [<c0022cf8>] (show_stack) from [<c04d329c>] (dump_stack+0x8c/0xa0)
    Nov 17 06:45:24 kernel: [<c04d329c>] (dump_stack) from [<c003abc8>] (get_signal+0x490/0x558)
    Nov 17 06:45:24 kernel: [<c003abc8>] (get_signal) from [<c0022290>] (do_signal+0xc8/0x3ac)
    Nov 17 06:45:24 kernel: [<c0022290>] (do_signal) from [<c0022718>] (do_work_pending+0x94/0xa4)
    Nov 17 06:45:24 kernel: [<c0022718>] (do_work_pending) from [<c001f58c>] (work_pending+0xc/0x20)
    Nov 17 06:45:29 rc_service: service 12078:notify_rc restart_firewall
    #34916
    • Replies 8,744
    Looks like the asd Tainted (“asd” daemon crashed) and then restarts and the “restart_firewall” is called by “asd” after it restarts.
    (The ASD from a Linux perspective  stands for ‘anything-sync-daemon’ I believe and handles temp files and writing them to storage etc.)
    • This reply was modified 2 years ago by UK SentinelUK Sentinel. Reason: added details "restart_firewall" is called by "asd"
    #34917
    • Replies 8,744
    As a follow on and to brake the following down a little ..
    • CPU:  = Central processing Unit
    • 1 PID = Uniquely identifier for an active process (LINUX)
    • 1719 Comm = Shared memory channel
    • asd Tainted = ‘anything-sync-daemon’ is in an unsupported state because it cannot be guaranteed to function correctly.
    • P O 4.1.52 #1 = I do not know but assume memory or space allocation etc
    Note: anything-sync-daemon (asd) is a tiny pseudo-daemon designed to manage user defined dirs in tmpfs and to periodically sync back to the physical disc (HDD/SSD).
    Q. Have you any third party storage devices plugged in if not then maybe just a bug in the underlying code ?
    #34927
    AvatarOltex8
    • Replies 3
    Much thanks to all that post in this forum.  In the past 2 years since owning 3 of these ASUS units this forum has been by far the most helpful.
    Background intro:  My setup is quantity 3 of these Zenwifi AX units.  All are only in AP mode. I purchased them to leverage the 3rd band for a high speed bridge for a few wired devices at different points in the home where I did not have wired Ethernet.  It is only since the last two firmware updates that I could go a complete week without having to reboot the system as the 3rd band would drop leaving the mesh running only on the 2.5 slow band (yellow line).  Indeed it was so frustrating that I finally decided to spend the money to install Ethernet to enable Ethernet backhaul between the 3 units (which I understand was also troublesome until the past few updates).  My general goal is stability sufficient to allow for only monthly reboots.  Prior to this most recent update I have not been able to get past a week.  Finally I am now at ten days and cautiously optimistic.
    Additional info on this latest release:  I also have seen “tainted” entries in my log since the last update, but they were for the http daemon.  Also on the first reboot after this most recent update while the Ethernet backhaul came up fine and was showing traffic one of the mesh satellite units had an entry in the wifi log as being connected via the 2.5 even though it was on Ethernet backhaul.   I rebooted the system again and that issue cleared.
    Prior to buying this ASUS system I had three Apple AirPort Extreme units in a different home that ran flawlessly in AP only mode between monthly reboots.  Hopefully ASUS will get us to that point while this hardware generation remain supported :-)
    • This reply was modified 2 years ago by AvatarOltex8.
    #34929
    • Replies 8,744
    Welcome, like many others glad you are enjoying the journey with your ASUS ZenWiFi XT8’s
    #35020
    AvatarNicky
    • Replies 58
    I just got the notification of an update to ” 3.0.0.4.388_24688-gf94212b”. I bit the bullet, now lets see.
    Anyway, I thought they were going to include monthly reboots in the next update?
    #35021
    • Replies 8,744
    ASUS ZenWiFi XT8 Firmware version 3.0.0.4.388_24688 update is a security update after a recent malware problem all ASUS routers have had.
    ASUS have said that monthly reboot feature is now included in their SW roadmap, this could in theory take several months before we see it in end user devices unfortunately.
    #35022
    • Replies 634
    The changelog seems exactly the same as 24684.
    It looks like 24686 is only released for V1 and V2 is still on 24684 (I am checking on the Asus UK site).
    Also, on the UK site I can only see 24684 (for V1) and 24684 (for V2).  The older FW releases are not there.
