› UKTH forums › 🛜 Wireless Routers & Modems › AVM & Wireless › AVM FRITZ!Box 7530 AX – Official Thread Looks like AVM announced a while back their new DSL FRITZ!Box 7530 AX which supports supervectoring (35b) and Wifi 6 standards https://en.avm.de/products/fritzbox/fritzbox-7530-ax/ Not sure if it is yet for...
- This topic has 101 replies, 5 voices, and was last updated 6 months, 3 weeks ago by
- February 22, 2021 at 8:37 am #12131
@lukenevill-bond – I was not able to show my Fritz!Box Spectrum until after weekend (As gaming router / rig plugged in) .
I agree all initial connection have the dip, but Your PSD Mask is both excessive and misshaped with others I have seen in the past.
My Cab is Huawei and I am just wondering if it is because your Cab is ECI and hence why a different initial drop profile compared to both @Grisu and mine ?
Will be interesting if you have the opportunity this week to plug back in you original 7530 and compare Spectrum profiles etc.
Note: Both my Fritz!Box (Lantiq) and my DSL-AX82U (Broadcom) show similar Spectrum profiles relative to Cab ?
Fritz!Box 3490
DL-AX82U
February 22, 2021 at 9:12 am #12135With new 7.2x firmwares (not available for your antique 3490 maybe in some months) you will see upload spectrum (SNR) too.
February 22, 2021 at 9:20 am #12139I love my 3490
but yes is getting old
February 22, 2021 at 9:24 am #12140@uk-sentinel my cabinet is Huawei which is why I paired it with a Broadcom chipset. But I’ll plug in the Lantiq 7530 at some point just to get an image of the Spectrum though to see if there are any differences.
February 22, 2021 at 10:50 am #12141Probably you wont see any relevant differences, seems to be filters in the line or on other end which are responsible for this low SNR in lower spectrum.
February 22, 2021 at 11:23 am #12142Probably you wont see any relevant differences, seems to be filters in the line or on other end which are responsible for this low SNR in lower spectrum.
Grisu was right. I quickly plugged in the Lantiq 7530 but it wasn’t worth take a screenshot as the spectrum was pretty much the same. It must be set that way at the DSLAM or something as mentioned previously. Two pages who have similar results than me.
https://blog.wirelessmoves.com/2018/06/why-is-my-snr-so-bad-at-2-mhz.html
February 22, 2021 at 11:43 am #12144February 22, 2021 at 12:22 pm #12146Here the answer:
Do they still have ADSL on your cable, otherwise it could do much better if they remove their filters.
February 22, 2021 at 12:32 pm #12148Here the answer: https://community.bt.com/t5/Archive-Staging/Large-Notch-around-1-6-2Mhz-in-my-VDSL-Spectrum/m-p/1758350/highlight/true#M881389 Do they still have ADSL on your cable, otherwise it could do much better if they remove their filters.
Yeah you can still order standard ADSL. It’s FTTC so still copper wire from cabinet to my premises as well. How I long for the days where they finally roll out FTTP. I’ve attached an image of what BT Wholesale sees my line should be capable of. Currently only syncing at 68megabits down/16megabits up on the router of course but maybe that will improve and get closer to those high targets if SNR goes down further.
February 22, 2021 at 1:00 pm #12150Thanks @Grisu ,Â
For anybody else reading this thread: ADSL maxis out at 2Mhz, hence why initial dip in spectrum to stop VDSL signal swamping ADSL signal upto 2Mhz.
This must have a impact on total bandwidth throughput potential, but whilst ADSL services are still available and being used, not much can be done if service meets quoted SLA speeds etc.
Seems you have the option of FTTP on-Demand, but not a cheap option
February 22, 2021 at 1:23 pm #12152Seems you have the option of FTTP on-Demand, but not a cheap option
Yeah don’t like to think how much the cost would come to which includes installation and then monthly fee for like 3 years I think?
But if the option is available then I assume that it might be pretty easy for them to install FTTP when it comes round to them actually doing it properly as part of the rollout.
February 22, 2021 at 3:09 pm #12153FTTP on-Demand runs from your cab at the end of your road along existing trunking occupied by Copper wires normally, so relatively time consuming and fiddly especially if your on a long line,
We can all dream
November 3, 2022 at 10:15 pm #21533I have question regarding FritzBox 7530AX for my local friend as he got it few days ago.
Internet and VoIP is working fine but he needs to make IPTV via ISP STB to work.The problem is that FritzBox 7350AX doesnt have any settings via WebGUI to setup WAN interface for IPTV in this case Bridged VLAN ID.
I tryed editing config file,ect…. and still doesnt work.If anyone has working IPTV config file to make this work i would be grateful.
November 4, 2022 at 8:16 am #21537Sorry, never used TV or made manual manipulations in config (although this is possible with little knowlegde how to do).
What I know for sure is that here (in my coutry) the config for TV is done by provider from ACS.
And there is no workaround for it and you wont get credentials too, even if you are able to modify config on your own.You could analyze a working box cofigured for TV for this provider and might patch your config accordingly.
Passthrough mode wont help I think, but maybe even worth a try.It might be similar to manually config VoIP, where you are able to set different VLAN-ID in advanced telefony connection settings, but nothing to do this for TV in GUI.
Most knowledge about AVM-boxes are found in ip-phone-forum.de, possibly they could help.PS: Why is your posting under mine, I already saw it when writing and #21536 is less than #21537?
November 4, 2022 at 8:19 am #21536 - AuthorPosts
