Viewing 15 posts - 91 through 105 (of 1,130 total)
  • #3771
    blackgear25
    • Replies 8
    [quote quote=3557]
    samba and ftp server is enabled. i just closed and free ram go to 18 mb 🙂
    😉[/quote]
    i have same problem :( i closed everyting but ram is always low and modem doing ping.
    • Replies 8,718
    @blackgear25
    Have you tried factory resetting router and configuring settings from scratch, not restoring from back-up?
    #3784
    blackgear25
    • Replies 8
    [quote quote=3773] @blackgear25 Have you tried factory resetting router and configuring settings from scratch, not restoring from back-up?[/quote]
    yes i try everyting but same.
    #3785
    • Replies 8,718
    Understood – If you can send a feedback form from the routers UI and mention you have spoken with UK Sentinel, and I will drop them a message also
    Thanks for letting us know ;-)
    #3869
    Avataralifrm
    • Replies 5
    hi , i use lastet firmware (DSL-AC51_1.1.2.3_743-gf5b4545) on Asus Dsl Ac51
    but ram is always low and modem And the modem sometimes freezes
    To fix this, I have to reset the modem to factory settings.
    This problem has been with me for a long time.
    please help me
    #3871
    • Replies 8,718
    Does switching power Off and waiting five minutes and then turning power back On fix this ?
    When modem freezes, can you still gain access to UI ?
    #3881
    Avatarlostcause
    • Replies 53
    [quote]hi , i use lastet firmware (DSL-AC51_1.1.2.3_743-gf5b4545) on Asus Dsl Ac51
    but ram is always low and modem And the modem sometimes freezes[/quote]
    Have the same router and no freezes yet. Free RAM fluctuates between 4 MB – 10 MB free. Max 93% RAM in use.
    What I did notice are the following quirks;
    Router throughput WAN>LAN fluctuates between 50MBit/s – 75 Mbit/s . Only once I saw 95 Mbit/s which is close enough to the actual Fast Ethernet LAN ports on this router.
    Toggling the radio ON/OFF by designating the WPS button to it causes irregular behavior. Sometimes the radio wont turn ON or OFF, or only the 2.4 Ghz radio and so forth. Seems you have to press > 10 seconds for stable behavior.
    When you turn OFF the 5 Ghz radio through the WEB_ui and power cycle the router. The 2.4 Ghz radio and the 5 Ghz radio wont turn ON any more. So then you need to connect the LAN cable to get into the WEB_ui again ;-(
    Have not experienced modem freeze yet, but its still early days for me.
    #4503
    • Replies 8,718
    DSL ASUSWRT Beta firmware v9.1.2.3_783 now available, feel free to post on your forum. Release note as follows. Thanks.
    Normal Beta T&C’s Apply – ASUS beta
    Now supports DSL Line Diagnostic for DSL-N16/DSL-AC51/DSL-AC750 models even these models with no USB port support(with limited time log capture).
    Protection Server enhanced with lock time backoff. 1) Record each IP address with fail count. 2) Add lock rule for each IP address. 3) Lock all if too many rules at a same time.
    New Live Update mechanism adopted.
    Fixed failed to work with the OpenVPN profile of Avira issue.
    Fixed PPTP client failed to work with ppp-2.4.7 module issue. (UKTH)
    Fixed wrong OpenVPN server state issue.
    OpenVPN server: update default compression to yes.
    Fixed OpenVPN wrong type conversion/ Fixed wrong state after client run successfully.
    cfg_manager: fixed the problem that PPPoE Username can’t use ‘$’
    Added new Lebanon ISP Ogero, ADSL WAN(ATM) profile into QIS manual setting list.
    Added new Italy ISP Vodafone, VDSLWAN(PTM) profile into QIS manual setting list.
    2019_09_06_v9.1.2.3_783-g4cb10eb
    https://www.asuswebstorage.com/navigate/a/#/s/8DF21FF35D4E46F092D567B3B305AA7BY
    #4514
    Avatarlostcause
    • Replies 53
    Thanks ! Will try it out.
    #4610
    AvatarAlexandr82
    • Replies 2
    [quote quote=4503]DSL ASUSWRT Beta firmware v9.1.2.3_783 now available, feel free to post on your forum.[/quote]
    Hi! Where is DSL-N66U?
    #4614
    • Replies 8,718
    [quote quote=4610]
    Hi! Where is DSL-N66U?[/quote]
    Hi,  firmware for the DSL-N66U is indeed not available/listed, I will ask ASUS why this was not included
    #4641
    • Replies 8,718
    I have spoken with ASUS and they have now added the latest firmware for the DSL-N66U to the original download link/set.
    ASUS will continue to provide updates for this router model, but had assumed no demand and hence removed from list.
    DSL-N66U_9.1.2.3_783-g4cb10eb.trx.zip
    Edit: ASUS have just given me this direct link to the latest firmware for the DSL-N66U
    https://www.asuswebstorage.com/navigate/a/#/s/1EB2A125096D4BA893AFD7AFDC9DC2EFY
    #4731
    AvatarBlay3r
    • Replies 1
    I hope Asus won’t cut support for DSL-N66U
    #4734
    • Replies 8,718
    [quote quote=4731]I hope Asus won’t cut support for DSL-N66U [/quote]
    Your DSL-N66U is safe for a couple for years
    #4898
    • Replies 8,718
    DSL ASUSWRT Beta firmware v9.1.2.3_790-g61d41b5 now available, release note as follows. Please feel free to share on your forum.
    2019_10_22_v9.1.2.3_790-g61d41b5
    https://www.asuswebstorage.com/navigate/a/#/s/DCA82E56805A43F08909A0D2BABB63A8Y
    Fixed Feedback feature failed to work issue, issue specifically occur with earlier beta v9.1.2.3_783.
    Fixed possible invalid feedback status leads to no logs download link issue(under feedback sent failure state). (UKTH)
    Web UI > Android/iOS Router app icon updated.
    Fixed Web UI related issues.
    (does not resolve VPN and memory loss issues raised by some owners), but please do advise if these assumptions are incorrect
