UKTH forums 🛜 Wireless Routers & Modems ASUS & Wireless Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support...
Viewing 15 posts - 46 through 60 (of 1,130 total)
  • #2505
    babis3gbabis3g
    • Replies 7
    New Beta… v9.1.2.3_676-g33e7375
    https://www.asuswebstorage.com/navigate/a/#/s/89D7B5A12BC54CA7B946AC9B77BEED94Y
    Sorry no change log yet, Thanks
    • Replies 8,459
    Thanks babis3g for latest updates from ASUS ;-)
    #2524
    babis3gbabis3g
    • Replies 7
    v9.1.2.3_676
    – [MT751x] xDSL Driver updated – v5.5.2.11_20190226, fixed Turkey ISP Turk Telekom DSLAM compatibility issue. Which leads to longer than expected sync time.
    – [MT751x] Fixed 5GHz band invalid RSSI value which leads to WiFi coverage issue.
    – New input field “ASUS Service No./Case#” added for Feedback form.
    – Fixed various security related issues.
    – Fixed VoIP service fail issue after Dual WAN fail back occurred.
    – Support OpenVPN option “extra-certs”, as Private Tunnel VPN use this option now.
    – [MT751x] Fixed 2.4GHz band after some connected clients frequently switch in Power Saving/Power Active mode after the screen is turned off, there is a probability that the Power Saving state machine maintained by the AP will fail and cannot enter the PS completion state(APPS_RETRIEVE_DONE). Now timing detection mechanism added.
    – Fixed OpenVPN username/ password with special character % failed to work issue.
    – Fixed static route rule cannot work if the rule is for second WAN interface issue.
    – Remove DSL Modulation > G.DMT mode auto switch function based on data rate observed.
    – Fine tune DHCP leases > expire time display format.
    – Dual WAN ping target timeout(3 times), changed to 8.8.8.8 instead.
    – Fixed Router app failed to prompt for a new version of firmware for update issue.
    – Fixed various Web UI related issues.
    AvatarErkkinimi
    • Replies 2
    Hi, thank you for the firmware you delivered. I have dsl-n66u and default credentials should be admin admin, but i cant login. I have latest beta v9.1.2.3_676-g33e7375.
    Can you help me?
    AvatarErkkinimi
    • Replies 2
    Double post sorry
    • Replies 8,459
    Double post sorry
    HAve you tried turning router on, leaving it for a few minutes and then turning back on.
    Yes I believe default username and password is still admin / admin, was this your password before beta applied or have you done a factory reset?
    #2938
    Avatardividex
    • Replies 2
    Having testing these betas with dsln55u_d1. My external WAN interface (to 4G modem)  connection drops time to time. I Have problems getting reconnected. I have tried ip link set nas10 down and up and killing/starting udhcpd without success. Only reboot recovers connection. Any ideas for this?
    How to get own startup scripts working on these new betas? The old guides doesn’t not work. I have placed my watchog script under /yaffs -folder.
    • Replies 8,459
    Firstly – have you try after loading the latest firmware, performing  factory rest and rebuild config from scratch, not restoring from backup?
    Has this always been an issue, or just with recent beta firmware’s ?
    #2941
    Avatardividex
    • Replies 2
    I am using the latest beta, although this problem have been there as far as I remember. I have done factory reset, and recovered the settings from backup file, so I haven’t build config from scratch. That’s for sure one point to consider.
    Logger error is: “Your ISP’s DHCP does not function correctly”. This seems to be common problem for Asus devices.
    For my questions, can anybody provide knowledge of these:
    1. recovering the WAN interface thru script, without just forcing reboot?
    2. if reboot is the only way, (which always do the job), what is the way run my watchdog script at reboot? I use cron file to run script, but need to copy cron file at every startup.
    • Replies 8,459
    Who’s your ISP (4G Modem) ?
    Are you using the DSL (modem) part of your ASUS router also or is it just 4G modem?
    #2947
    • Replies 1,002
    did you ever try this?
    service restart_wan
    • Replies 8,459
    Or…. (I believe both options should work) but never tried it myself
    service stop_wan
    service start_wan
    #2951
    • Replies 1,002
    only easier with one command ;-)
    • Replies 8,459
    I am using the latest beta, although this problem have been there as far as I remember. I have done factory reset, and recovered the settings from backup file, so I haven’t build config from scratch. That’s for sure one point to consider. Logger error is: “Your ISP’s DHCP does not function correctly”. This seems to be common problem for Asus devices. For my questions, can anybody provide knowledge of these:
    I spoke with ASUS and they believe the issue you describe has been resolved/fixed in latest release stock firmware.
    Okay, I wonder which firmware version customer using? Please inform user to update to latest v1.1.2.3_674, if not yet done then reset to default and try again.
    https://www.asus.com/Networking/DSLN55U_D1/HelpDesk_Download/
    #2957
    • Replies 1,002
    Direct download link: https://dlcdnets.asus.com/pub/ASUS/wireless/DSL-N55U_D1/FW_DSL-N55U-D1_1123674.zip
