Viewing 15 posts - 436 through 450 (of 718 total)
  • #7260
    AvatarMrk26
    • Replies 465
    Like for 5h (if I’m correct) is not too bad. Keep an eye on stats. If they get worse you can try to disable SRA (you have how to few pages back in this thread). On zyxel when I capped line SRA was always disabled (same on asus dsl-ac88u). So I was thinking why after whole week my line is still interleaved with vigor (really low amount of errors and line capped). Then @Uk Sentinel reminded me SRA settings, so once I turn it off after 5 days I had fastpath enabled on my line with vigor.
    #7261
    Bully
    • Replies 386
    Could I have capped the speed instead of tweaking snr?
    Is there anywhere i can get a list of commands and their descriptions, so I can understand what they are and what they change?
    #7262
    AvatarMrk26
    • Replies 465
    Well on draytek you increase snr what is equivalent to cap command on broadcom based modems (but on broadcom you can cap booth downstream and upstream where on vigor only downstream ) . However I personally think that on draytek is better because you increase snr as much as is needed, on broadcom based modem you have to guess at what cap what snr you will get. In manual for draytek vigor 130 should be section with all commands described.
    #7263
    For all things CLI DrayTeK, take a look at attachment
    [download id="6366"]
    #7264
    Bully
    • Replies 386
    [quote quote=7263]For all things CLI DrayTeK, take a look at attachment DrayTek-CLIRef-2016-1-3.pdf (5 downloads) [/quote]
    Downloaded and looked at this numerous time since owning the 130.  Does not explain SRA etc.
    #7265
    Page 176 – to disable
    I think @Mrk26 and I did this over @ https://uktechhub.com/forums/topic/draytek-vigor2760/
    #7267
    AvatarMrk26
    • Replies 465
    Post 7038, page 24 in this thread https://uktechhub.com/forums/topic/rt-ac86u-384-16/page/24/#post-7038
    #7268
    Bully
    • Replies 386
    Thanks.
    #7269
    [quote quote=7268]Thanks.[/quote]
    ‘give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime’
    (Lao Tsu)
    Enjoy your Fishing
    #7270
    Bully
    • Replies 386
    You cant beat a good Chinese proverb.  I have some but they are not suitable for this forum LOL
    #7271
    [quote quote=7270]You cant beat a good Chinese proverb. I have some but they are not suitable for this forum LOL [/quote]
    Thank you for your diplomacy
    #7334
    Bully
    • Replies 386
    Today’s stats
    vdsl status
    DS Actual Rate          : 30000000 bps   US Actual Rate       : 10723000 bps
    DS Attainable Rate      : 38845672 bps   US Attainable Rate   : 10679305 bps
    DS Interleave Depth     :     1339       US Interleave Depth  :        1
    NE Current Attenuation  :       20 dB    Cur SNR Margin       :        8  dB
    DS actual PSD           :     6. 5 dB    US actual PSD        :    13. 4  dB
    NE CRC Count            :        1       FE CRC Count         :     4076
    NE ES Count             :        1       FE  ES Count         :     2656
    Xdsl Reset Times        :        0       Xdsl Link  Times     :        4
    VDSL Firmware Version   : 05-07-09-0F-01-07   [with Vectoring support]
    > vdsl status more
    LOS          :      2               0
    FECS         :   9531            54499 (seconds)
    ES           :      1            2656 (seconds)
    UAS          :     34            87446 (seconds)
    CRC          :      1            4076
    INP          :      0              40 (symbols)
    InterleaveDelay :      0            1600 (1/100 ms)
    NFEC         :    255              61
    LSYMB        :   2877            10252
    INTLVBLOCK   :    255              61
    > vdsl status counts
    [ Counters: Showtime ]
    ElapsedTime  :   98340            98340 (seconds)
    CRC          :      0            4076
    FEC          :   9528            54499
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0            2656
    SES          :    718              31
    LOSS         :      2               1
    UAS          :      0               0
    LOFS         :      0               0
    [ Counters: 15Min ]
    ElapsedTime  :    227             227 (seconds)
    CRC          :      0               0
    FEC          :      0               0
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0               0
    SES          :      0               0
    LOSS         :      0               0
    UAS          :      0               0
    LOFS         :      0               0
    [ Counters: 1DAY ]
    ElapsedTime  :   26327            26327 (seconds)
    CRC          :      0               0
    FEC          :   4834               1
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0               0
    SES          :      0               0
    LOSS         :      0               0
    UAS          :      0               0
    LOFS         :      0               0
    #7344
    AvatarMrk26
    • Replies 465
    Probably best stats I ever seen on your line. Did you turned off SRA?
    #7352
    Bully
    • Replies 386
    [quote quote=7344]Probably best stats I ever seen on your line. Did you turned off SRA?[/quote]
    no, I have not touched SRA.
    #7406
    Bully
    • Replies 386
    Today’s stats
    DS Attainable Rate      : 38459224 bps   US Attainable Rate   : 10666565 bps
    DS actual PSD           :     6. 5 dB    US actual PSD        :    12. 9  dB
    > vdsl status more
    LOS          :      2               0
    FECS         :   57708420            54500 (seconds)
    CRC          :      1            4076
    NFEC         :    255              61
    LSYMB        :   2877            10252
    INTLVBLOCK   :    255              61
    > vdsl status counts
    ElapsedTime  :   174228            174228 (seconds)
    CRC          :      0            4076
    FEC          :   57708417            54500
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0            2656
    SES          :    718              31
    LOSS         :      2               1
    UAS          :      0               0
    LOFS         :      0               0
    [ Counters: 15Min ]
    ElapsedTime  :    802             802 (seconds)
    CRC          :      0               0
    FEC          :   415254               0
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0               0
    SES          :      0               0
    LOSS         :      0               0
    UAS          :      0               0
    LOFS         :      0               0
    [ Counters: 1DAY ]
    ElapsedTime  :   26902            26902 (seconds)
    CRC          :      0               0
    FEC          :   21207931               0
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0               0
    SES          :      0               0
    LOSS         :      0               0
    UAS          :      0               0
    LOFS         :      0               0
