Bully.
- May 6, 2020 at 11:39 am #7025
Output from vdsl optn
vdsl optn
%% adsl optn FUNC [us/ds/bi [value/on/off]]
%% FUNC : ‘trellis’, ‘bitswap’, ‘sra’, ‘retx’, ‘aelem’, ‘virtualnoise’, ’20bit’, ‘status’, ‘g.v
%% us/ds/bi : upstream or downstream or bidirection.
%% ‘aelem’ and ‘g.vector’ are only on/off.
%% value : bitswap=0~2, sra=0,2,3,4, 20bit=0~2.
%% on/off : enable/disable.
%% PS, some commands are only available for VDSL2.
%% some commands are only available for later modem code.
%% For G.Vector feature, CPE’s modem firmware needs to support VDSL2 G.Vector.You need to login in order to vote
May 6, 2020 at 11:49 am #7026I just looked at the DrayTeK 2760 manual and Cmd is the same for adjusting SRA ?
But does show cmd – adsl optn status rather than vdsl optn status options ? so DrayOS maybe older coding style/standard etc ?
May 6, 2020 at 12:00 pm #7027Right, while lunch brake I have few attempts but only command “vdsl optn sra bi 2” indicate changes as per screenshot, however after reboot SRA is still “ON”. Should I reboot or no?
May 6, 2020 at 12:23 pm #7029Did you use this to save cfg before reboot “vdsl savecfg ” ?
Yes reboot after entering cmd “vdsl optn sra bi 2 off” again and the savecfg cmd to save configuration
Fingers crossed
May 6, 2020 at 12:33 pm #7030No, didn’t used “vdsl savecfg “, I knew it that go too smooth.
may try again later…You need to login in order to vote
May 6, 2020 at 1:23 pm #7031No, didn’t used “vdsl savecfg “, I knew it that go too smooth.
may try again later…hee-hee
May 6, 2020 at 4:24 pm #7036Done all as per above instructions, after reboot same output.
DrayTek> vdsl optn default
trellis [US] = ON, [DS] = ON.
bitswap [US] = 0, [DS] = 0.
[0: default(ON), 1: ON, 2: OFF]
sra [US] = 0, [DS] = 0.
[0: default(=3), 2: OFF, 3: ON , 4: DYNAMIC_SOS]
retx [US] = ON, [DS] = ON.
vpcs 0xff
virtualnoise [US] = ON, [DS] = ON.
20bit [US] = 0, [DS] = 0.
[0: default, 1: ON, 2: OFF]
UPBO aelem ON
G.Vector ONYou need to login in order to vote
May 6, 2020 at 4:41 pm #7038Right, finally got it :
DrayTek> vdsl optn status
sra [US] = 2, [DS] = 2.
vpcs 0xff
UPBO aelem ON
G.Vector ONCorrect commands are :
vdsl savecfg
Reboot
@UK Sentinel
If you think our last few posts are irrelevant to this thread please move to vigor section
Sorry for messing up in your thread
May 6, 2020 at 4:57 pm #7041Congrats – let us know how it goes
May 6, 2020 at 5:00 pm #7042May 6, 2020 at 6:31 pm #7043You guys have been busy in here today
I only have a laptop and do not want to leave it on over night plugged into mains to do any graphs.
xdslcmd profile –show
Modulations:
G.Dmt Disabled
G.lite Disabled
T1.413 Disabled
ADSL2 Disabled
AnnexL Disabled
ADSL2+ Disabled
AnnexM Disabled
VDSL2 Enabled
VDSL2 profiles:
8a Enabled
8b Enabled
8c Enabled
8d Enabled
12a Enabled
12b Enabled
17a Enabled
30a Enabled
US0 Enabled
Phone line pair:
Inner pair
Capability:
bitswap On
sra On
trellis On
sesdrop Off
CoMinMgn Off
24k On
phyReXmt(Us/Ds) Off/On
TpsTc AvPvAa
monitorTone: On
dynamicD: On
dynamicF: Off
SOS: On
Training Margin(Q4 in dB): -1(DEFAULT)xdslcmd info –stats
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 12222 Kbps, Downstream rate = 49704 Kbps
Bearer: 0, Upstream rate = 12198 Kbps, Downstream rate = 39994 KbpsLink Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.6 6.1
Attn(dB): 19.5 0.0
Pwr(dBm): 13.4 6.7
VDSL2 framing
Bearer 0
MSGc: 18 20
B: 31 238
M: 1 1
T: 64 63
R: 10 16
S: 0.0255 0.6235
L: 13200 3272
D: 1283 1
I: 42 255
N: 42 255
Counters
Bearer 0
OHF: 97879003 533601
OHFErr: 76 0
RS: 3225643728 2765574
RSCorr: 625931 7
RSUnCorr: 3550 0Bearer 0
HEC: 622 0
OCD: 28 0
LCD: 28 0
Total Cells: 1272800060 0
Data Cells: 824453921 0
Drop Cells: 0
Bit Errors: 0 0ES: 28 2655
SES: 0 31
UAS: 26 86680
AS: 240120Bearer 0
INP: 3.50 0.00
INPRein: 0.00 0.00
delay: 8 0
PER: 2.45 9.85
OR: 78.26 21.09
AgR: 40072.04 12219.06Bitswap: 164180/165203 17/17
Total time = 1 days 18 hours 42 min 26 sec
FEC: 625931 7
CRC: 76 0
ES: 28 2655
SES: 0 31
UAS: 26 86680
LOS: 0 1
LOF: 0 1
LOM: 0 0
Latest 15 minutes time = 12 min 26 sec
FEC: 24288 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 1032 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 18 hours 42 min 26 sec
FEC: 149261 0
CRC: 9 0
ES: 2 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 264066 3
CRC: 30 0
ES: 12 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 2 days 18 hours 41 min 59 sec
FEC: 625931 7
CRC: 76 0
ES: 28 2655
SES: 0 31
UAS: 0 86654
LOS: 0 1
LOF: 0 1
LOM: 0 0DSLAM type / SW version: IFTN:0xd086 (208.134) / v0xd086
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime: 2 days 18 hours 42 min 0 sec
Resyncs: 0 (since 06 May 2020 19:28:10)Downstream Upstream
Connection speed (kbps): 39994 12198
SNR margin (dB): 6.6 6.1
Power (dBm): 13.4 6.7
Interleave depth: 1283 1
INP: 3.50 0
Vectoring status: 5 (VECT_UNCONFIGURED)RSCorr/RS (%): 0.0194 0.0003
RSUnCorr/RS (%): 0.0001 0.0000
May 6, 2020 at 6:40 pm #7044bitswap On
sra OnInteresting, time to disable bitswap I think ;-)
May 6, 2020 at 6:54 pm #7045That is a big burst
FEC: 24288 0
FEC: 1032 0Not bigger than on previous modem but still quite big.
@Uk Sentinel
On my line not much difference errors wise with SRA off.
Did you consider to get BT to check your line or you prefer to play with modem first. 😉
May 6, 2020 at 7:03 pm #7046That is a big burst Latest 15 minutes time = 12 min 26 sec FEC: 24288 0 Previous 15 minutes time = 15 min 0 sec FEC: 1032 0 Not bigger than on previous modem but still quite big. @Uk Sentinel On my line not much difference errors wise with SRA off. @Bully Did you consider to get BT to check your line or you prefer to play with modem first. 😉
Yeah not sure what to do, I am off work now till Monday morning. Would i need to reboot modem at all if i change stuff?
May 6, 2020 at 7:15 pm #7047 - AuthorPosts
