› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › RT-AC86U 384.16 Hi, I updated to the latest Merlin firmware this morning (about 9 am) and since doing so my NE CRC count has gone up to 326598 over 5 hours. ...
- This topic has 717 replies, 4 voices, and was last updated 6 years, 1 month ago by
Bully.
May 11, 2020 at 8:47 pm #7179May 12, 2020 at 6:02 pm #7214
xdslcmd info –stats
Status: Showtime
Retrain Reason: 1
Max: Upstream rate = 12244 Kbps, Downstream rate = 49648 Kbps
Bearer: 0, Upstream rate = 11999 Kbps, Downstream rate = 34999 KbpsLink Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 8.3 6.2
Attn(dB): 19.6 0.0
Pwr(dBm): 13.2 6.7
VDSL2 framing
Bearer 0
MSGc: 18 159
B: 47 236
M: 1 1
T: 61 2
R: 16 16
S: 0.0436 0.6283
L: 11736 3247
D: 1485 1
I: 64 255
N: 64 255
Counters
Bearer 0
OHF: 109124132 610669
OHFErr: 21 0
RS: 856394643 525470
RSCorr: 406286 9
RSUnCorr: 2208 0Bearer 0
HEC: 610 0
OCD: 18 0
LCD: 18 0
Total Cells: 2424721298 0
Data Cells: 817174876 0
Drop Cells: 0
Bit Errors: 0 0ES: 1649 7965
SES: 11 93
UAS: 98 260258
AS: 291543Bearer 0
INP: 8.00 0.00
INPRein: 0.00 0.00
delay: 16 0
PER: 2.67 10.40
OR: 71.86 126.83
AgR: 35071.00 12125.70Bitswap: 226153/226153 74/76
Total time = 1 days 3 hours 40 min 11 sec
FEC: 16748412 77
CRC: 40092 0
ES: 1649 7965
SES: 11 93
UAS: 98 260258
LOS: 1 3
LOF: 10 3
LOM: 0 0
Latest 15 minutes time = 10 min 11 sec
FEC: 601 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 1468 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 3 hours 40 min 11 sec
FEC: 16811 0
CRC: 1 0
ES: 1 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 97503 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 3 days 8 hours 59 min 1 sec
FEC: 406286 9
CRC: 21 0
ES: 4 2655
SES: 0 31
UAS: 0 86757
LOS: 0 1
LOF: 0 1
LOM: 0 0DSLAM type / SW version: IFTN:0xd086 (208.134) / v0xd086
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime: 3 days 8 hours 52 min 3 sec
Resyncs: 0 (since 12 May 2020 19:00:41)Downstream Upstream
Line attenuation (dB): 19.6 0.0
Connection speed (kbps): 34999 11999
SNR margin (dB): 8.5 6.2
Power (dBm): 13.3 6.7
Interleave depth: 1485 1
INP: 8.00 0
Vectoring status: 5 (VECT_UNCONFIGURED)RSCorr/RS (%): 0.0497 0.0004
RSUnCorr/RS (%): 0.0003 0.0000
May 12, 2020 at 9:05 pm #7217If won’t get worse than is now, after few more days DLM should reduce INP to 3 and delay to 8ms. Also I think one of your posts was missed where you indicated noise during the phone call. If noise was really bad I wouldn’t wait much longer, just report fault to ISP. You may be lucky as you are with BT so big chances that they will send engineer your way.
May 17, 2020 at 1:02 pm #7246I have notice my Asus 86u LAN port 1 is now only showing a speed of 100 mbps instead of 1000 mbps ?
**EDIT** – Ignore this, i unplugged and re-plugged cable in LAN 1 and now is showing full 1000mbps.
May 17, 2020 at 1:24 pm #7249I have notice my Asus 86u LAN port 1 is now only showing a speed of 100 mbps instead of 1000 mbps ? **EDIT** – Ignore this, i unplugged and re-plugged cable in LAN 1 and now is showing full 1000mbps.
self diagnosis
May 17, 2020 at 1:28 pm #7250It was was even showing on the switch it was plugged into as 100 mbps, its not now.
May 17, 2020 at 1:32 pm #7251‘If technology (in all its forms) was easy, everybody would be doing it well’
Edit, forgot to ask, hows modem ?
May 17, 2020 at 1:43 pm #7252May 17, 2020 at 1:51 pm #7253No improvements. I have to confess, I have switched back the the Draytek 130 this morning. I am using the latest alternative firmware (Vigor 130 3.8.4.1 Alternative Modem Code 579F17), I have tweaked vdsl snr +25 to up my snr to 8db to reduce errors. I am going to monitor it for a week and see how it goes. If this has no improvements then we will call BT.
May 17, 2020 at 2:23 pm #7254Vigor is good, I believe it’s just need tweak settings to turn it on to the beast. Once I turn off SRA on mine I actually observe smallest amount of errors since I remember.
May 17, 2020 at 2:25 pm #7255Any tweaking advice would be appreciated
Stats –
DS Actual Rate          : 31925000 bps   US Actual Rate       : 10712000 bps
DS Attainable Rate      : 39476632 bps   US Attainable Rate   : 10742688 bps
DS Interleave Depth     :     1337       US Interleave Depth  :        1
NE Current Attenuation  :       20 dB    Cur SNR Margin       :        8  dB
DS actual PSD           :     6. 4 dB    US actual PSD        :    12. 9  dB
NE CRC Count            :        3       FE CRC Count         :     4076
NE ES Count             :        1       FE  ES Count         :     2656
Xdsl Reset Times        :        0       Xdsl Link  Times     :        3
ITUÂ Version[0]Â Â Â Â Â Â Â Â Â Â :Â fe004452Â Â Â Â Â Â Â ITUÂ Version[1]Â Â Â Â Â Â Â :Â 41590000
VDSL Firmware Version   : 05-07-09-0F-01-07   [with Vectoring support]
COÂ ITUÂ Version[0]Â Â Â Â Â Â Â :Â b5004946Â Â Â Â Â Â Â COÂ ITUÂ Version[1]Â Â Â Â :Â 544ed086
DSLAMÂ CHIPSETÂ VENDORÂ Â Â Â :Â <Â IFTNÂ >
> vdsl status more———————- ATU-R Info (hw: annex A, f/w: annex A/B/C) ———–
Bitswap      :      0               1
LOSÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
LOFÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
LPRÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
LOMÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
NCDÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
LCDÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
FECSÂ Â Â Â Â Â Â Â Â :Â Â Â 4152Â Â Â Â Â Â Â Â Â Â Â Â 54497Â (seconds)
ESÂ Â Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 1Â Â Â Â Â Â Â Â Â Â Â Â 2656Â (seconds)
SESÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â 31Â (seconds)
LOSSÂ Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 1Â (seconds)
UASÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â 40Â Â Â Â Â Â Â Â Â Â Â Â 87409Â (seconds)
CRCÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 3Â Â Â Â Â Â Â Â Â Â Â Â 4076
INPÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â 40Â (symbols)
InterleaveDelay :      0            1600 (1/100 ms)
NFECÂ Â Â Â Â Â Â Â Â :Â Â Â Â 255Â Â Â Â Â Â Â Â Â Â Â Â Â Â 64
RFECÂ Â Â Â Â Â Â Â Â :Â Â Â Â Â 16Â Â Â Â Â Â Â Â Â Â Â Â Â Â 16
LSYMBÂ Â Â Â Â Â Â Â :Â Â Â 2874Â Â Â Â Â Â Â Â Â Â Â Â 10696
INTLVBLOCKÂ Â Â :Â Â Â Â 255Â Â Â Â Â Â Â Â Â Â Â Â Â Â 64
AELEMÂ Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â —-You need to login in order to vote
May 17, 2020 at 2:32 pm #7256May 17, 2020 at 2:33 pm #7257This is mine with SRA off for over 130h constantly running:
DrayTek> vdsl status counts
[ Counters: Showtime ]
ElapsedTime  :   404280            404280 (seconds)
CRCÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â 588Â Â Â Â Â Â Â Â Â Â Â Â 51778
FECÂ Â Â Â Â Â Â Â Â Â :Â Â Â 9141Â Â Â Â Â Â Â Â Â Â Â Â 4010947
HECÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
CRC_PÂ Â Â Â Â Â Â Â :Â Â Â Â 421Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
CRCP_PÂ Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
CVP_PÂ Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
ESÂ Â Â Â Â Â Â Â Â Â Â :Â Â Â Â 480Â Â Â Â Â Â Â Â Â Â Â Â 46719
SESÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â 67
LOSSÂ Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â 1934
UASÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
LOFSÂ Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
[ Counters: 15Min ]
ElapsedTime  :    851             851 (seconds)
CRCÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 2Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 1
FECÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â 24Â Â Â Â Â Â Â Â Â Â Â Â Â Â 10
CRC_PÂ Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
ESÂ Â Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 2Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 1
SESÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
LOSSÂ Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
[Â Counters:Â 1DAYÂ ]
ElapsedTime  :   31451            31451 (seconds)
CRCÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â 42Â Â Â Â Â Â Â Â Â Â Â Â Â Â 26
FECÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â 747Â Â Â Â Â Â Â Â Â Â Â Â Â 264
CRC_PÂ Â Â Â Â Â Â Â :Â Â Â Â Â 37Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
ESÂ Â Â Â Â Â Â Â Â Â Â :Â Â Â Â Â 40Â Â Â Â Â Â Â Â Â Â Â Â Â Â 25
DrayTek>
May 17, 2020 at 2:39 pm #7258[ Counters: Showtime ]
ElapsedTime  :   16119            16119 (seconds)
FECÂ Â Â Â Â Â Â Â Â Â :Â Â Â 4257Â Â Â Â Â Â Â Â Â Â Â Â 54497
CRC_PÂ Â Â Â Â Â Â Â :Â Â Â Â Â Â 1Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
[ Counters: 15Min ]
ElapsedTime  :    504             504 (seconds)
CRCÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
FECÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â 107Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
ESÂ Â Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
ElapsedTime  :   18504            18504 (seconds)
LOFSÂ Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0You need to login in order to vote
May 17, 2020 at 3:23 pm #7259 -
- The topic ‘RT-AC86U 384.16 Hi, I updated to the latest Merlin firmware this morning (about 9 am) and since doing so my NE CRC count has gone up to 326598 over 5 hours. ...’ is closed to new replies.
