Bully.
- May 25, 2020 at 9:17 pm #7658
[quote quote=7652]The G.fast Faceplate sounds interesting, as it for G.fast and VDSL and has a newer REIN filter, seems only MK1 had no REIN Filter, MK2 had the First REIN filter and by the MK3 they changed the standard REIN filter, MK4 also has a REIN filter and is the latest faceplate offered by BT until G.fast install is required when the G.fast faceplate is used with NTE5C Master Socket. I think that correct ?[/quote]
yeah I looked at the g.fast faceplate but it was rather expensive.
May 25, 2020 at 9:32 pm #7659[quote quote=7652]The G.fast Faceplate sounds interesting, as it for G.fast and VDSL and has a newer REIN filter, seems only MK1 had no REIN Filter, MK2 had the First REIN filter and by the MK3 they changed the standard REIN filter, MK4 also has a REIN filter and is the latest faceplate offered by BT until G.fast install is required when the G.fast faceplate is used with NTE5C Master Socket. I think that correct ?[/quote]
May 26, 2020 at 6:39 am #7665£30 for new G.fast faceplate./Master Socket, yes a luxury rather than a necessity
May 26, 2020 at 6:48 am #7666Not looking too good –
DS Actual Rate : 30000000 bps US Actual Rate : 10555000 bps
DS Attainable Rate : 44330160 bps US Attainable Rate : 10724607 bps
DS Interleave Depth : 1549 US Interleave Depth : 1
NE Current Attenuation : 20 dB Cur SNR Margin : 8 dB
DS actual PSD : 6. 5 dB US actual PSD : 13. 0 dB
NE CRC Count : 1 FE CRC Count : 4080
NE ES Count : 1 FE ES Count : 2658
Xdsl Reset Times : 0 Xdsl Link Times : 1
VDSL Firmware Version : 05-07-09-0F-01-07 [with Vectoring support]
Test Mode : DISABLE
DSLAM CHIPSET VENDOR : < IFTN >
> vdsl status more———————- ATU-R Info (hw: annex A, f/w: annex A/B/C) ———–
Near End Far End Note
Trellis : 1 1
Bitswap : 1 1
ReTxEnable : 0 0
VirtualNoise : 0 0
20BitSupport : 0 0
LatencyPath : 0 0
LOS : 0 0
LOF : 0 0
LPR : 0 0
LOM : 0 0
SosSuccess : 0 0
NCD : 0 0
LCD : 0 0
FECS : 170812 54526 (seconds)
ES : 1 2658 (seconds)
SES : 0 31 (seconds)
LOSS : 0 1 (seconds)
UAS : 34 88462 (seconds)
HECError : 0 0
CRC : 1 4080
RsCorrection : 0 0
INP : 0 45 (symbols)
InterleaveDelay : 0 1600 (1/100 ms)
NFEC : 255 55
RFEC : 16 16
LSYMB : 2832 10664
INTLVBLOCK : 255 55
AELEM : 0 —-
> vdsl status counts[ Counters: Showtime ]
ElapsedTime : 40328 40328 (seconds)
CRC : 1 4080
FEC : 170812 54526
HEC : 0 0
CRC_P : 0 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 1 2658
SES : 0 31
LOSS : 0 1
UAS : 0 0
LOFS : 0 0
[ Counters: 15Min ]
ElapsedTime : 363 363 (seconds)
CRC : 0 0
FEC : 315 0
HEC : 0 0
CRC_P : 0 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 0 0
SES : 0 0
LOSS : 0 0
UAS : 0 0
LOFS : 0 0
[ Counters: 1DAY ]
ElapsedTime : 46263 46263 (seconds)
CRC : 1 4080
FEC : 170812 54526
HEC : 0 0
CRC_P : 0 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 1 2658
SES : 0 31
LOSS : 0 1
UAS : 0 0
May 26, 2020 at 6:50 am #7667Yeah, and personally I don’t think the G.fast one will make much difference on vdsl. Very similar design to Mk4, only higher frequency filter which is not used on vdsl.
May 26, 2020 at 6:54 am #7669[quote quote=7667]Yeah, and personally I don’t think the G.fast one will make much difference on vdsl. Very similar design to Mk4, only higher frequency filter which is not used on vdsl.[/quote]
I think so to, I might purchase the MK4 , just in the name of science or ask @Bully to post one to me as he has several by now
May 26, 2020 at 7:09 am #7672[quote quote=7666]Not looking too good [/quote]
I wonder if your telephone extension is not shorted somewhere. If you can do quiet line test with everything plugged in as it is now but do test on telephone extension.
May 26, 2020 at 8:35 am #7674I just ordered a new BT Openreach NTE5C MK2 + MK4 Faceplate to replace my existing MK2 Faceplate and NTE5A Master socket,
Looking forward to see if DSL stats change / improve ?
May 26, 2020 at 8:42 am #7676I didn’t know you have issues with your line? I though last time problem was solved. Hope you order one with clear idc connectors, these colour ones (blue and red) was faulty, apparently.
May 26, 2020 at 8:54 am #7677[quote quote=7676]I didn’t know you have issues with your line? I though last time problem was solved. Hope you order one with clear idc connectors, these colour ones (blue and red) was faulty, apparently.[/quote]
My line is fine, just thought I would try a newer one, in the name of science and improved stats
I will start a new thread with my results , save clogging this one .
May 26, 2020 at 5:12 pm #7678Nearly 24 hrs –
vdsl status
DS Attainable Rate : 43852080 bps US Attainable Rate : 10638504 bps
DS actual PSD : 6. 5 dB US actual PSD : 12. 9 dB
NE CRC Count : 1 FE CRC Count : 4083
NE ES Count : 1 FE ES Count : 2661
Test Mode : DISABLE
Trellis : 1 1
Bitswap : 1 1
ReTxEnable : 0 0
VirtualNoise : 0 0
20BitSupport : 0 0
LatencyPath : 0 0
LOS : 0 0
LOF : 0 0
LPR : 0 0
LOM : 0 0
SosSuccess : 0 0
NCD : 0 0
LCD : 0 0
FECS : 714015 54530 (seconds)
ES : 1 2661 (seconds)
HECError : 0 0
CRC : 1 4083
RsCorrection : 0 0
NFEC : 255 55
RFEC : 16 16
LSYMB : 2832 10664
INTLVBLOCK : 255 55
AELEM : 0 —-
ElapsedTime : 72948 72948 (seconds)
CRC : 1 4083
FEC : 714015 54530
HEC : 0 0
CRC_P : 0 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 1 2661
SES : 0 31
LOSS : 0 1
UAS : 0 0
LOFS : 0 0
[ Counters: 15Min ]
ElapsedTime : 849 849 (seconds)
CRC : 0 0
FEC : 111226 0
HEC : 0 0
CRC_P : 0 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 0 0
SES : 0 0
LOSS : 0 0
UAS : 0 0
LOFS : 0 0
[ Counters: 1DAY ]
ElapsedTime : 83649 83649 (seconds)
CRC : 1 4083
FEC : 714015 54530
HEC : 0 0
CRC_P : 0 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 1 2661
SES : 0 31
LOSS : 0 1
UAS : 0 0
May 26, 2020 at 5:22 pm #7679That is like nine times worse than previous day stats. You clearly must have issue with extension line. If you want (it’s absolutely safe once you take off filtered faceplate) lift up extension idc clamp and remove telephone extension cables and test for 24h without. If you want go further I will check with multimeter if they are not shorted somewhere. How looks like your extension socket? If you have issues with telephone extension that is probably what killed previous faceplate.
Edit.
Only last 15 mins you had more FEC errors than previous 24h…
May 26, 2020 at 5:31 pm #7682May 26, 2020 at 5:44 pm #7683Trouble is that @Bully proved yesterday with previous stats on test socket that his line is really not bad. And I’m sure that either telephone socket is faulty or telephone? It’s easy to test.
Either test for 24h with telephone unplugged (extension connected in master socket), and test for 24h with extension line disconnected from master socket.
May 26, 2020 at 5:50 pm #7686 - AuthorPosts
