Viewing 15 posts - 181 through 195 (of 1,442 total)
  • #1320
    • Replies 8,739
    Try beta585, just to make sure ;)
    Long shot, also try unplugging unit for 30 mins (or longer) then plug back in as this has worked for me in the past with real early Alpha firmware’s
    #1321
    AvatarAgi47
    • Replies 5
    [quote quote=1320]Try beta585, just to make sure 😉 Long shot, also try unplugging unit for 30 mins (or longer) then plug back in as this has worked for me in the past with real early Alpha firmware’s[/quote]
    i need th asus rescue mode utility cant find it power light flashing all time
    #1322
    • Replies 634
    [quote quote=1321] i need th asus rescue mode utility cant find it power light flashing all time[/quote]
    Have you tried this:
    DSL-AC88U Recovery Mode (Rescue Mode) and Clearing NVRAM Guide
    #1323
    AvatarAgi47
    • Replies 5
    i did all that, on 585 now still no 5g and i cant connect to 2.4g, 5g dose not show in Wireless Log and no light its dead tbo with you all i cant aford a new one. :(
    #1325
    AvatarNyzlia
    • Replies 8
    For those with WIFI dying how long was it before it did die?
    On old router i had when 2.4GHz died it was in the first week.
    #1326
    • Replies 634
    [quote quote=1323]i did all that, on 585 now still no 5g and i cant connect to 2.4g, 5g dose not show in Wireless Log and no light its dead tbo with you all i cant aford a new one. 🙁[/quote]
    This has 3 year warranty I think.  Get in contact with Asus.
    #1327
    • Replies 8,739
    As @dodgydrains says, these DSL-AC88U have a three year warranty and you have tried the obvious options to fix issue, so defo return router to supplier if at all possible?
    #1328
    • Replies 634
    Do you know if Asus will get round to fixing BuferBloat on the DSL-AC88U?
    My cheap TalkTalk provided DSL3782 rates A and this rates as B or C.
    #1329
    • Replies 8,739
    [quote quote=1328]Do you know if Asus will get round to fixing BuferBloat on the DSL-AC88U? My cheap TalkTalk provided DSL3782 rates A and this rates as B or C.[/quote]
    April 2017 I was using the DSL-AC88U and chatting to ASUS regarding BufferBloat, ASUSWRT for DSL-AC88U does not and never will support – Smart Queue Management (SQM) algorithms such as cake, fq_codel, PIE etc. to reduce the effects of buffer bloat.?
    Bufferbloat is a big subject, with very many factors, enabling QoS and setting the download speed t0 5-10% below your attainable speed offers the biggest single measurable fix. but beyond that, it is not a pure gaming router, as Such.
    #1330
    • Replies 634
    Thanks for that, it is silly that a cheap router from ISP handles this better than the more expensive 3rd party one.
    Just had another BT engineer visit due to errors and line fault.  He did a port change (I think in the cabinet).  Would this have resulted in a DLM reset?  Line now has 1265 interleaving and G.998.4 (G.INP) no longer showing.  Sync now 64630 kbps with max rate 77342 kbps.
    Is it now a case of waiting to see what DLM does?  If so how long is the wait for G.998.4 (G.INP) to be enabled?
    • Replies 8,739
    Looks like you are back on Interleave (Downstream) so hopefully G.INP should come back in around 3-4 days if nothing else has issues.
    BT must love you ;)
    #1333
    • Replies 634
    [quote quote=1332]Looks like you are back on Interleave (Downstream) so hopefully G.INP should come back in around 3-4 days if nothing else has issues. BT must love you 😉[/quote]
    Luckily I knew the guys, the last one used to live a few streets away from me.  I have basically had everything changed that could be changed.
    Am I right in thinking that G.INP reduces the errors and increases sync and maximum attainable?  I was previously told by TalkTalk to wait up to 48 hours for DLM to do it’s thing.
    #1335
    AvatarAgi47
    • Replies 5
    it a week were just keep rebooting the modem then 5g stop working anyway whats the best to get now with gfast
    #1336
    • Replies 8,739
    [quote quote=1335]it a week were just keep rebooting the modem then 5g stop working anyway whats the best to get now with gfast[/quote]
    Can you start a new Thread, as hopefully others will find this very useful also
    • Replies 8,739
    @dodgydrains – In theory, yes should reduce errors and DLM to do is thing in 2 days is optimistic, but depends on line condition etc.
