› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS – DSL-AC88U / DSL-AC3100 Firmwares (beta's) etc. Looks like a new Beta Release for the DSL-AC88U is available, this version has Telnet enabled and improved 2.4GHz wifi (I believe). DSL-AC88U_v9.10.06_build581_debug.w.zip https://www.asuswebstorage.com/navigate/s/604D61534F2541D1B3CE1CC031A697E4Y   UK Sentinel In a completely...
Viewing 15 posts - 226 through 240 (of 1,439 total)
  • #1408
    • Replies 8,689
    Hi @NoFixedAddress, no problem. I only have beta586 for DSL-AC88U ?
    #1409
    Avatarnofixedaddress
    • Replies 6
    Hi @nofixedaddress, no problem. I only have beta586 for DSL-AC88U ?
    That would be great, thank you.
    #1416
    AvatarCozak
    • Replies 20
    AI Protection still has high cpu use with latest beta when performing a file copy over Wi-Fi.
    File copy speed drops from 60MB/s with AI off to ar0und 13MB/s with it on.
    #1417
    • Replies 6
    AI Protection still has high cpu use with latest beta when performing a file copy over Wi-Fi. File copy speed drops from 60MB/s with AI off to ar0und 13MB/s with it on.
    Confirmed.
    Reverting back to build585 as https://forums.whirlpool.net.au/forum-replies.cfm?t=2606692&r=57560437#r57560437 has gotten worse. Since updating to build586, symptoms begin immediately.
    Once unit has finished powering on/rebooting, Used RAM is no longer at 175MB at first, it is now immediately at 250MB. The CPU1/CPU2 graphs max out with normal download use/without cause.
    Worst though, WLAN file transfers no longer get a 50-60MB/s speed at first, it is now 12-13MB/s permanently.
    #1418
    • Replies 8,689
    @nofixedaddress and @Cozak  – Stock build585 had a DSL Driver update, this is included in beta build586, just need to see if one of you did a factory reset after latest Beta, just to eliminate all other factors?
    But do agree, does not sound promising.
    R.S.V.P.
    #1419
    • Replies 6
    @nofixedaddress and @cozak – Stock build585 had a DSL Driver update, this is included in beta build586, just need to see if one of you did a factory reset after latest Beta, just to eliminate all other factors? R.S.V.P.
    As always.
    #1420
    • Replies 8,689
    ‘As Always’, you are well trained ;) – so an issue it is and stock585 does not have this issue?
    We both need to let ASUS know this, back to our testing days, all we need now is babis3g  ;)
    #1421
    • Replies 6
    ‘As Always’, you are well trained 😉 – so an issue it is and stock585 does not have this issue? We both need to let ASUS know this, back to our testing days, all we need now is babis3g 😉
    Correct, and have indeed advised Asus.
    #1422
    • Replies 8,689
    Great – hopefully @cozak can also confirm  that Build 585 does not have this issue and only 586 does, then I will let ASUS know also ?
    #1423
    AvatarCozak
    • Replies 20
    I’ve not yet tried the stock firmware 585. I’ve been away from home since Friday so just went straight to the latest beta.
    I’ll flash the latest official firmware shortly and see what happens.
    #1424
    • Replies 8,689
    @Cozak – thank you
    #1425
    AvatarCozak
    • Replies 20
    To confirm, problem is also present on 585 official firmware.
    Copying a large file over Wi-Fi from my laptop to my server (on Ethernet) and the copy speed is 13MB/s.
    #1426
    • Replies 8,689
    To confirm, problem is also present on 585 official firmware. Copying a large file over Wi-Fi from my laptop to my server (on Ethernet) and the copy speed is 13MB/s.
    That is interesting, as one person says build585 works well with file copy, I know it is a lot to ask, did you manage to do a factory reset after loading buid585 (stock)?
    #1427
    AvatarCozak
    • Replies 20
    • To confirm, problem is also present on 585 official firmware. Copying a large file over Wi-Fi from my laptop to my server (on Ethernet) and the copy speed is 13MB/s.
    <!–more–>Remember there is a bug where AI can show as enabled in the UI when it’s not (following a reboot) . Suggest other user reflashes official firmware then toggles ai off and back on again then tries another copy.
    Factory reset has never worked for me so I’m reluctant to do one without the above being confirmed first. It highly likely that ai was not working due to the aforementioned bug.
    #1428
    • Replies 8,689
    Good idea, I think I will dig out my DSL-AC88U tomorrow and give it a go with both versions, BTW usually you can tell if AiProtection is working if memory usage is around 240MB (ish)
    Thanks for you assistance and totally understand all is flashing/factory resetting is a real pain ;)
