Viewing 15 posts - 271 through 285 (of 1,439 total)
  • #1486
    oxygen8
    • Replies 38
    [quote quote=1484]
    If money is no object, then I would go for the new ASUS RT-AX88U and this is newly supported by RMerlin, early days yet for ASUSWRT-Merlin, but 4 core 1.8GHz CPU and 1GB Ram 😉[/quote]
    Oh, I just saw that beast maybe I will buy it when it is on sales, it looks very similar to the RT-AC3100, so my next question is, would you recommend the RT-AC3100?
    #1487
    • Replies 8,718
    The RT-AC3100 is a dual core 1.4Ghz unit with 512MB Ram, nice unit, but nothing special, the RT-AC86U has dual 1.8Ghz processors,  slightly newer wifi chips, but only has three antennas, so depends how many wifi client’s you plan to use and wifi usage in general?
    Both have strengths and weaknesses,
    #1488
    oxygen8
    • Replies 38
    [quote quote=1487]The RT-AC3100 is a dual core 1.4Ghz unit with 512MB Ram, nice unit, but nothing special, the RT-AC86U has dual 1.8Ghz processors, slightly newer wifi chips, but only has three antennas, so depends how many wifi client’s you plan to use and wifi usage in general?[/quote]
    Yeah, you are right, the only logical upgrade I see is the RT-AX88U, good antennas, no TriBand, high CPU speed, I would had never discovered if it wasn’t for this forum, at least I owe that to the DSL-AC88U
    #1489
    • Replies 8,718
    Some good coming from not so good ;)
    #1490
    oxygen8
    • Replies 38
    Back to my RT-AC3200, it feels so fast with Merlin UI and stuff, back to my 240mb/s with AiProtection active, my next target will definitely be the RT-AX88U, the difference in gigantic.
    #1491
    AvatarKitsuneDave
    • Replies 24
    [quote quote=1478]
    As you are one of those lucky users on G.fast, if you use the ASUS UI – Feedback form and send ASUS a message saying, speeds issue with AiProtection and mention UK Sentinel and tick all check boxes, then I will after you confirm you have done this, I will drop ASUS an email also to advise this is what you are doing, this way they have another DSL-AC88U user with AiProtection throughput issues to look at 😉[/quote]
    I did as you requested, mentioned the issue and your name with all the info collected. Whether the firmware team listen is another matter. At this moment in time i feel like they’ve given up in terms of quality of firmwares. I know the DSL models have been problematic with firmwares compared to the RT’s. It would not surprise me if they’ve already been building/testing a new DSL model for 2019, thus giving up on the 88u. As the all in one modem/routers are a good idea, the lack of support for a product of that type can be tiresome. Which is why im now looking into getting separate router/modem. I keep seeing Merlin’s firmware being recommended so im looking forward to experiencing that. Only thing im not sure on is what modem would be best to choose for my G.Fast connection?
    #1492
    • Replies 8,718
    @KitsuneDave – Thanks you, I have dropped ASUS DSL team an email to ask them to keep an eye out for your email, I will let you know if they feed anything back to myself.
    Your current ISP, what kit did you get from them and yes, RMerlin is a breath of Fresh Air, especially if you are technically curious ;)
    Note: Even the ASUS RT routers are a little buggy using ASUSWRT (stock) firmware, RMerlin provides the Q and A which makes using RMerlin’s firmware (ASUSWRT-Merlin) a positive experience.
    #1493
    AvatarKitsuneDave
    • Replies 24
    With my ISP being BT, they supplied me with a Ultrafast smart hub all in one. It was ok at time of installation but the wi-fi signals were very poor. Frequent disconnections every 3-5 days lead me into buying the 88u in the first place.
    Ive did further research and when BT were rolling out the G.Fast to testers, they supplied a separate modem Huawei MT992-10 to users. I can’t find concrete info but maybe the modem chip from the Huawei is present in the all in one smart hub. Maybe worth looking into the Huawei MT992-10 unless i find something better as a modem :)
    #1494
    oxygen8
    • Replies 38
    I’ll tell you my short story, 6 years ago when I contracted UPC in Ireland I got a Cisco EPC3925 which is a decent router with WiFi, and that was the problem -with WiFi- so I was never able to get the speed I contracted through the WiFi so this is what I did:
    • Bought the RT-AC56U and put Merlin in it (not at the beginning, after some research)
    • I completely disabled the WiFi radio on the Cisco router.
    • Set the Cisco router to bridge mode.
    • Got greedy and bought the RT-AC3200 which is better than the RT-AC56U but the TriBand is not a good thing because trying to do too many things usually ends in bad.
    • Got even more greedy and bought the DSL-88U which was a bad decision, I didn’t do my homework to find out that the firmware is not the standard AsusWRT that Merlin supports, Merlin doesn’t support ANY Asus DSL router
    What I have learned so far:
    • When dealing with the ISP don’t ever get a router with WiFi because of their lack of CPU and RAM.
    • Buy a good extra WiFi router and configure the ISP router in bridge mode and that’s it, profit.
    If I were you and you can return the DSL-88U do it because I don’t think there is hope for it, if you have some router working use it until the RT-AX88U is fully supported by Merlin (in progress) and buy that one combined with a non-WiFi ISP router.
    If you don’t have such money you can buy the RT-AC86U which has nice high speed dual CPU.
    Here is the spec of every Asus AC router RAM and CPU which is what I use when deciding what to buy next, look at the last two tables which are the AC and AX router(s): https://en.wikipedia.org/wiki/List_of_Asus_routers
    #1495
    • Replies 8,718
    [quote quote=1493]With my ISP being BT, they supplied me with a Ultrafast smart hub all in one. It was ok at time of installation but the wi-fi signals were very poor. Frequent disconnections every 3-5 days lead me into buying the 88u in the first place. Ive did further research and when BT were rolling out the G.Fast to testers, they supplied a separate modem Huawei MT992-10 to users. I can’t find concrete info but maybe the modem chip from the Huawei is present in the all in one smart hub. Maybe worth looking into the Huawei MT992-10 unless i find something better as a modem 🙂[/quote]
    ASUS said they would get in contact with you, so let us know how it goes, they may want you to install a new (unlocked) firmware to enable Telnet, which is nothing to worry about ;)
    #1496
    KingfisherUK
    • Replies 19
    @KitsuneDave Curious to know if you’ve tried IPv6? I’m also on BT and simply can’t get it to work – it picks up the wrong PD (/64 instead of /56) and when it’s enabled the wifi constantly drops and reconnects on all devices.
    #1497
    AvatarKitsuneDave
    • Replies 24
    [quote quote=1496] @kitsunedave Curious to know if you’ve tried IPv6? I’m also on BT and simply can’t get it to work – it picks up the wrong PD (/64 instead of /56) and when it’s enabled the wifi constantly drops and reconnects on all devices.[/quote]
    Exactly the same, even when i was on firmware 503. Yet when i plugged in the ISP’s smart hub last week the ipv6 was displaying and working correctly. So definitely Asus firmware at fault :)
    #1498
    KingfisherUK
    • Replies 19
    That’s what I suspected but nice to have it confirmed it’s not just me being stupid ;-)
    Smart Hub works fine with IPv6 as does an Openreach modem with an Asus RT-AC66U running RMerlin. If you haven’t already done so, it might be worth mentioning the IPv6 issue in your feedback as well – the more of us that report it, the better.
    #1499
    AvatarKitsuneDave
    • Replies 24
    Yeah i’ll assist Asus when they contact me, however if the problem still has not been resolved for both IPv6 and Ai Protection then i will be looking into getting rid of the unit and looking towards a 2 box solution ;)
    #1500
    AvatarKitsuneDave
    • Replies 24
    [quote quote=1495]
    ASUS said they would get in contact with you, so let us know how it goes, they may want you to install a new (unlocked) firmware to enable Telnet, which is nothing to worry about 😉[/quote]
    Sitrep ;)
    Asus contacted me and provided a debug firmware, also gave me telnet commands to use etc. Ive just done all the testing they wanted with screenshots, hopefully it helps and not been a waste of time on this glorious sunny day.
    Time for a beer ;)
