- This topic has 1,441 replies, 107 voices, and was last updated 6 days, 12 hours ago by
etdome.
August 22, 2020 at 6:26 pm #9275
Hey,
I want to set the DNS for the DHCP server/LAN rather than WAN as this causes an issue when using Pi-Hole (I suspect).
I’ve got two Pi-Hole DNS servers running on my network and set their IP’s in the WAN configuration. But I think this is causing an excessive amount of requests when the router does a phone-home. I’ve noticed that devices on the network get the gateway IP as the DNS address rather than the DNS servers.
Usually I’d set the DNS settings of the DHCP server and leave the WAN DNS alone (or set to OpenDNS 1.1.1.1) but there’s no option here. Would this be the sort of thing I’ve be able to change via SSH editing some sort of dhcp.conf?
August 22, 2020 at 7:27 pm #9278The way the DSL-AC88U was coded, It is a nightmare to figure out and best avoided if at all possible
The DSL-AC88U is a project not finished, but I would try Advanced Settings > LAN > Route – which can be used to connect several routers behind DSL-AC88U to share the same connection and DNS to the Internet
To manually change the DNS server of each node via the DHCP client (LAN) is not possible I believe on the DSL-AC88U
I can pass to you an unlocked DSL-AC88U firmware build which supports Telnet etc, but it is not a secure build
August 22, 2020 at 8:15 pm #9280Route/Gateway is 192.168.1.1
DNS 1: 192.168.1.5
DNS 2: 192.168.1.6
Scenario:
When a computer makes a request for a new IP lease, it is given DNS IP(s) too.
Expected:
The IP(s) given are those configured in the LAN – DHCP page, DNS 1 and DNS 2 above. Therefore computers on the network make DNS requests directly to the server
Actual
The IP given is the gateway IP. DNS requests go to the Router/gateway first, then to the DNS servers. Causes some weirdness to happen sometimes.
The only way, currently, to change the DNS settings of this router are via the WAN settings.
My old Linksys had this functionality. At a push I could plug that in and run it as a switch and DHCP server, which would be able to give the correct IPs but I’m pretty sure if the firmware/ROM is similar enough to Open-WRT or similar I could configure DHCP myself manually.
August 22, 2020 at 8:27 pm #9282I see, A separate (independent) DHCP server sounds a sensible option, do you still want a copy of the unlocked DSL-AC88U firmware to play with ?
August 23, 2020 at 7:18 am #9283Yes please :)
I was reading some more of this thread last night and gathered Asus abandoned this device a while back :/
August 23, 2020 at 7:20 am #9284Edit: our posts just missed each other
If you have a look at the Emulator for the RT AX model below, under LAN > DHCP Server is the option to nominate LAN Clients DNS and WINS IP addresses which can be different to that of the Routers DNS servers
So yes in short, the DSL-AC88U is missing this option
The other question you might consider is that given the DSL-AC88U is no longer supported (unofficially) is it really safe to connect it to the internet
http://demoui.asus.com/Advanced_DHCP_Content.asp
August 23, 2020 at 7:30 am #9285I don’t have much of a choice at the moment :( Though, I only paid £100 for this, new, in March!
My previous Router is a Linksys WRT1900ACS had DD-WRT installed on it and I’d done what I could to harden that. This is a shame, though, because Asus’ software is pretty decent.
EDIT:
I’m also stuck for a single-box solution with my VDSL line, as well. With the Linksys I had to use an older TP-Link as the modem and have two boxes running.
August 23, 2020 at 7:39 am #9287[quote quote=9285]I don’t have much of a choice at the moment :( Though, I only paid £100 for this, new, in March! My previous Router is a Linksys WRT1900ACS had DD-WRT installed on it and I’d done what I could to harden that. This is a shame, though, because Asus’ software is pretty decent. EDIT: I’m also stuck for a single-box solution with my VDSL line, as well. With the Linksys I had to use an older TP-Link as the modem and have two boxes running.[/quote]
This should be interesting when it arrives in the UK – https://uktechhub.com/forums/topic/asus-new-dsl-ax82u-modem-router-combo-wifi-6/
August 23, 2020 at 7:52 am #9288[quote quote=9287]
This should be interesting when it arrives in the UK – https://uktechhub.com/forums/topic/asus-new-dsl-ax82u-modem-router-combo-wifi-6/[/quote]
If that’s only £210 later this year that’s 100% going to be my next box.
August 23, 2020 at 8:23 am #9289[quote quote=9288]
If that’s only £210 later this year that’s 100% going to be my next box.[/quote]
With Brexit – it will be interesting to see what happens with the price
Email Sent about Telnet firmware.
August 23, 2020 at 8:33 am #9290I’m going to try the DSL-AX82U when it’s available (not impressed with the Draytek Vigor > RT-AC88U so far…)
August 23, 2020 at 8:46 am #9291[quote quote=9290]I’m going to try the DSL-AX82U when it’s available (not impressed with the Draytek Vigor > RT-AC88U so far…)[/quote]
DSL-AX82U will be interesting, usually first few firmware’s are buggy, but should improve after that ?
What’s wrong with your current set-up ?
August 23, 2020 at 9:04 am #9292[quote quote=9291]
DSL-AX82U will be interesting, usually first few firmware’s are buggy, but should improve after that ? What’s wrong with your current set-up ?[/quote]
I’ve had to power cycle the Draytek 130 twice, the RT once and had wifi issues about 4 times in less than 2 weeks since switching to this set up. The sys log from yesterday just stops when I had to power cycle the RT – no disconnect info…
I now expect no server response when I go to refresh a web page. Seriously considering going back to the DSL-AC88U until the new range is available.
The Draytek was brand new and the RT was used.
August 23, 2020 at 9:13 am #9293[quote quote=9292]
I’ve had to power cycle the Draytek 130 twice, the RT once and had wifi issues about 4 times in less than 2 weeks since switching to this set up. The sys log from yesterday just stops when I had to power cycle the RT – no disconnect info… I now expect no server response when I go to refresh a web page. Seriously considering going back to the DSL-AC88U until the new range is available. The Draytek was brand new and the RT was used.[/quote]
If you start a new topic under ASUS Forum say call it (RT-AC88U and Draytek 130) , we can run thru a few options to hopefully help improve what you have. the Drayteks in particular are usually very good
August 23, 2020 at 9:21 am #9294 -
