Viewing 15 posts - 1,141 through 1,155 (of 1,442 total)
  • #9295
    Avatarn13ldo
    • Replies 31
    [quote quote=9294]My setup (Draytek vigor 2760 and Asus RT-AX88U) is bulletproof [/quote]
    Nice but the RT-AX88U is a bit too pricey for me at the moment.
    [quote quote=9293]
    If you start a new topic under ASUS Forum say call it (RT-AC88U and Draytek 130) , we can run thru a few options to hopefully help improve what you have. the Drayteks in particular are usually very good [/quote]
    Thanks but not really wanting to spend the time investigating this just now as I have a few interviews lined up this week (Software Engineer) and need solid internet. In fact typing this just now I’ve decided the DSL-AC88U is being retrieved from the loft…
    #9297
    and good luck with interviews this week
    #9298
    Avatarn13ldo
    • Replies 31
    Will the DSL-AC88U mesh with the RT-AC88U (in non router mode) ? The DSL-AC88U being the router and the RT-AC88U being a ‘repeater’ ?
    I’m asking this as the RT-AC88U can be deployed into the garage for wider wifi (there’s a TP-Link in there just now)
    #9299
    [quote quote=9298]Will the DSL-AC88U mesh with the RT-AC88U (in non router mode) ? The DSL-AC88U being the router and the RT-AC88U being a ‘repeater’ ? I’m asking this as the RT-AC88U can be deployed into the garage for wider wifi (there’s a TP-Link in there just now)[/quote]
    The DSL-AC88U has no AiMesh capability, a feature they never got round to introducing on the DSl-AC88U – you could fudge a connection to it via an ethernet cable between the two routers, but would require a different  SSIDs (probable) and double natting would happen etc ?
    #9416
    AvatarCoops67
    • Replies 2
    I would advise anyone thinking of buying the DSL-88U not to. It is an absolute dud of a product. Lots of functions are missing from the firmware but most importantly the FTTN synch speeds are very low (I was getting 78mbps on my DSL-88U and about 90mbps on 3 other modems I own.
    Don’t buy any expensive combined router / modem. My advice would be get a really good wifi router and then bridge to a separate modem.
    #9417
    Avatarn13ldo
    • Replies 31
    [quote quote=9297] and good luck with interviews this week[/quote]
    Got the job
    #9418
    Congrats.    ‘you can treat yourself to a new router now’
    #9578
    Avatarr0b0tnik
    • Replies 2
    the debug version works great! seems a lot more stable than any of the public asus revisions. I don’t do a whole lot of advanced home networking anymore these days so I may not be facing the same issues as everyone else.
    As a security engineer myself I think we all have bigger problems if telnet is exposed on the intranet..but I also have a PA220 inline and limit telnet just to that zone.
    I’ve been running top as a baseline for awhile since receiving the firmware (thank you UKTechHub team!).
    To free up 20-25% RAM I kill -9 httpd if I reboot it. Whenever I ever need to get back into the web gui, I just telnet back and rerun httpd to start up the web console again.
    I haven’t seen any memory leaks, if you are referring to kmemleak, that is actually a good thing per man pages (I am not a linux d00d).
    “Kmemleak provides a way of detecting possible kernel memory leaks in a way similar to a tracing garbage collector”
    I’m getting a 2nd DSL line installed for my wife and her Mom. Thank you again for the firmware because I ended up buying another DSL-AC88U after not seeing any more problems
    I will stay tuned and circle back. I hate to see a good device get such bad rep when its mfg firmware..it’s a heck of a lot better than the  centurylink “upgraded” actiontec c3000A. So for any US based folks on centurylink- this device works great using the firmware provided by the team. I can’t speak to QWEST based though.
    Thanks again from across the sea!
    #9580
    @@r0b0tnik – I seem to remember from ASUS that memory issues for the DSL-AC88U was due to a lot of temp files being created and then not deleted by the kernel,
    The DSL-AC88U had good potential
    #9632
    Avatareazy
    • Replies 4
    Hi UK Sentinel,
    DSL-AC88U needing SSH/Telnet access, can you please send me the firmware?
    Nobber
    #9633
    [quote quote=9632]Hi UK Sentinel, DSL-AC88U needing SSH/Telnet access, can you please send me the firmware? Thanks Nobber[/quote]
    Hi @eazy – email / PM sent
    #9647
    Avataremantec
    • Replies 5
    Could I grab a copy of the ssh firmware? Thanks!
    #9648
    [quote quote=9647]Could I grab a copy of the ssh firmware? Thanks![/quote]
    Hi @emantec – email / PM sent
    #9668
    AvatarFifty89
    • Replies 1
    May I grab a copy of the DSL-88U debug firmware as well please?
    Thanks in advance :)
    #9669
    [quote quote=9668]May I grab a copy of the DSL-88U debug firmware as well please? Thanks in advance :)[/quote]
    Hi @fifty89 – email / PM sent
