Viewing 15 posts - 241 through 255 (of 1,411 total)
  • #15745
    Jacky DecosterJacky Decoster
    • Replies 34
    Installed the new firmware via gui (without factory reset).
    The problem I had with previous firmware arose again : interuptions when streaming video content from nas to PC. (NAS is hardwired with base station. PC is hardwired on satelite station on first floor of the house. Base and satelite station are connected with 5ghz wifi backhaul).
    I am unable to watch a movie without video cutting of. Strangely enough, interuptions occurs when a familymember with iphone moves from first floor to ground floor or other way around. Somehow moving other wifi devices interferes with video stream? happens with or without activating adaptive QOS.
    I’ve reverted back to the “safe” 3.0.0.4.386.42095, where I never had this problem.
    guess i’ll stick to 42095 for me.
    Would a factory reset influence this behaviour? If so, when do you suggest doing the factory reset : before or after upgrading the firmware?
    • Replies 8,458
    Hi, A factory reset may help, always best to upgrade firmware and then factory reset
    Let us know if this helps with streaming content via NAS
    #15751
    RavenRaven
    • Replies 28
    I’ll wait until I’m sure that this new firmware is stable on backhaul connection… I’ve 5 apparates so I prefer to see how it goes…
    • Replies 34
    ok, did (again) the upgrade to the new firmware, factory reset, re-paired base and satelite.
    results :
    • still interuptionsย  when streaming video from nas
    • still interuptions when doing remote desktop session to server
    • still interuptions when using teams
    back to the ‘safe’ 42095 firmware for me.
    • Replies 617
    It might be worth sending ASUS feedback.ย  Hopefully UK Sentinel can help with getting a response from them.
    • Replies 617
    Does anyone know what is the fastest real world speed possible on the 5GHz-1 band on the XT8?
    • Replies 8,458
    ok, did (again) the upgrade to the new firmware, factory reset, re-paired base and satelite. results :
    • still interuptions when streaming video from nas
    back to the โ€˜safeโ€™ 42095 firmware for me.
    Hi @Jacky-Decoster – can I ask you to send a feedback form and detail as you have above, if you mention at the begging of message ‘UK Sentinel’ and I can chase from this end also
    it is odd that @dodgydrains Teams calls works well and yours does not ?
    #15829
    • Replies 617
    I can confirm that for me Teams is as stable as 42095.
    Just been upgraded today to 1Gb broadband for ยฃ20 with Hyperoptic (Special 10 year anniversary deal they have going).ย  Getting amazing speeds wired from the XT8 main router (852Mbps DL and 927 Mbps UL).ย  Much lower wireless speeds with Wifi 6 device.
    • Replies 8,458
    1Gb broadband for ยฃ20 with Hyperoptic is an amazing deal
    Wifi 6 speeds are defendant on many variables – but I assume some devices are faster than others with wifi 6 ?
    #15832
    • Replies 617
    The fastest speed I got was 653Mbps UL and 830Mbps DL on the 5GHz-1.ย  This is from the main XT8 router.ย  The furthest XT8 is still roughly 500Mbps UL and DL.ย  I didn’t get the 1Gb for the additional speed, got it just the ยฃ15 savings and the stability.
    • Replies 8,458
    are those speeds via Laptop ?
    #15835
    • Replies 617
    These are speeds with my OPPO Find X3 Pro.
    • Replies 8,458
    Never seen that Brand before, but specs say Wi-Fi 6 (802.11ax), is supported so wifi should be quicker ?
    https://www.oppo.com/uk/smartphones/series-find-x/find-x3-pro/specs/
    #15837
    • Replies 94
    The Oppo supports 80 and 160MHz Wi-Fi 6. Of course that’s just 80 with the XT8 in most usage cases.
    • Replies 8,458
    Good point !
Close โœ–
Search forums
Advanced forum search
Back to basic search
