Viewing 15 posts - 466 through 480 (of 1,417 total)
  • #17785
    • Replies 94
    Did you only make a reboot (by software) or turn off power for short time on ALL physically connected devices? First might not reset HW completely to remove failure. Do you use some kind of switch or PLC (PowerLine)?
    I did the reset via software, which went back to the setup wizard (and then uploaded the config file to restore all my settings). I also turned off the power for a while. I have no Powerline devices in use either.
    I doubt I’ll ever know what went wrong. I just hope it doesn’t happen again!
    #17787
    • Replies 8,707
    Handy Tip;
    If Anyone is having issues where the signal of the wireless backhaul node randomly drops from 5GHz to 2.4GHz frequency and displays “weak” signal then try disabling universal beamforming on the 5Ghz-2 network band
    Worth  a try from a stability perspective
    #17815
    Jacky DecosterJacky Decoster
    • Replies 34
    QOS didn’t solve all my problems.
    reverted back to 42095 : issues gone :-)
    #17816
    • Replies 8,707
    QOS didn’t solve all my problems. reverted back to 42095 : issues gone :-)
    That is a real shame, I will let ASUS know your particular set-up and ask them to have a look at stability for future releases ?
    #17926
    • Replies 630
    https://dlcdnets.asus.com/pub/ASUS/wireless/ZenWiFi_XT8/FW_ZENWIFI_XT8_900438646980.zip
    If anyone interested in testing this, I haven’t tried yet.
    ASUS ZenWiFi XT8 Firmware version 9.0.0.4.386.46980
    This beta version fixed someIoT compatibility issues.
    Please download and unzip the firmware and Refer to “Method 2: Update Manually” in https://www.asus.com/support/FAQ/1008000 to update this firmware.
    MD5:bdb2b656513629c83af8b266257c0e6e
    #17927
    • Replies 8,707
    Great news ,  I think well will have to call you Mr ZenWifi
    #17942
    AvatarDave
    • Replies 17
    Unfortunately I see others still having problems.
    Since I sent mine back and reverted back to.my old Orbi RBK52 I’ve had no issues at all.
    Think I’ll stick with that for the time being.
    Good luck to the beta testing
    #17993
    • Replies 630
    https://dlcdnets.asus.com/pub/ASUS/wireless/ZenWiFi_XT8/FW_ZENWIFI_XT8_900438646980.zip If anyone interested in testing this, I haven’t tried yet. ASUS ZenWiFi XT8 Firmware version 9.0.0.4.386.46980 This beta version fixed someIoT compatibility issues. Please download and unzip the firmware and Refer to “Method 2: Update Manually” in https://www.asus.com/support/FAQ/1008000 to update this firmware. Please unzip the firmware file first then check the MD5 code. MD5:bdb2b656513629c83af8b266257c0e6e
    This beta has been really good for me with Teams.  I updated around 3/4 days ago.  No issues with Microsoft Teams
    #17994
    • Replies 8,707
    Great news, thanks for update and will interesting to see if anybody else has tried this firmware also
    #18021
    • Replies 8,707
    I have read on a couple of Forums that using firmware 3.0.0.4.386_46061 owners are having Gaming issues, shame they have not tried ASUS ZenWiFi XT8 Firmware version 9.0.0.4.386.46980
    #18022
    • Replies 630
    My son uses Game Pass and the Xbox cloud gaming every day, this is on PC and the Xbox Series X.  He hasn’t complained about any issues with gaming at all.  We used Cloudflare IPv6 without any issues and yesterday changed to Google IPv6 for testing purposes.  Teams was fine for me today with Google dns.
    #18024
    • Replies 8,707
    Great news, did your Son have any issues with gaming whilst you where using firmware 3.0.0.4.386_46061 ?
    Is he on Ethernet to Node for gaming connection ?
    #18028
    • Replies 630
    No issues at all with gaming even on 46061.
    He uses both ethernet and wifi for gaming
    #18029
    • Replies 8,707
    Good to know, hopefully just a config/QoS issue for their side.
    #18033
    • Replies 630
    The beta 46980 has been rock solid for me the whole week even with multiple Teams calls.  Hopefully it stays like this.
