- This topic has 198 replies, 13 voices, and was last updated 2 years, 5 months ago by
- October 13, 2020 at 8:57 am #9874
8[quote quote=9872]
You mean 2 x DSL-AC68U I think ?
Yes, I have 1x RT-AC68U and 2 x DSL-AC68U[/quote]
With the latest firmware they should be able to act as a node, similar to an RT-AC68U, connecting in the same way.
October 13, 2020 at 9:42 am #9875[quote quote=9874]8
With the latest firmware they should be able to act as a node, similar to an RT-AC68U, connecting in the same way.[/quote]
You mean I can connect th ethernet cable from the WAN port of the RT-AC68U to the LAN_1 port of the DSL-AC68U using the stock firmware ?
October 13, 2020 at 9:45 am #9876The WAN port is for telephony it won’t work for a LAN connection.
Connect to one of the LAN ports on the DSL-RT68U and it should work fine.
October 13, 2020 at 10:02 am #9877October 13, 2020 at 10:13 am #9879[quote quote=9876]The WAN port is for telephony it won’t work for a LAN connection.[/quote]
Thats not correct, WAN port of RT-AC68U is an Ethernet-port, and DSL-AC68U got an DSL-port (for phone-line) there is no WAN port on it.
@Patrik Pabo: So you have to use “alternative” picture you posted.
AFAIK you have to set in menu which port shall act as WAN-port on your DSL-AC68U, in your case set it to LAN1 and use the port named LAN1.
October 13, 2020 at 10:14 am #9880[quote quote=9879]
Thats not correct, WAN port of RT-AC68U is an Ethernet-port, and DSL-AC68U got an DSL-port (for phone-line) there is no WAN port on it. @Patrik Pabo: So you have to use “alternative” picture you postet. AFAIK you have to set in menu which port shall act as WAN-port on your DSL-AC68U, in your case set it to LAN1 and use the port named LAN1.[/quote]
I will try asap, thank you!
October 13, 2020 at 10:42 am #9882[quote quote=9879]
Thats not correct, WAN port of RT-AC68U is an Ethernet-port, and DSL-AC68U got an DSL-port (for phone-line) there is no WAN port on it. @Patrik Pabo: So you have to use “alternative” picture you posted. AFAIK you have to set in menu which port shall act as WAN-port on your DSL-AC68U, in your case set it to LAN1 and use the port named LAN1.[/quote]
Correct, my mistake the blue port is DSL not WAN but my advice was correct the port is for telephony only, so you need to use one of the LAN ports.
October 13, 2020 at 12:00 pm #9883Advice is goo
d,
Edit: I have dropped ASUS an email, just to double check as the ASUS world changes so quickly and the lack of a Dedicated WAN port on DSL-AC68U makes me wonder
Edit 1: https://www.asus.com/support/FAQ/1039736/
October 14, 2020 at 9:25 am #9885Ok, so had an email from ASUS this morning and it does look as though the DSL-AC68U does support both AiMesh Primary and Node but for AiMesh Node the DSL-AC68U does not support AiMesh via Ethernet backhaul.
DSL-AC68U acting as an AiMesh Node only supports wireless backhaul due to the lack of WAN port
Sorry for the bad news
October 14, 2020 at 9:57 am #9887[quote quote=9885]Ok, so had an email from ASUS this morning and it does look as though the DSL-AC68U does support both AiMesh Primary and Node but for AiMesh Node the DSL-AC68U does not support AiMesh via Ethernet backhaul. DSL-AC68U acting as an AiMesh Node only supports wireless backhaul due to the lack of WAN port Sorry for the bad news [/quote]
nooooooo
October 14, 2020 at 10:01 am #9888October 14, 2020 at 10:07 am #9889unfortunatelly I cant, bought used on the web…two of them
…my faultYou need to login in order to vote
October 14, 2020 at 10:52 am #9890You could use one DSL as Mesh Master router (set LAN1 as WAN to existing modem) instead of RT, then RT as Mesh-node with LAN (its WAN port) backhaul and 2nd DSL as Mesh-node over Wifi.
October 14, 2020 at 11:01 am #9891Also There is another option called Access Point, I cannot recall if the DSL-AC68U will support Access Point mode ?
Have a look on your DSL-AC68U > Administration > Operation Mode and see if Access Point is available ?
Alternatively, there is a third party developer @GNUton, that has produced a Firmware that will support AP for DSL-AC68U
https://github.com/gnuton/asuswrt-merlin.ng/releases/tag/384.17_0-gnuton1
October 14, 2020 at 11:01 am #9892 - AuthorPosts
