Viewing 15 posts - 301 through 315 (of 1,130 total)
  • #9653
    AvatarMMTECH
    • Replies 6
    Great!
    I hope 5ghz will be more stable.
    #9658
    • Replies 8,714
    [quote quote=9653]Great! I hope 5ghz will be more stable.[/quote]
    Send ASUS a feedback form and make sure they are reminded
    #9780
    byrallier
    • Replies 21
    is everything ok guys? :)
    #9781
    • Replies 8,714
    [quote quote=9780]is everything ok guys? :)[/quote]
    yes very quiet on the ASUS DSL forum and ASUS have just had another Chinese Holiday 1 – 4 Oct (Taiwan) so are catching up, I did drop ASUS an email this morning asking when the next set of Beta’s are scheduled to be released and  it is looking to be by the 14th Oct
    #9789
    • Replies 8,714
    Well I got the date wrong
    DSL ASUSWRT Beta Firmware v9.1.2.3_886 now available, as follows. Feel free to share on your forum.
    2020_10_07_v9.1.2.3_886-g42a8ba5 (UKTH)
    https://www.asuswebstorage.com/navigate/a/#/s/0C8B540FC9394CCE9F4E02B88720B96AY
    Changelog to follow early next week.
    Edit: Changelog as detailed below
    Release note as follows…
    • Fixed Web UI related issues.
    • Enhance firmware live update mechanism.
    • Adopt security related enhancements.
    • QIS > VDSL WAN(PTM), added Australia ISP Optus profile.
    • Fixed possible Feedback > xDSL Diagnostic log missing issue.
    • Fixed DDNS leads to possible UI login issue.
    • Fixed OpenVPN related issues.
    Note: Normal ASUS Beta T&C’s apply (top of Forum)
    #9818
    Avatarosman
    • Replies 52
    Hello, I am using ac750 model. No matter which version I do not use, my internet becomes unusable. It was the same in the v9.1.2.3_886 version. When I call my internet provider, it says my line is constantly disconnected. I tried many settings on forum sites, I tried many settings such as QoS, Wifi channel setting. I contacted Asus and sent my modem for repair. What they do is simply reset and install the 1.1.2.3_858 version and it still doesn’t work. I will add that it can give strange results in speed test measurements. It does not work wired or wireless. I did it with the hard factory reset method. I ask for your help in finding a solution.
    #9821
    • Replies 8,714
    Do you have stability problems / speed problems when you are using a wired (ethernet) connection form Router to PC /Laptop for test ?
    #9822
    Avatarosman
    • Replies 52
    I do not live for a certain period of time. This sometimes takes 15 minutes, sometimes 2 days. After that, it starts giving CRC errors every second. Between 1000-3000 per second. Turning the modem on and off did not work in previous versions. I would get DSL Log and DSL Public Log records when I reconnected my modem for you. I noticed that the modem is working. I will see how long it will work right now.I do not experience speed problems while the modem is running. There is no problem on the pc or the modem. All the lights of the modem are on and the internet appears to be connected on the PC. I sent feedback over the modem. That’s why I think the General doesn’t save the diary. Diagnostic debug log capture in progress: It is writing 23 hours. I can cancel if you want. I can have it save the General Diary.
    #9823
    • Replies 8,714
    I see, when CRC start increasing show me log again (asusdslgunlugu.png) so we can see if issue is REIN or Shine ?
    Your DSL Stats look good, you have very high SNR, but everything thing else looks good for DSL
    https://uktechhub.com/forums/topic/rein-vs-shine/
    #9824
    Avatarosman
    • Replies 52
    35 minutes after reconnecting the modem, CRC started giving errors.
    #9831
    • Replies 8,714
    Yes, very high CRC’s but not showing REIN or SHINE values ?
    Try an older firmware to see if CRC problem  is the same and factory reset and build from scratch (not backup) after loading firmware – Version 1.1.2.3_617
    https://dlcdnets.asus.com/pub/ASUS/wireless/DSL-AC750/FW_DSL-AC750_1123617.ZIP
    If the above does not work, can you post a Traffic Manager – Spectrum screenshot – I think the DSL-AC750 support this option ?
    Also  try a new DSL cable between modem and wall socket.
    The DSL-AC750 has I think a setting called ESNP (Enhanced Sudden Noise Protection) make sure this is On ?
    Not sure if this will also work in your region of the world, if you use a landline telephone, look up how to do a quiet-line-test and see if you can hear any crackling / hissing on your telephone ?
    When u Called your ISP did they say there was a  line fault ?
    If still high CRC’s, then probable a faulty electrolytic capacitors in the Modem which is not good and time to buy a new (better) Broadcom Modem Router as yours is MediaTek and very sensitive
    Avatarosman
    • Replies 52
    My internet did not cause any problems in version 1.1.2.3_617. With that in mind I installed version 1.1.2.3_858. I moved my modem away from my computer. approx 2mt. I could not find how to open the REIN or SHINE values ​​you mentioned. I could not test it because I have a very old type of radio. I continue to test version 1.1.2.3_858. Thanks for your help. I am sorry for my English I am writing to you using google translate.
    #9842
    • Replies 8,714
    version 1.1.2.3_617 is interesting that it worked, let us know how version 1.1.2.3_858 testing works ?
    Change ESNP (Enhanced Sudden Noise Protection) to On if you can
    Your Spectrum Graph shows a little bit of interference, hopefully ESNP On will help ?
    Google Translate is working well
    #9843
    Avatarosman
    • Replies 52
    I did what they said but the internet is not stable and it’s getting worse and worse. I will install the beta version again.
    #9846
    • Replies 8,714
    [quote quote=9843]I did what they said but the internet is not stable and it’s getting worse and worse. I will install the beta version again.[/quote]
