- This topic has 717 replies, 4 voices, and was last updated 6 years, 1 month ago by
Bully.
April 22, 2020 at 8:51 pm #6638
It may be solved, may be not it depends how bad it is and if engineer pick this up. Can you unplug your phone for couple of hours and see if amount of errors go down where only modem is connected, if it does that will give you good argument when you report fault.
April 23, 2020 at 7:22 am #6645Plugged HG612 in this morning before I left for work, will check stats when I get home.
April 23, 2020 at 4:42 pm #6650April 23, 2020 at 5:12 pm #6651Hi,
I’m home now and showered.
Cant access the modem through my Asus router to get stats
Just about to plug laptop into the modem.
April 23, 2020 at 5:15 pm #6652April 23, 2020 at 5:23 pm #6653April 23, 2020 at 5:39 pm #6654April 23, 2020 at 5:56 pm #6655Attainable
Downstream 50492
Upstream 12160Actual
Downstream 34999
Upstream 12045SNR margin (dB)
8.5
6.1
Line attenuation (dB)
19.6
0
Output power (dBmV)
13.3
6.7You need to login in order to vote
April 23, 2020 at 6:19 pm #6659Interesting start but will hopefully settle in after a couple of re- synchs etc, do you know how to gain access to FEC stats etc?
April 23, 2020 at 6:28 pm #6660April 23, 2020 at 6:33 pm #6662DSLAM type / SW version: IFTN:0xd086 (208.134) / v0xd086
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime: 1 hour 55 min 54 sec
Resyncs: 0 (since 23 Apr 2020 19:32:36)Downstream Upstream
Line attenuation (dB): 19.6 0.0
Signal attenuation (dB): Not monitored
Connection speed (kbps): 34999 12045
SNR margin (dB): 8.4 6.2
Power (dBm): 13.3 6.7
Interleave depth: 1485 1
INP: 8.00 0
Vectoring status: 5 (VECT_UNCONFIGURED)RSCorr/RS (%): 0.0019 0.0002
April 23, 2020 at 6:38 pm #6663Try this if you use telnet command.
xdslcmd info –stats
If you use dsl stats program in tab telnet is tab stats, same output (from memory).
April 23, 2020 at 6:39 pm #6664xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 12170 Kbps, Downstream rate = 50064 Kbps
Bearer: 0, Upstream rate = 12045 Kbps, Downstream rate = 34999 KbpsLink Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 8.4 6.2
Attn(dB): 19.6 0.0
Pwr(dBm): 13.3 6.7
VDSL2 framing
Bearer 0
MSGc: 18 20
B: 47 238
M: 1 1
T: 61 31
R: 16 16
S: 0.0436 0.6314
L: 11736 3231
D: 1485 1
I: 64 255
N: 64 255
Counters
Bearer 0
OHF: 2626126 716725
OHFErr: 0 0
RS: 640685133 1479424
RSCorr: 11886 2
RSUnCorr: 0 0Bearer 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 471808795 0
Data Cells: 135151973 0
Drop Cells: 0
Bit Errors: 0 0ES: 0 2648
SES: 0 31
UAS: 26 83749
AS: 7014Bearer 0
INP: 8.00 0.00
INPRein: 0.00 0.00
delay: 16 0
PER: 2.67 9.82
OR: 71.86 21.17
AgR: 35071.00 12065.94Bitswap: 4951/4980 3/3
Total time = 1 hours 57 min 20 sec
FEC: 11886 2
CRC: 0 0
ES: 0 2648
SES: 0 31
UAS: 26 83749
LOS: 0 1
LOF: 0 1
LOM: 0 0
Latest 15 minutes time = 12 min 20 sec
FEC: 857 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 1367 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 1 hours 57 min 20 sec
FEC: 11886 2
CRC: 0 0
ES: 0 2648
SES: 0 31
UAS: 26 83749
LOS: 0 1
LOF: 0 1
LOM: 0 0
Previous 1 day time = 0 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 1 hours 56 min 53 sec
FEC: 11886 2
CRC: 0 0
ES: 0 2648
SES: 0 31
UAS: 0 83723
LOS: 0 1
LOF: 0 1
LOM: 0 0
#You need to login in order to vote
April 23, 2020 at 6:52 pm #6665April 23, 2020 at 6:56 pm #6667 -
