Viewing 15 posts - 151 through 165 (of 718 total)
  • #6668
    AvatarMrk26
    • Replies 465
    To what you changed ip address? And how you connected to asus router?
    #6669
    Bully
    • Replies 386
    Changed lan ip to 192.168.2.1
    router wan port to dsl port on modem.
    #6670
    AvatarMrk26
    • Replies 465
    I think HG612 don’t work like that, at least not straight away. Give HG612 ip 192.168.1.2 where your asus should be 192.168.1.1, and plug in second cable from HG612 to lan into asus.
    #6671
    • Replies 8,724
    give the modem a couple of days to settle in and post results again if u can
    #6672
    Bully
    • Replies 386
    I have set it up how my Draytek Vigor 130 was setup to access its gui via router.
    #6673
    Bully
    • Replies 386
    @uk-sentinel – Do i have to untick port binding on lan 1 and lan 2 within the HG612?
    #6674
    • Replies 8,724
    [quote quote=6672]I have set it up how my Draytek Vigor 130 was setup to access its gui via router.[/quote]
    In theory, DrayTeK was 192.168.2.1 and RT-AC86U was 192.168.50.1 so as long as you followed the details previously for DrayTek config , just subbing out DrayTeK ip and subnet for HG612 IP address (192.168.1.1) , it should work if set up correctly on the ASUS – I have achieved this in the past with success – long time ago     (does not work for BT HG612 (3B) modem)
    I would avoid playing with HG612 for a couple of days, as we do not wish to cause any re-synchs etc. if happy with HG612 in a week or so, then we can set-up your configs to suit
    #6675
    • Replies 8,724
    [quote quote=6673] @uk-sentinel – Do i have to untick port binding on lan 1 and lan 2 within the HG612?[/quote]
    Sorry, late to this, if it works currently, I would leave alone until we are happy with modem etc ? then configure later as we do not want any re-synchs while modem is settling in
    #6677
    Bully
    • Replies 386
    [quote quote=6674]
    In theory, DrayTeK was 192.168.2.1 and RT-AC86U was 192.168.50.1 so as long as you followed the details previously for DrayTek config , just subbing out DrayTeK ip and subnet for HG612 IP address (192.168.1.1) , it should work if set up correctly on the ASUS – I have achieved this in the past with success – long time ago I would avoid playing with HG612 for a couple of days, as we do not wish to cause any re-synchs etc. if happy with HG612 in a week or so, then we can set-up your configs to suit[/quote]
    Ok thanks.  Will leave well alone.
    I changed the HG612 IP to match the Draytek, so i did not have to change the router wan settings.
    #6680
    • Replies 8,724
    Can you access HG612 UI via ASUS currently ?
    #6681
    Bully
    • Replies 386
    [quote quote=6680]Can you access HG612 UI via ASUS ?[/quote]
    Nope, only direct in HG612’s lan 2.  I cannot telnet it via it’s lan 2 only via DSLstats program.  Strange ?
    #6682
    • Replies 8,724
    I will dig out my BT HG612 over weekend and have a play, Take the weekend off and give us some stats on Monday if you could – by then we should have some good stats to ingest  ;-)
    #6683
    Bully
    • Replies 386
    [quote quote=6682]I will dig out my BT HG612 over weekend and have a play, Take the weekend off and give us some stats on Monday if you could – by then we should have some good stats to ingest ;-)[/quote]
    Ok, thanks again to you and Mrk26 for the help.
    #6684
    AvatarMrk26
    • Replies 465
    [quote quote=6681]
    Nope, only direct in HG612’s lan 2. I cannot telnet it via it’s lan 2 only via DSLstats program. Strange ?[/quote]
    At least you can access it with dsl stats program, there is all you need.
    #6686
    • Replies 8,724
    Had a play with my HG612 3B today loaded with howling wolf’s (bcm96368MVWG_fs_kernel_HG612V100R001C01B030SP08_webgui) firmware for unlocking the BT HG612 modem and @Mrk26 is correct, I could not gain access to modem UI via Modem LAN Port 1, connected to RT-AC86U WAN Port – only via Modem LAN Port 2 with separate ethernet cable running from spare LAN port on ASUS router,
    I had forgotten there was 2 x LAN ports for this model, as and when you want to gain access to HG612 – I am sure @Mrk26 good instructions should work – Ignore my previous guidance
