RT-AC86U 384.16
Viewing 15 posts - 46 through 60 (of 718 total)
  • #6424
    Bully
    • Replies 386
    Todays stats –
    DS Actual Rate          : 35000000 bps   US Actual Rate       : 10666000 bps
    DS Attainable Rate      : 44621984 bps   US Attainable Rate   : 10735457 bps
    DS Interleave Depth     :     1514       US Interleave Depth  :        1
    NE Current Attenuation  :       20 dB    Cur SNR Margin       :        6  dB
    DS actual PSD           :     6. 4 dB    US actual PSD        :    13. 0  dB
    NE CRC Count            :        1       FE CRC Count         :     4044
    NE ES Count             :        1       FE  ES Count         :     2644
    Xdsl Reset Times        :        0       Xdsl Link  Times     :        4
    [ Counters: Showtime ]
    ElapsedTime  :   229772            229772 (seconds)
    CRC          :     -1            4044
    FEC          :   589195            53801
    HEC          :      0               0
    CRC_P        :     -1               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0            2644
    SES          :      3              31
    LOSS         :      0               1
    UAS          :      0               0
    LOFS         :      0               0
    [ Counters: 15Min ]
    ElapsedTime  :    567             567 (seconds)
    CRC          :      0               0
    FEC          :   16389               0
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0               0
    SES          :      0               0
    LOSS         :      0               0
    UAS          :      0               0
    LOFS         :      0               0
    [ Counters: 1DAY ]
    ElapsedTime  :   4167            4167 (seconds)
    CRC          :      0               0
    FEC          :   90007               0
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0               0
    SES          :      0               0
    LOSS         :      0               0
    UAS          :      0               0
    LOFS         :      0               0
    [ BAND INFORMATION ]
    US:
    Band=0, LATN=   6, SATN=   6, SNR=   7, Border=[   8-  31], Limits=[   6-  31]
    Band=1, LATN=  29, SATN=  29, SNR=   6, Border=[ 882-1193], Limits=[ 882-1193]
    Band=2, LATN=  45, SATN=  45, SNR=   6, Border=[1984-2770], Limits=[1984-2770]
    DS:
    Band=0, LATN=  14, SATN=  14, SNR=   5, Border=[  33- 857], Limits=[  33- 857]
    Band=1, LATN=  36, SATN=  36, SNR=   5, Border=[1218-1959], Limits=[1218-1959]
    Band=2, LATN=  56, SATN=  54, SNR=   6, Border=[2795-3631], Limits=[2795-3784]
    #6425
    AvatarMrk26
    • Replies 465
    You had resync recently and you got fastpath on upstream now 😁,  it’s going right way.
    #6428
    • Replies 8,708
    @Bully – what is the bitswap status ?
    #6431
    Bully
    • Replies 386
    Bitswap see below
    LOS          :      4               0
    FECS         :   733218            53801 (seconds)
    ES           :      1            2644 (seconds)
    UAS          :     33            80427 (seconds)
    CRC          :      1            4044
    INP          :      0              40 (symbols)
    InterleaveDelay :      0            1500 (1/100 ms)
    NFEC         :    255              61
    LSYMB        :   2862            11974
    INTLVBLOCK   :    255              61
    #6432
    • Replies 8,708
    Thanks, do you think connection is improving ?
    #6433
    Bully
    • Replies 386
    Looking at stats it seems to be.
    #6434
    • Replies 8,708
    As Fastpath is now enabled upstream, will be interesting if Fastpath DS also comes online ?
    I forget, have you ever had fastpath in both direction ?
    #6449
    Bully
    • Replies 386
    Never on both.
    Todays stats
    DS Attainable Rate      : 44295296 bps   US Attainable Rate   : 10713400 bps
    DS actual PSD           :     6. 4 dB    US actual PSD        :    13. 1  dB
    NE CRC Count            :        1       FE CRC Count         :     4045
    NE ES Count             :        1       FE  ES Count         :     2645
    #6450
    AvatarMrk26
    • Replies 465
    How errors looking now?
    #6451
    Bully
    • Replies 386
    ElapsedTime  :   305944            305944 (seconds)
    CRC          :     -1            4045
    FEC          :   37658444            53807
    HEC          :      0               0
    CRC_P        :     -1               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0            2645
    SES          :      3              31
    LOSS         :      0               1
    UAS          :      0               0
    LOFS         :      0               0
    [ Counters: 15Min ]
    ElapsedTime  :    569             569 (seconds)
    CRC          :      0               0
    FEC          :   2583210               0
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0               0
    SES          :      0               0
    LOSS         :      0               0
    UAS          :      0               0
    LOFS         :      0               0
    [ Counters: 1DAY ]
    ElapsedTime  :   5069            5069 (seconds)
    CRC          :      0               0
    FEC          :   12746071               0
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0               0
    SES          :      0               0
    LOSS         :      0               0
    UAS          :      0               0
    LOFS         :      0               0
    US:
    Band=0, LATN=   6, SATN=   6, SNR=   7, Border=[   9-  31], Limits=[   6-  31]
    DS:
    Band=2, LATN=  56, SATN=  54, SNR=   6, Border=[2795-3619], Limits=[2795-3784]
    LOS          :      4               0
    FECS         :   38170553            53807 (seconds)
    ES           :      1            2645 (seconds)
    CRC          :      1            4045
    NFEC         :    255              61
    LSYMB        :   2862            11974
    INTLVBLOCK   :    255              61
    #6452
    • Replies 8,708
    So Synch has again improved slightly and your CRC’s are very good/low, you just have a high FEC now ?
    #6453
    AvatarMrk26
    • Replies 465
    I think high is not enough to say…
    If that won’t get worse, I mean if you don’t loose fastpath I will add at least 1snr to downstream to increase line stability. With this amount of errors you barely have chance to get fastpath on downstream. Have you got filtered face plate mounted? Looking by amount of FEC errors I doubt.
    #6454
    Bully
    • Replies 386
    I think high is not enough to say… If that won’t get worse, I mean if you don’t loose fastpath I will add at least 1snr to downstream to increase line stability. With this amount of errors you barely have chance to get fastpath on downstream. Have you got filtered face plate mounted? Looking by amount of FEC errors I doubt.
    Yeah I have a filtered face plate, open reach mk4.
    #6455
    AvatarMrk26
    • Replies 465
    Have you got any extensions connected to master socket apart your modem.
    #6457
    Bully
    • Replies 386
    Yeah a phone line to my living room for my sky box and a phone.
  • The topic ‘RT-AC86U 384.16’ is closed to new replies.
