› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › RT-AC86U 384.16 Hi, I updated to the latest Merlin firmware this morning (about 9 am) and since doing so my NE CRC count has gone up to 326598 over 5 hours. ...
- This topic has 717 replies, 4 voices, and was last updated 6 years, 1 month ago by
Bully.
May 24, 2020 at 9:55 am #7541
Yes, you interleaved heavily now, 16ms delay added. It’s because no matter what settings, your line didn’t improved. You need to wait and see how it will perform now.
May 24, 2020 at 12:05 pm #7543vdsl status
DS Actual Rate          : 29999000 bps   US Actual Rate       : 10596000 bps
DS Attainable Rate      : 43643920 bps   US Attainable Rate   : 10725733 bps
DS Interleave Depth     :     1513       US Interleave Depth  :        1
NE Current Attenuation  :       20 dB    Cur SNR Margin       :        8  dB
DS actual PSD           :     6. 4 dB    US actual PSD        :    13. 1  dB
NE CRC Count            :        9       FE CRC Count         :     4080
NE ES Count             :        1       FE  ES Count         :     2658
Xdsl Reset Times        :        0       Xdsl Link  Times     :        1
ITUÂ Version[0]Â Â Â Â Â Â Â Â Â Â :Â fe004452Â Â Â Â Â Â Â ITUÂ Version[1]Â Â Â Â Â Â Â :Â 41590000
VDSL Firmware Version   : 05-07-09-0F-01-07   [with Vectoring support]
COÂ ITUÂ Version[0]Â Â Â Â Â Â Â :Â b5004946Â Â Â Â Â Â Â COÂ ITUÂ Version[1]Â Â Â Â :Â 544ed086
DSLAMÂ CHIPSETÂ VENDORÂ Â Â Â :Â <Â IFTNÂ >
> vdsl status more———————- ATU-R Info (hw: annex A, f/w: annex A/B/C) ———–
LOSÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
LOFÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
LPRÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
LOMÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
NCDÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
LCDÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
FECSÂ Â Â Â Â Â Â Â Â :Â Â Â 24751Â Â Â Â Â Â Â Â Â Â Â Â 54519Â (seconds)
ESÂ Â Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 1Â Â Â Â Â Â Â Â Â Â Â Â 2658Â (seconds)
SESÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â 31Â (seconds)
LOSSÂ Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 1Â (seconds)
UASÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â 34Â Â Â Â Â Â Â Â Â Â Â Â 87891Â (seconds)
CRCÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 9Â Â Â Â Â Â Â Â Â Â Â Â 4080
INPÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â 45Â (symbols)
InterleaveDelay :      0            1600 (1/100 ms)
NFECÂ Â Â Â Â Â Â Â Â :Â Â Â Â 255Â Â Â Â Â Â Â Â Â Â Â Â Â Â 56
RFECÂ Â Â Â Â Â Â Â Â :Â Â Â Â Â 16Â Â Â Â Â Â Â Â Â Â Â Â Â Â 16
LSYMBÂ Â Â Â Â Â Â Â :Â Â Â 2843Â Â Â Â Â Â Â Â Â Â Â Â 10594
INTLVBLOCKÂ Â Â :Â Â Â Â 255Â Â Â Â Â Â Â Â Â Â Â Â Â Â 56
AELEMÂ Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â —-
> vdsl status counts[ Counters: Showtime ]
ElapsedTime  :   40188            40188 (seconds)
FECÂ Â Â Â Â Â Â Â Â Â :Â Â Â 24751Â Â Â Â Â Â Â Â Â Â Â Â 54519
HECÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
CRC_PÂ Â Â Â Â Â Â Â :Â Â Â Â Â Â 2Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
CRCP_PÂ Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
CVP_PÂ Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
UASÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
LOFSÂ Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
[ Counters: 15Min ]
ElapsedTime  :    203             203 (seconds)
CRCÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
FECÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 1Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
CRC_PÂ Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
ESÂ Â Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
SESÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
LOSSÂ Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
[Â Counters:Â 1DAYÂ ]
ElapsedTime  :   46103            46103 (seconds)
LOFSÂ Â Â Â Â Â Â Â Â :Â Â Â Â Â Â 0Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0You need to login in order to vote
May 24, 2020 at 12:44 pm #7544So far so good.
If you end up with around 50k FEC errors within 24h that will be really good.
May 24, 2020 at 1:00 pm #7545I’m wondering if I should order new faceplate for delivery tomorrow.  Or am I’m being to optimistic?
May 24, 2020 at 1:05 pm #7548I don’t think is to expensive and is worth to try, wait till end of the day to see results.
May 24, 2020 at 5:33 pm #7587May 24, 2020 at 5:37 pm #7588vdsl status
DS Attainable Rate      : 43608064 bps   US Attainable Rate   : 10700429 bps
FECSÂ Â Â Â Â Â Â Â Â :Â Â Â 49224Â Â Â Â Â Â Â Â Â Â Â Â 54519Â (seconds)
ElapsedTime  :   57544            57544 (seconds)
FECÂ Â Â Â Â Â Â Â Â Â :Â Â Â 49224Â Â Â Â Â Â Â Â Â Â Â Â 54519
[ Counters: 15Min ]
ElapsedTime  :    295             295 (seconds)
FECÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â 16Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
ElapsedTime  :   65995            65995 (seconds)
May 24, 2020 at 5:42 pm #7589Looks like your issue may be solved. If it keeps like that for whole week there is a big chance for fastpath around Saturday (latest)
If you decide to change master socket, don’t do it until you get fastpath, is important now to keep modem connected constantly.
May 24, 2020 at 6:25 pm #7590My new master socket will be here tomorrow, I’d like to fit it tomorrow, no wiring to do, I will just plug the front faceplate in and then plug in modem.
May 24, 2020 at 7:23 pm #7591Well, your choice. Thing is if you will get fastpath you can disconnect any time and you will not loose it (if amount of errors will not go through the roof) . If you disconnect tomorrow you will brake DLM monitoring period and new period will start (at least 6 days). Also I personally will recommend to change whole socket it will take 5 min any way. Hope you order one with clear idc as your current one.
May 24, 2020 at 7:59 pm #7592Well, your choice. Thing is if you will get fastpath you can disconnect any time and you will not loose it (if amount of errors will not go through the roof) . If you disconnect tomorrow you will brake DLM monitoring period and new period will start (at least 6 days). Also I personally will recommend to change whole socket it will take 5 min any way. Hope you order one with clear idc as your current one.
Yeah i ordered the exact same one as i have.
I appreciate all your help and advice. I will sleep on it tonight and see how it goes.
May 24, 2020 at 9:57 pm #7593[ Counters: Showtime ]
ElapsedTime  :   71144            71144 (seconds)
FECÂ Â Â Â Â Â Â Â Â Â :Â Â Â 80774Â Â Â Â Â Â Â Â Â Â Â Â 54519
[ Counters: 15Min ]
ElapsedTime  :    582             582 (seconds)
FECÂ Â Â Â Â Â Â Â Â Â :Â Â Â Â Â 29Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
ElapsedTime  :   81582            81582 (seconds)
May 24, 2020 at 10:00 pm #7594That is still pretty good like for nearly 24h. I will say big improvement.
May 24, 2020 at 10:04 pm #7595May 24, 2020 at 10:09 pm #7596 -
- The topic ‘RT-AC86U 384.16 Hi, I updated to the latest Merlin firmware this morning (about 9 am) and since doing so my NE CRC count has gone up to 326598 over 5 hours. ...’ is closed to new replies.
