Viewing 15 posts - 511 through 525 (of 718 total)
  • #7598
    Bully
    • Replies 386
    This mornings stats –
    vdsl status
    DS Actual Rate          : 29999000 bps   US Actual Rate       : 10596000 bps
    DS Attainable Rate      : 44484544 bps   US Attainable Rate   : 10792156 bps
    DS Interleave Depth     :     1513       US Interleave Depth  :        1
    NE Current Attenuation  :       20 dB    Cur SNR Margin       :        8  dB
    DS actual PSD           :     6. 4 dB    US actual PSD        :    13. 1  dB
    NE CRC Count            :        9       FE CRC Count         :     4080
    NE ES Count             :        1       FE  ES Count         :     2658
    Xdsl Reset Times        :        0       Xdsl Link  Times     :        1
    VDSL Firmware Version   : 05-07-09-0F-01-07   [with Vectoring support]
    > vdsl status more
    LOS          :      0               0
    FECS         :   130271            54522 (seconds)
    ES           :      1            2658 (seconds)
    UAS          :     34            87891 (seconds)
    CRC          :      9            4080
    INP          :      0              45 (symbols)
    InterleaveDelay :      0            1600 (1/100 ms)
    NFEC         :    255              56
    LSYMB        :   2843            10594
    INTLVBLOCK   :    255              56
    > vdsl status counts
    [ Counters: Showtime ]
    ElapsedTime  :   104760            104760 (seconds)
    CRC          :      9            4080
    FEC          :   130271            54522
    HEC          :      0               0
    CRC_P        :      2               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      1            2658
    SES          :      0              31
    LOSS         :      0               1
    UAS          :      0               0
    LOFS         :      0               0
    [ Counters: 15Min ]
    ElapsedTime  :    409             409 (seconds)
    CRC          :      0               0
    FEC          :      0               0
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0               0
    SES          :      0               0
    LOSS         :      0               0
    UAS          :      0               0
    LOFS         :      0               0
    [ Counters: 1DAY ]
    ElapsedTime  :   33709            33709 (seconds)
    CRC          :      0               0
    FEC          :   41497               3
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0               0
    SES          :      0               0
    LOSS         :      0               0
    UAS          :      0               0
    LOFS         :      0               0
    #7599
    AvatarMrk26
    • Replies 465
    That’s really good, previous day with below 100k FEC errors, 41k now, not getting worse, that is a good sign. Do you still have SRA disabled?
    #7600
    Bully
    • Replies 386
    Yeah SRA still off.
    #7601
    AvatarMrk26
    • Replies 465
    That’s good.
    #7602
    • Replies 8,717
    DS Interleave Depth     :     1513  will be interesting if/when this changes
    @Bully
    – where did you purchase your replacement Master Socket / Faceplate as there are a lot of fakes out there ?
    #7611
    Bully
    • Replies 386
    [quote quote=7602]DS Interleave Depth : 1513 will be interesting if/when this changes @Bully – where did you purchase your replacement Master Socket / Faceplate as there are a lot of fakes out there ?[/quote]
    Amazon  ?
    #7612
    AvatarMrk26
    • Replies 465
    [quote quote=7602]DS Interleave Depth : 1513 will be interesting if/when this changes [/quote]
    Don’t want to guess too much but could be two stage intervention, one after 3 days to reduce interleave and then further 5-6 day to get fastpath, or fastpath straight away after 5-6 days.
    #7613
    • Replies 8,717
    [quote quote=7611]
    Amazon ?[/quote]
    Better then Ebay, hopefully will be Ok as usually better suppliers etc.
    #7614
    Bully
    • Replies 386
    Any way to tell a fake?
    #7615
    AvatarMrk26
    • Replies 465
    Ebay is not that bad, checked history, I bought mine original BT for 8 pounds last year, this was nte5c with mk4 faceplate.
    #7616
    • Replies 8,717
    Like most things in life, you purchase from Ebay,  second hand items, could be good, probable is, but could also be faulty. Lots of Chinese imports etc. with different standard for Resistors and surge protectors etc.
    Amazon, less likely, alas I could not tell a good unit from a copy, so when yours arrives, just make sure it looks like yours and has same values for electrical components inside it, same thickness for wiring and quality of electrical joints etc. etc.
    (just my view)
    #7618
    AvatarMrk26
    • Replies 465
    I don’t think you can get fake ones like BT official from China. Most likely BT engineers sell them, mine was brand new and sealed. However you can buy something equivalent with slightly different shape made by different supplier without BT logo, other than that official BT is made so cheap way that is not worth for China to copy
    Have look for this if you want to see what’s inside https://youtu.be/jD67a-ZC7VY
    #7620
    • Replies 8,717
    [quote quote=7618]I don’t think you can get fake ones like BT official from China. Most likely BT engineers sell them, mine was brand new and sealed. However you can buy something equivalent with slightly different shape made by different supplier without BT logo, other than that official BT is made so cheap way that is not worth for China to copy [/quote]
    You are braver than I am
    #7626
    Bully
    • Replies 386
    Wish I had not watched that video, it really is cheaply made, no pcb and no solder fixing the components on to the tin sheets
    #7627
    AvatarMrk26
    • Replies 465
    That’s why I said is not worth for China to copy
