Bully.
- May 22, 2020 at 9:53 pm #7508May 23, 2020 at 8:24 am #7517
[ Counters: Showtime ]
Near End Far End Note
ElapsedTime : 47500 47500 (seconds)
CRC : 1 4080
FEC : 962107 54518
HEC : 0 0
CRC_P : 0 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 1 2658
SES : 0 31
LOSS : 0 1
UAS : 0 0
LOFS : 0 0
[ Counters: 15Min ]
ElapsedTime : 486 486 (seconds)
CRC : 0 0
FEC : 25 0
HEC : 0 0
CRC_P : 0 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 0 0
SES : 0 0
LOSS : 0 0
UAS : 0 0
LOFS : 0 0
[ Counters: 1DAY ]
ElapsedTime : 54486 54486 (seconds)
CRC : 1 4080
FEC : 962107 54518
HEC : 0 0
CRC_P : 0 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 1 2658
SES : 0 31
LOSS : 0 1
UAS : 0 0
May 23, 2020 at 8:45 am #7518These don’t looking promising, unfortunately..
I think is worth to check how modem will perform on test socket before you report fault to BT.
May 23, 2020 at 12:04 pm #7519I will plug modem into test socket first thing tomorrow morning and see how it goes.
SNR has increased by 1 db
vdsl status
DS Actual Rate : 30000000 bps US Actual Rate : 10574000 bps
DS Attainable Rate : 38677616 bps US Attainable Rate : 10743592 bps
DS Interleave Depth : 1336 US Interleave Depth : 1
NE Current Attenuation : 20 dB Cur SNR Margin : 9 dB
DS actual PSD : 6. 5 dB US actual PSD : 13. 3 dB
NE CRC Count : 1 FE CRC Count : 4080
NE ES Count : 1 FE ES Count : 2658
Xdsl Reset Times : 0 Xdsl Link Times : 1
VDSL Firmware Version : 05-07-09-0F-01-07 [with Vectoring support]
Test Mode : DISABLE
DSLAM CHIPSET VENDOR : < IFTN >
> vdsl status more———————- ATU-R Info (hw: annex A, f/w: annex A/B/C) ———–
Trellis : 1 1
Bitswap : 1 1
ReTxEnable : 0 0
VirtualNoise : 0 0
20BitSupport : 0 0
LatencyPath : 0 0
LOS : 0 0
LOF : 0 0
LPR : 0 0
LOM : 0 0
SosSuccess : 0 0
NCD : 0 0
LCD : 0 0
FECS : 966566 54518 (seconds)
ES : 1 2658 (seconds)
SES : 0 31 (seconds)
LOSS : 0 1 (seconds)
UAS : 34 87620 (seconds)
HECError : 0 0
CRC : 1 4080
RsCorrection : 0 0
INP : 0 40 (symbols)
InterleaveDelay : 0 1600 (1/100 ms)
NFEC : 255 61
RFEC : 16 16
LSYMB : 2837 10252
INTLVBLOCK : 255 61
AELEM : 0 —-
> vdsl status counts[ Counters: Showtime ]
ElapsedTime : 59104 59104 (seconds)
CRC : 1 4080
FEC : 967669 54518
HEC : 0 0
CRC_P : 0 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 1 2658
SES : 0 31
LOSS : 0 1
UAS : 0 0
LOFS : 0 0
[ Counters: 15Min ]
ElapsedTime : 285 285 (seconds)
CRC : 0 0
FEC : 3739 0
HEC : 0 0
CRC_P : 0 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 0 0
SES : 0 0
LOSS : 0 0
UAS : 0 0
LOFS : 0 0
[ Counters: 1DAY ]
ElapsedTime : 67785 67785 (seconds)
CRC : 1 4080
FEC : 967669 54518
HEC : 0 0
CRC_P : 0 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 1 2658
SES : 0 31
LOSS : 0 1
UAS : 0 0
May 23, 2020 at 1:15 pm #7522May 23, 2020 at 2:03 pm #7523Try:
- Switch on router.
- For at least 10 seconds, press the Factory Reset button
- Device is automatically restarted.
- Default settings have been restored.
Never tried this myself but should bring DrayTeK 130 back to how it was when it first was plugged in.
May 23, 2020 at 2:05 pm #7524Try:
- Switch on router.
so I can’t do it via cli?
May 23, 2020 at 2:05 pm #7525May 23, 2020 at 2:11 pm #7526May 23, 2020 at 2:12 pm #7527The only issue with re-tweaking the modem, is that when BT check your line, it is best to have modem at default incase they decide to check what stats your modem is reporting, highly unlikely, but it has happened with me when I had my Fritz!Box as I had a line branching problem which Fritz!Box identified, BT underground works team then dug up the road and sorted my connection
May 23, 2020 at 11:20 pm #7529Just plugged modem into test socket no phones plugged in. Will see what stats are like in the morning and throughout the day tomorrow.
May 24, 2020 at 8:24 am #7533vdsl status
DS Actual Rate : 29999000 bps US Actual Rate : 10596000 bps
DS Attainable Rate : 44078176 bps US Attainable Rate : 10725733 bps
DS Interleave Depth : 1513 US Interleave Depth : 1
NE Current Attenuation : 20 dB Cur SNR Margin : 8 dB
DS actual PSD : 6. 4 dB US actual PSD : 13. 1 dB
NE CRC Count : 9 FE CRC Count : 4080
Test Mode : DISABLE
Trellis : 1 1
Bitswap : 1 1
ReTxEnable : 0 0
VirtualNoise : 0 0
20BitSupport : 0 0
LatencyPath : 0 0
LOS : 0 0
LOF : 0 0
LPR : 0 0
LOM : 0 0
SosSuccess : 0 0
NCD : 0 0
LCD : 0 0
FECS : 16470 54518 (seconds)
UAS : 34 87891 (seconds)
HECError : 0 0
CRC : 9 4080
RsCorrection : 0 0
INP : 0 45 (symbols)
NFEC : 255 56
RFEC : 16 16
LSYMB : 2843 10594
INTLVBLOCK : 255 56
AELEM : 0 —-
ElapsedTime : 28608 28608 (seconds)
CRC : 9 4080
FEC : 16470 54518
HEC : 0 0
CRC_P : 2 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 1 2658
SES : 0 31
LOSS : 0 1
UAS : 0 0
LOFS : 0 0
[ Counters: 15Min ]
ElapsedTime : 431 431 (seconds)
CRC : 9 0
FEC : 3579 0
HEC : 0 0
CRC_P : 2 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 1 0
SES : 0 0
LOSS : 0 0
UAS : 0 0
LOFS : 0 0
[ Counters: 1DAY ]
ElapsedTime : 32831 32831 (seconds)
CRC : 9 4080
FEC : 16470 54518
HEC : 0 0
CRC_P : 2 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 1 2658
SES : 0 31
LOSS : 0 1
UAS : 0 0
May 24, 2020 at 8:30 am #7534Looking really good like for 9h. Will be nice if it’s stay like that till evening.
May 24, 2020 at 9:11 am #7538Also your DS Attainable Rate : 44078176 bps
A nice 6 Mb increase and actually 2Mb higher than you very first stats posting on this thread
May 24, 2020 at 9:39 am #7540 - AuthorPosts
