Viewing 15 posts - 61 through 75 (of 718 total)
  • #6458
    AvatarMrk26
    • Replies 465
    Can you post picture how is connected your modem and how is connected extension line to master socket? Just wonder if telephone line which going to your living room is connected to filtered socket or unfiltered.
    #6459
    Bully
    • Replies 386
    Cat5e cable RJ45 from from face plate to modem RJ11.  Phone extension wired on inside of filtered face plate to living room socket, so this is filtered.
    #6460
    AvatarMrk26
    • Replies 465
    Well is not guaranteed , unless you did it and you know how was connected. When you planing next time to turn off your modem take off face plate and have a look where is connected (when you take off face plate it will disconnect modem), there are two sockets where cables can be inserted, one for three cables an that is on base of master socket this is filtered for telephone extension only ( picture 3 from attached auction ) and there is smaller one for two cables only on the back of the faceplate which is unfiltered for broadband extension (picture 4 from auction) . I only suggest that base on your enormous amount of FEC errors.
    Link to auction Mk4 faceplate
    #6463
    • Replies 8,709
    I think high is not enough to say… If that won’t get worse, I mean if you don’t loose fastpath I will add at least 1snr to downstream to increase line stability. With this amount of errors you barely have chance to get fastpath on downstream. Have you got filtered face plate mounted? Looking by amount of FEC errors I doubt.
    It invites conversation from others ;-)
    In reality, the original issue was high CRC’s, that has now been resolved, new concern for myself is FEC’s which maybe down to the value of the hex digits in the original command we used to enable bitswap in both directions (and if that command indeed worked) they way I intended.
    Hopefully Fastpath will kick in in both directions which should help with FEC. but only time will tell
    @Bully
    – has Fastpath ever been On in both direction via the Draytek 130 ?
    @Mrk26
    – congrats your status has now changed to “UKTechHub Addict”
    #6489
    Bully
    • Replies 386
    Originally I had fast path on both directions, I can’t remember when I lost it on downstream.
    #6491
    • Replies 8,709
    Good to know about Fastpath, hopefully FastPath will return in the next few days in both directions
    #6492
    Bully
    • Replies 386
    With the amount of FEC errors will fast path return?
    [ Counters: Showtime ]
    ElapsedTime  :   383280            383280 (seconds)
    CRC          :     -1            4046
    FEC          :   258004342            53814
    HEC          :      0               0
    CRC_P        :     -1               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0            2646
    SES          :      3              31
    LOSS         :      0               1
    UAS          :      0               0
    LOFS         :      0               0
    [ Counters: 15Min ]
    ElapsedTime  :    103             103 (seconds)
    CRC          :      0               0
    FEC          :   239368               0
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0               0
    SES          :      0               0
    LOSS         :      0               0
    UAS          :      0               0
    LOFS         :      0               0
    [ Counters: 1DAY ]
    ElapsedTime  :   7303            7303 (seconds)
    CRC          :      0               0
    FEC          :   16686684               0
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0               0
    SES          :      0               0
    LOSS         :      0               0
    UAS          :      0               0
    LOFS         :      0               0
    DS Actual Rate          : 35000000 bps   US Actual Rate       : 10666000 bps
    DS Attainable Rate      : 44633936 bps   US Attainable Rate   : 10666135 bps
    DS Interleave Depth     :     1514       US Interleave Depth  :        1
    NE Current Attenuation  :       20 dB    Cur SNR Margin       :        6  dB
    DS actual PSD           :     6. 4 dB    US actual PSD        :    13. 1  dB
    NE CRC Count            :        1       FE CRC Count         :     4046
    NE ES Count             :        1       FE  ES Count         :     2646
    Xdsl Reset Times        :        0       Xdsl Link  Times     :        4
    LOS          :      4               0
    FECS         :   258146886            53814 (seconds)
    ES           :      1            2646 (seconds)
    UAS          :     33            80427 (seconds)
    CRC          :      1            4046
    INP          :      0              40 (symbols)
    InterleaveDelay :      0            1500 (1/100 ms)
    NFEC         :    255              61
    LSYMB        :   2862            11974
    INTLVBLOCK   :    255              61
    #6493
    • Replies 8,709
    highly unlikely as high FEC will encourage interleaving
    #6494
    AvatarMrk26
    • Replies 465
    Well we all know every line is different but based on my experience if I had 50k plus FEC errors per day there was no chance for fastpath. If nothing happen within 5-6 days from day when you get fastpath on upstream then I will not expect too much.
    #6496
    • Replies 8,709
    Well we all know every line is different but based on my experience if I had 50k plus FEC errors there was no chance for fastpath. If nothing happen within 5-6 days from day when you get fastpath on upstream then I will not expect too much.
    Defo
    #6497
    Bully
    • Replies 386
    FECS sake what do I do?
    #6498
    AvatarMrk26
    • Replies 465
    Maybe is worth to look in to root of the problem? 🤔 Your internal wiring as a point 1. 😉
    #6499
    Bully
    • Replies 386
    OK, i maybe able to check early tomorrow morning, when the other members of the family are still asleep.
    #6500
    • Replies 8,709
    Or be patient for a few more days and see if DLM sorts it out for you, at the beginning your FEC where relatively low, so as long as nothing has changed physically, then I am hopeful they will reduce ?
    Alas, this is not an easy subject as way to many variables,
    BTW and for reference – I have had issues over the last 2 week with my DrayTek 130 overheating, (I believe) and causing reboots due to Modem sitting directly ontop or my Netgear Xr500 and as a result trashing my IP profile
    Fritz!box is back in to recovers IP Profile currently, so nothing is guaranteed ;-)
    #6502
    Bully
    • Replies 386
    Is there a way to tell if G.INP is active on my line?  I hear BT have rolled out testing on ECI cabinets.
